当我发送数据的时候,如果我把fifo的trigger leval设置成4,比如我要发送10个字,那是不是在第六个数发送出去的时候产生中断呢?
另外的一个主要的问题是,我如何才能把我要发的10个数送到fifo中去呢?因为上电以后fifo是复位状态的,里面是空的,自己中断是不可能了。那我的数得在什么时候采取什么方式放到fifo中去呢?
谢谢高手回复! 答 1: 我写的串口驱动自己看吧,很明了的。
你的问题就在这个源码中
serial.c
Project :
Author : kreal@163.net
Date : 04-10-10
Funtion : 串口驱动
#define SERIAL_G
#include "sysincludes.h"
Function : Uart ISR
Input : None
Output : None
void __irq ISR_Uart0 (void)
uchar iN, cnt ;
OSIntEnter();
if (rSUBSRCPND & BIT_SUB_TXD0) {
while ((rUFSTAT0 & (1<<9)) == 0) { // 塞满 FIFO 为止.
if (Com0.Rd != Com0.Wr) {
rUTXH0 = Com0.TxBuffer[Com0.Rd++];
if (Com0.Rd >= UART_TX_MAX_SIZE ) {
Com0.Rd = 0x00;
} else break; // 发送完毕.
rSUBSRCPND=(BIT_SUB_TXD0); // Clear Sub int pending.
else if( rSUBSRCPND & BIT_SUB_RXD0 )
cnt = rUFSTAT0 & 0x000F ;
for( iN = 0 ; iN < cnt ; iN ++ )
Com0.RxBuffer[Com0.pIn++] = rURXH0 ;
if( Com0.pIn>=UART_RX_MAX_SIZE )
Com0.pIn = 0 ;
rSUBSRCPND = BIT_SUB_RXD0 ;
OSIntExit();
ClearPending(BIT_UART0); // Clear master pending.
void __irq ISR_Uart1 (void)
uchar iN, cnt ;
OSIntEnter();
if (rSUBSRCPND & BIT_SUB_TXD1) {
while ((rUFSTAT1 & (1<<9)) == 0) { // 塞满 FIFO 为止.
if (Com1.Rd != Com1.Wr) {
rUTXH1 = Com1.TxBuffer[Com1.Rd++];
if (Com1.Rd >= UART_TX_MAX_SIZE ) {
Com1.Rd = 0x00;
rSUBSRCPND=(BIT_SUB_TXD1); // Clear Sub int pending.
else if( rSUBSRCPND & BIT_SUB_RXD1 )
cnt = rUFSTAT1 & 0x000F ;
Com1.RxBuffer[Com1.pIn++] = rURXH1 ;
if(Com1.pIn>=UART_RX_MAX_SIZE )
Com1.pIn = 0 ;
rSUBSRCPND = BIT_SUB_RXD1 ;
OSIntExit();
ClearPending(BIT_UART1); // Clear master pending
void __irq ISR_Uart2 (void)
uchar iN, cnt ;
OSIntEnter();
if (rSUBSRCPND & BIT_SUB_TXD2) {
while ((rUFSTAT2 & (1<<9)) == 0) { // 塞满 FIFO 为止.
if (Com2.Rd != Com2.Wr) {
rUTXH2 = Com2.TxBuffer[Com2.Rd++];
if (Com2.Rd >= UART_TX_MAX_SIZE ) {
Com2.Rd = 0x00;
rSUBSRCPND=(BIT_SUB_TXD2); // Clear Sub int pending.
else if( rSUBSRCPND & BIT_SUB_RXD2 )
cnt = rUFSTAT2 & 0x000F ;
Com2.RxBuffer[Com2.pIn++] = rURXH2 ;
if( Com2.pIn >= UART_RX_MAX_SIZE )
Com2.pIn = 0 ;
rSUBSRCPND = BIT_SUB_RXD2 ;
OSIntExit();
ClearPending(BIT_UART2); // Clear master pending.
Function : 串口初始化
Input : ComNum -- 串口号
baud -- 串口波特率
Output : COM_NUM_ERR 不存在的串口
COM_BAUD_ERR 非法波特率
char ComInit( uchar ComNum, uint baud )
if( ComNum>2 ) // Para Limit
return COM_NUM_ERR ; // 不存在的串口
else if( baud > 115200 )
return COM_BAUD_ERR ; // 非法的波物率
if(ComNum==0 )
rULCON0 = ((0<<6)+(0<<3)+(0<<2)+(3<<0)); //stop bit and parity bit
rUCON0 = ((0<<10)+(0<<9)+(0<<8)+(0<<7)+(0<<6)+(0<<5)+(0<<4)+(1<<2)+(1<<0)); // interrupt mode or poll mode
rUFCON0 = ((0<<6)+( 2<<4)+(0<<2)+(0<<1)+(1<<0)); // fifo
rUMCON0 = ((0<<4)+(0<<0)); //disable the modem mode
rUBRDIV0 = ((int)(PCLK/(baud*16))-1); // baud
Com0.Wr = 0; // 初始化自定义缓冲区.
