那位好心的人,帮我看一下我的程序怎么错了,急用,求求!!
#include <reg52.h>
#include<absacc.h>
//ad控制线
#define ad_244 XBYTE[0xbfff];
sbit ad_stb=P3^3;
sbit ad_start=P1^1;
//lcd控制线
sbit lcd_di=P1^7;
sbit lcd_rw=P1^2;
sbit lcd_e=P1^0;
//7289控制线
sbit cs7289=P1^3;
sbit clk7289=P1^4;
sbit dio7289=P1^5;
//sbit key7289=P1^6; //7289查询方式
sbit key7289=P3^2; //7289中断方式
sbit baoj=P3^5;
//7289子程序
void ini_7289(void);
void send7289(short);
short receive(void);
void keyin(void);
//lcd子程序
void ini_lcd(void);
void lcdd_send(short);
void lcdi_send(short);
void chk_busy(void);
//ad子程序
void ad(void);
void baojing(void);
void d_change(long);
//初始化,编号,日期
void ini();
void error1(void);
void nop1()
void change(s)
int dealy; //全局变量
short sh=0; //商品号
short dot=0; //小数点标志
bit list=0;
short qb=0;
char xdata shuju[7]="";
short xdata bcd[5];
char xdata s1[16]="单价: 元";
char xdata s2[16]="重量: Kg";
char xdata s3[16]="金额: 元";
char xdata s4[16]="累计: 元";
char code message0[]="联华超市 乐山分店";
char code message1[]="输入收银员代号:";
char code message2[]="输入日期:";
char code message3[16]=" --联华超市-- ";
char code message5[16]="匀桧叶商场欢迎您!";
char xdata bianhao[16]="收银员: ";
char xdata riqi[16]=" - - ";
long int xdata zongjia=0,jine=0,jine1=0;
int xdata shizhong=0,pizhong=0,zhongliang=0;
long int xdata qingdan[20][4];
char code shangpin[11][4]={{"单价"},{"苹果"},{"糖果"},{"花生"},{"大米"},
{"衣服"},{"刷子"},{"瓜子"},{"桔子"},{"香蕉"},{"大豆"}};
long int xdata danjia[11]=
{0,2000,3635,5502,6660,3320,5502,660,3210,6600,5600};
char xdata jiage[6]={0x0,0x0,0x0,0xfe,0x0,0x0}; // 0.00
short xdata xiuzheng[]={0,2,5,6,7,8,9,12,13};
char s[16];
{s[6]=shuju[0];
s[7]=shuju[1];
s[8]=shuju[2];
s[9]=shuju[3];
s[10]=shuju[4];
s[11]=shuju[5];
s[12]=shuju[6];
void main()
{short i,j;
long int x,z;
int y;
int xdata duilie[3]={0};
P1=0xff;
ini_lcd(); //初始化LCD
lcdi_send(0x8a);
while(message0[i]) lcdd_send(message0[i++]);
ini_7289(); //初始化7289
pizhong=ad1();
lcdi_send(0x1); //总清 屏
ini(); //初始页面,收银员编号,日期
EA=1;EX0=1; //中断
//EX1=1;
//ad_start=1;
while(1)
{if(list){lcdi_send(0x80); //显示单位名称
for(i=0;i<16;i++) lcdd_send(message3[i]);
x=qingdan[0][0]; //商品名 单价
for(i=0;i<4;i++) s1[i]=shangpin[x][i];
x=qingdan[0][1];
d_change(x); change(s1);
lcdi_send(0x90);
for(i=0;i<16;i++) lcdd_send(s1[i]);
x=qingdan[0][2]; //显示重量
d_change(x); change(s2);
s2[10]=s2[9];s2[9]='.';
if(s2[8]==32) s2[8]=0x30;
lcdi_send(0x88);
for(i=0;i<16;i++) lcdd_send(s2[i]);
x=qingdan[0][3];
d_change(x); change(s3);
lcdi_send(0x98);
for(i=0;i<16;i++) lcdd_send(s3[i]); //以上为第一页
EA=0;EX0=0; //关键盘中断
for(j=1;j<qb;j++)