Com0.Rd = 0;
Com0.tSem = OSSemCreate (1); // 建立一个信号量,避免冲突.
Com0.pIn = 0 ;
Com0.pOut= 0 ;
Com0.rSem = OSSemCreate( 1 ) ;
pISR_UART0 =(uint) ISR_Uart0 ;
rINTMOD &= ~(BIT_UART0); // IRQ mode.
rINTMSK &= ~(BIT_UART0); // 开 UART0 发送中断屏蔽位.
rINTSUBMSK &= ~(BIT_SUB_TXD0);
rINTSUBMSK &= ~(BIT_SUB_RXD0) ;
else if( ComNum==1 )
rULCON1 = ((0<<6)+(0<<3)+(0<<2)+(3<<0)); //stop bit and parity bit
rUCON1 = ((0<<10)+(0<<9)+(0<<8)+(0<<7)+(0<<6)+(0<<5)+(0<<4)+(1<<2)+(1<<0)); // interrupt mode or poll mode
rUFCON1 = ((0<<6)+( 2<<4)+(0<<2)+(0<<1)+(1<<0)); // fifo
rUMCON1 = ((0<<4)+(0<<0)); //disable the modem mode
rUBRDIV1 = ((int)(PCLK/(baud*16))-1); // baud
Com1.Wr = 0; // 初始化自定义缓冲区.
Com1.Rd = 0;
Com1.tSem = OSSemCreate (1); // 建立一个信号量,避免冲突.
Com1.pIn = 0 ;
Com1.pOut= 0 ;
Com1.rSem = OSSemCreate( 1 ) ;
pISR_UART1 =(uint) ISR_Uart1 ;
rINTMOD &= ~(BIT_UART1); // IRQ mode.
rINTMSK &= ~(BIT_UART1); // 开 UART0 发送中断屏蔽位.
rINTSUBMSK &= ~(BIT_SUB_TXD1);
rINTSUBMSK &= ~(BIT_SUB_RXD1) ;
}else if( ComNum == 2 )
rULCON2 = ((0<<6)+(0<<3)+(0<<2)+(3<<0)); //stop bit and parity bit
rUCON2 = ((0<<10)+(0<<9)+(0<<8)+(0<<7)+(0<<6)+(0<<5)+(0<<4)+(1<<2)+(1<<0)); // interrupt mode or poll mode
rUFCON2 = ((0<<6)+( 2<<4)+(0<<2)+(0<<1)+(1<<0)); // fifo
rUMCON2 = ((0<<4)+(0<<0)); //disable the modem mode
rUBRDIV2 = ((int)(PCLK/(baud*16))-1); // baud
Com2.Wr = 0; // 初始化自定义缓冲区.
Com2.Rd = 0;
Com2.tSem = OSSemCreate (1); // 建立一个信号量,避免冲突.
Com2.pIn = 0 ;
Com2.pOut= 0 ;
Com2.rSem = OSSemCreate( 1 ) ;
pISR_UART2 =(uint) ISR_Uart2 ;
rINTMOD &= ~(BIT_UART2); // IRQ mode.
rINTMSK &= ~(BIT_UART2); // 开 UART0 发送中断屏蔽位.
rINTSUBMSK &= ~(BIT_SUB_TXD2);
rINTSUBMSK &= ~(BIT_SUB_RXD2) ;
return COM_INIT_OK ;
void Wr_Uart_Buf( UART *ch, uchar data )
UART *p ;
p = ch ;
p->TxBuffer[ p->Wr++] = data ;
if( p->Wr > UART_TX_MAX_SIZE ) p->Wr = 0x00 ;
void StartSend( char ComNum )
UART *ptr ;
uint status ;
uchar *reg ;
switch( ComNum )
case 0 : ptr = &Com0 ; status = rUTRSTAT0&(1<<2 ) ; reg =(uchar *)&rUTXH0; break ;
case 1 : ptr = &Com1 ; status = rUTRSTAT1&(1<<2 ) ; reg =(uchar *)&rUTXH1; break ;
case 2 : ptr = &Com2 ; status = rUTRSTAT2&(1<<2 ) ; reg =(uchar *)&rUTXH2; break ;
default : ptr = &Com0 ; status = rUTRSTAT0&(1<<2 ) ; reg =(uchar *)&rUTXH0; break ;
if( status )
if( ptr->Rd != ptr->Wr )
*reg = ptr->TxBuffer[ptr->Rd++] ;
if( ptr->Rd >= UART_TX_MAX_SIZE ) ptr->Rd = 0x00 ;
//Write Data To Uart Buffer (Tx )
void UartPrintf(UART *ch , const char *format, ...)