{while(key7289);
x=qingdan[j][2];
d_change(x); change(s2); //显示数据
s2[10]=s2[9];
s2[9]='.'; if(s2[8]==32) s2[8]=0x30;
lcdi_send(0x90);
x=qingdan[j][1];
x=qingdan[j][0];
lcdi_send(0x80);
x=qingdan[j][3];
lcdi_send(0x88);
lcdi_send(0x98);
for(i=0;i<16;i++) lcdd_send(0x20);
lcdi_send(0x98);
while(key7289==0);
while(key7289);
d_change(zongjia); change(s4);
lcdi_send(0x80);
for(i=0;i<16;i++) lcdd_send(s4[i]);
lcdi_send(0x90);
for(i=0;i<16;i++) lcdd_send(bianhao[i]);
lcdi_send(0x88);
for(i=0;i<16;i++) lcdd_send(message5[i]);
lcdi_send(0x98);
for(i=0;i<16;i++) lcdd_send(riqi[i]);
list=0;
while(key7289==0);
while(key7289==1);
while(key7289==0);
EA=1;EX0=1;
else{ y=0;
/* duilie[2]=duilie[1]; //数字滤波
duilie[1]=duilie[0];
y=ad1();
duilie[0]=y>>1;
x=duilie[0];
x=x<<1;
x=x+duilie[1]+duilie[2]; */
zhongliang=ad1();
shizhong=zhongliang-pizhong; //数据转换
x=danjia[sh];
jine1=shizhong*x;
jine=jine1/1000;
d_change(shizhong); change(s2); //显示数据
s2[10]=s2[9]; s2[9]='.';
lcdi_send(0x90);
d_change(danjia[sh]); change(s1);
for(i=0;i<4;i++) s1[i]=shangpin[sh][i];
lcdi_send(0x80);
d_change(jine); change(s3);
lcdi_send(0x88);
lcdi_send(0x98);
lcdi_send(0x98);
//while(1);
void keyin(void) interrupt 0 using 0 //中断0服务程序
{char X,i;
long int y;
send7289(0x15); //接收数据
X=receive();
cs7289=1;
X=X&0x1f;
switch(X)
{case 0xf : {zongjia=zongjia+jine;
qingdan[qb][0]=sh;
qingdan[qb][1]=danjia[sh];
qingdan[qb][2]=shizhong;
qingdan[qb][3]=jine;
qb++; sh=0;dot=0;
danjia[0]=0;
for(i=0;i<6;i++) jiage[i]=0;
break; //累加
case 0xe : pizhong=zhongliang; break; //去皮
case 0xd : {danjia[sh]=0;dot=0;} break; //清单价
case 0xc : {zongjia=0;jine=0;dot=0;list=0;qb=0;pizhong=0;
if(sh==0) danjia[sh]=0;} break; //总清
case 0xa : dot=1;break; //点
case 0xb : list=1;break; //清单
case 0x19 : sh=10;break;
case 0x18 : sh=9;break;
case 0x17 : sh=8;break;
case 0x16 : sh=7;break;
case 0x15 : sh=6;break;
case 0x14 : sh=5;break;
case 0x13 : sh=4;break;
case 0x12 : sh=3;break;
case 0x11 : sh=2;break;
case 0x10 : sh=1;break;
case 0x1f :
case 0x1e :
case 0x1d :
case 0x1c :
case 0x1a : break;
case 0x1b : dot=1;break;
default :{ if(dot==0) {jiage[0]=jiage[1];jiage[1]=jiage[2];jiage[2]=X;}
if(dot==1) {jiage[4]=X;dot++; }
else if(dot==2) {jiage[5]=X; dot++;}
else if(dot>2) break;
// lcdi_send(0x84);
y=jiage[0];
y=y*10+jiage[1];
y=y*10+jiage[2];
y=y*10+jiage[4];
danjia[sh]=y*10+jiage[5];
while(key7289==0); //等待键盘松开
void ad(void) interrupt 2 using 1
{short x,y;
x=ad_244;
y=x;
if(x&0x80) baojing();
else x=x>>4;
y=y&0xf;
bcd[x]=y;
//初始页面