#define MAX_TBUF 100 // 注意: 只允许接收改大小的字符串.
char tbuf[MAX_TBUF] = {0, };
va_list v_list;
char *ptr;
uchar err;
UART *p ;
char comnum ;
if( ch == &Com0 ) comnum = 0 ;
else if(ch== &Com1 ) comnum = 1 ;
else if( ch == &Com2 ) comnum = 2 ;
else comnum = 0 ;
p = ch ;
OSSemPend( p->tSem, 0, &err);
va_start( v_list, format); // Initialize variable arguments.
vsprintf( tbuf, format, v_list );
va_end(v_list);
ptr= tbuf;
while(*ptr != '\0')
Wr_Uart_Buf(p, *ptr++ );
StartSend (comnum);
OSSemPost (p->tSem);
#undef MAX_TBUF
void UartSendData( UART *ch, uchar *buf, uint len )
uchar err;
UART *p ;
uint iN ;
char comnum ;
else comnum = 0 ;
p = ch ;
OSSemPend( p->tSem, 0,&err ) ;
for( iN = 0 ; iN < len ; iN ++ )
Wr_Uart_Buf( p, *buf++ ) ;
StartSend( comnum ) ;
OSSemPost( p->tSem ) ;
//serial.h
其中包括 :
串口的类抽象
串口属性参数
#ifdef SERIAL_G
#define serial_ext
#else
#define serial_ext extern
#endif
#define UART_TX_MAX_SIZE 100
#define UART_RX_MAX_SIZE 8192
#define COMM0 &Com0
#define COMM1 &Com1
#define COMM2 &Com2
typedef struct {
unsigned char TxBuffer[UART_TX_MAX_SIZE];
unsigned char Wr;
unsigned char Rd;
OS_EVENT *tSem;
unsigned char RxBuffer[UART_RX_MAX_SIZE] ;
unsigned int pIn ;
unsigned int pOut;
OS_EVENT *rSem ;
} UART ; // Uart Struct
serial_ext UART Com0,Com1,Com2 ; // 2410 Uart0 - Uart2
//Error List
#define COM_BAUD_ERR 0
#define COM_NUM_ERR 1
#define COM_INIT_OK 2
serial_ext void UartPrintf(UART *ch , const char *format, ...) ;
serial_ext char ComInit( uchar omNum, uint baud ) ;
serial_ext void UartSendData( UART *ch, uchar *buf, uint len ) ;
你的问题就在这个源码中
serial.c
Project :
Date : 04-10-10
Funtion : 串口驱动
#define SERIAL_G
Function : Uart ISR
Input : None
Output : None
uchar iN, cnt ;
OSIntEnter();
Com0.Rd = 0x00;
Com0.pIn = 0 ;
OSIntExit();
uchar iN, cnt ;
OSIntEnter();
Com1.Rd = 0x00;
Com1.pIn = 0 ;
OSIntExit();
uchar iN, cnt ;
OSIntEnter();
Com2.Rd = 0x00;
Com2.pIn = 0 ;
OSIntExit();
Function : 串口初始化
baud -- 串口波特率
COM_BAUD_ERR 非法波特率
if(ComNum==0 )
Com0.Rd = 0;
Com0.pIn = 0 ;
Com0.pOut= 0 ;
Com1.Rd = 0;
Com1.pIn = 0 ;
Com1.pOut= 0 ;
Com2.Rd = 0;
Com2.pIn = 0 ;
Com2.pOut= 0 ;
UART *p ;
p = ch ;
UART *ptr ;
uint status ;
uchar *reg ;
switch( ComNum )
if( status )
va_list v_list;
char *ptr;
uchar err;
UART *p ;
char comnum ;
else comnum = 0 ;
p = ch ;
va_end(v_list);
ptr= tbuf;
while(*ptr != '\0')
StartSend (comnum);
#undef MAX_TBUF
uchar err;
UART *p ;
uint iN ;
char comnum ;
else comnum = 0 ;
p = ch ;
//serial.h
其中包括 :
串口的类抽象
串口属性参数
#ifdef SERIAL_G
#define serial_ext
#else
#endif
#define COMM0 &Com0
#define COMM1 &Com1
#define COMM2 &Com2
typedef struct {
unsigned char Wr;
unsigned char Rd;
OS_EVENT *tSem;
unsigned int pIn ;
unsigned int pOut;
OS_EVENT *rSem ;
//Error List
【有奖活动】分享技术经验,兑换京东卡 | |
话不多说,快进群! | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
打赏了!打赏了!打赏了! |
打赏帖 | |
【STM32H7S78-DK评测】LVGL DMA2D/CPU搬运数据至framebuff性能比较被打赏50分 | |
【STM32H7S78-DK评测】LVGL适配之GuiGuider被打赏50分 | |
【STM32H7S78-DK评测】LVGL适配之触摸输入被打赏50分 | |
【STM32H7S78-DK评测】LVGL适配之LCD显示被打赏50分 | |
分享技术笔记六被打赏50分 | |
【开发板试用-NUCLEO-U575ZI-Q】定时器中断实现板载LED点亮被打