void ini() // 输入收银员编号,日期
{short i,j;
char X;
lcdi_send(0x80); //提示输入收银员编号
i=0;
while(message1[i]) lcdd_send(message1[i++]);
for(i=8;i<12;i++)
while(key7289);
X=receive();
cs7289=1;
bianhao[i]=X+0x30;
lcdi_send(0x93);
for(j=8;j<16;j++) lcdd_send(bianhao[j]);
while(key7289==0);
lcdi_send(0x88); //提示输入日期
i=0;
while(message2[i]) lcdd_send(message2[i++]);
for(i=0;i<10;i++) //输入日期
{if(i==4||i==7) i++;
while(key7289==1);
X=receive();
cs7289=1;
riqi[i]=X+0x30;
j=0;
lcdi_send(0x9a);
for(j=0;j<10;j++) lcdd_send(riqi[j]);
while(key7289==0);
while(key7289);
nop1();
while(key7289==0);
nop1();
lcdi_send(0x1);
//LCD子程序
void ini_lcd() //LCD初始化子程序
lcdi_send(0x30);
lcdi_send(0xc);
lcdi_send(0x2); //光标右移,AC+1
void lcdd_send(short X) //LCD发送数据子程序
{chk_busy();
nop1();
lcd_di=1;lcd_rw=0;lcd_e=0;
P0=X;
for(dealy=0;dealy<5;dealy++);//
lcd_e=1; X=X;
P0=0xff;
void lcdi_send(short X) //LCD发送指令子程序
{chk_busy();
nop1();
lcd_di=0;lcd_rw=0;lcd_e=0;
P0=X;
lcd_e=1; X=X;
P0=0xff;
void chk_busy()
{short i=0xff;
while(i&0x80)
{lcd_di=0;
lcd_rw=1;
lcd_e=0;
i=P0;
lcd_e=1;
//7289子程序
void ini_7289()
{short i;
cs7289=1; key7289=1; dio7289=1; //7289初始化子程序
for(i=0;i<50;i++)
for(dealy=0;dealy<5000;dealy++); //延时25ms
send7289(0xa4); cs7289=1;
void send7289(short X) //7289发送数据子程序
{short i,j=1;
cs7289=0;
for(dealy=0;dealy<6;dealy++); //延时50us
for(i=7;i>=0;i--)
{j=j<<i;
dio7289=X&j;
j=1;j=1;clk7289=1;
for(dealy=0;dealy<1;dealy++) ; //延时10us
clk7289=0;
dio7289=0;
short receive() //7289接收数据子程序
{short i,X=0;
dio7289=1;
for(i=0;i<=7;i++)
{clk7289=1;
for(dealy=0;dealy<1;dealy++); //延时10us
X=X<<1;
if(dio7289)X++;
clk7289=0;
dio7289=0;
return(X);
//ad
//AD子程序
int ad1()
{short k,x;
int ad_zhi=0,xz;
EA=0;
ad_start=1;
for(k=0;k<5;k++)
{ while(ad_stb);
x=ad_244;
x=x&0xf;
ad_zhi=ad_zhi*10+x;
ad_start=0;
EA=1;EX0=1;
ad_zhi=ad_zhi>>1;
xz=ad_zhi-50;
xz=xz/100;
ad_zhi=ad_zhi+xiuzheng[xz];
return(ad_zhi);
void d_change(long X)
{char qian,bai,shi,ge,shifen,baifen;
long int yu;
if(X>999999) error1();
qian=X/100000; yu=X%100000;
bai=yu/10000; yu=yu%10000;
shi=yu/1000; yu=yu%1000;
ge=yu/100; yu=yu%100;
shifen=yu/10;
baifen=yu%10;
qian=qian+0x30;
bai=bai+0x30;
shi=shi+0x30;
ge=ge+0x30;
shifen=shifen+0x30;
baifen=baifen+0x30;
if(qian==0x30)
{qian=0x20;
if(bai==0x30)
{bai=0x20;
if(shi==0x30) shi=0x20;
shuju[0]=qian;
shuju[1]=bai;
shuju[2]=shi;
shuju[3]=ge;
shuju[4]='.';
shuju[5]=shifen;
shuju[6]=baifen;
void baojing()
{short i;
for(i=0;i<50;i++)
{baoj=0;
for(dealy=0;dealy<10;dealy++);
baoj=1;
答 1: 狂晕,这怎么看啊?二天也看不完 答 2: 那里错了。到底那里错了?
#include<absacc.h>
//ad控制线
sbit ad_stb=P3^3;
sbit ad_start=P1^1;
//lcd控制线
sbit lcd_di=P1^7;
sbit lcd_rw=P1^2;
sbit lcd_e=P1^0;
//7289控制线
sbit cs7289=P1^3;
sbit clk7289=P1^4;
sbit dio7289=P1^5;
sbit baoj=P3^5;
//7289子程序
void keyin(void);
//lcd子程序
void ini_lcd(void);
//ad子程序
void ad(void);
void baojing(void);
//初始化,编号,日期
void ini();
void error1(void);
void nop1()
void change(s)
int dealy; //全局变量
short sh=0; //商品号
bit list=0;
short qb=0;
short xdata bcd[5];
char s[16];
{s[6]=shuju[0];
s[7]=shuju[1];
s[8]=shuju[2];
s[9]=shuju[3];
s[10]=shuju[4];
s[11]=shuju[5];
s[12]=shuju[6];
void main()
{short i,j;
long int x,z;
int y;
P1=0xff;
ini_lcd(); //初始化LCD
lcdi_send(0x8a);
pizhong=ad1();
EA=1;EX0=1; //中断
//EX1=1;
//ad_start=1;
while(1)
x=qingdan[0][1];
lcdi_send(0x90);
lcdi_send(0x88);
x=qingdan[0][3];
lcdi_send(0x98);
EA=0;EX0=0; //关键盘中断
for(j=1;j<qb;j++)
{while(key7289);
x=qingdan[j][2];
s2[10]=s2[9];
lcdi_send(0x90);
x=qingdan[j][1];
x=qingdan[j][0];
lcdi_send(0x80);
x=qingdan[j][3];
lcdi_send(0x88);
lcdi_send(0x98);
lcdi_send(0x98);
while(key7289==0);
while(key7289);
lcdi_send(0x80);
lcdi_send(0x90);
lcdi_send(0x88);
lcdi_send(0x98);
list=0;
while(key7289==0);
while(key7289==1);
while(key7289==0);
EA=1;EX0=1;
else{ y=0;
y=ad1();
duilie[0]=y>>1;
x=duilie[0];
x=x<<1;
zhongliang=ad1();
x=danjia[sh];
jine1=shizhong*x;
jine=jine1/1000;
lcdi_send(0x90);
lcdi_send(0x80);
lcdi_send(0x88);
lcdi_send(0x98);
lcdi_send(0x98);
//while(1);
{char X,i;
long int y;
X=receive();
cs7289=1;
X=X&0x1f;
switch(X)
qingdan[qb][0]=sh;
qb++; sh=0;dot=0;
danjia[0]=0;
break; //累加
case 0x1f :
case 0x1e :
case 0x1d :
case 0x1c :
case 0x1a : break;
// lcdi_send(0x84);
y=jiage[0];
y=y*10+jiage[1];
y=y*10+jiage[2];
y=y*10+jiage[4];
{short x,y;
x=ad_244;
y=x;
else x=x>>4;
y=y&0xf;
bcd[x]=y;
//初始页面
{short i,j;
char X;
i=0;
for(i=8;i<12;i++)
while(key7289);
X=receive();
cs7289=1;
bianhao[i]=X+0x30;
lcdi_send(0x93);
while(key7289==0);
i=0;
while(key7289==1);
X=receive();
cs7289=1;
riqi[i]=X+0x30;
j=0;
lcdi_send(0x9a);
while(key7289==0);
while(key7289);
nop1();
while(key7289==0);
nop1();
lcdi_send(0x1);
//LCD子程序
lcdi_send(0x30);
lcdi_send(0xc);
{chk_busy();
nop1();
P0=X;
lcd_e=1; X=X;
P0=0xff;
{chk_busy();
nop1();
P0=X;
lcd_e=1; X=X;
P0=0xff;
void chk_busy()
{short i=0xff;
while(i&0x80)
{lcd_di=0;
lcd_rw=1;
lcd_e=0;
i=P0;
lcd_e=1;
//7289子程序
void ini_7289()
{short i;
for(i=0;i<50;i++)
{short i,j=1;
cs7289=0;
for(i=7;i>=0;i--)
{j=j<<i;
dio7289=X&j;
j=1;j=1;clk7289=1;
clk7289=0;
dio7289=0;
{short i,X=0;
dio7289=1;
for(i=0;i<=7;i++)
{clk7289=1;
X=X<<1;
if(dio7289)X++;
clk7289=0;
dio7289=0;
return(X);
//ad
//AD子程序
int ad1()
{short k,x;
int ad_zhi=0,xz;
EA=0;
ad_start=1;
for(k=0;k<5;k++)
{ while(ad_stb);
x=ad_244;
x=x&0xf;
ad_zhi=ad_zhi*10+x;
ad_start=0;
EA=1;EX0=1;
ad_zhi=ad_zhi>>1;
xz=ad_zhi-50;
xz=xz/100;
return(ad_zhi);
long int yu;
shifen=yu/10;
baifen=yu%10;
qian=qian+0x30;
bai=bai+0x30;
shi=shi+0x30;
ge=ge+0x30;
shifen=shifen+0x30;
baifen=baifen+0x30;
if(qian==0x30)
{qian=0x20;
if(bai==0x30)
{bai=0x20;
shuju[0]=qian;
shuju[1]=bai;
shuju[2]=shi;
shuju[3]=ge;
shuju[4]='.';
shuju[5]=shifen;
shuju[6]=baifen;
void baojing()
{short i;
for(i=0;i<50;i++)
{baoj=0;
baoj=1;
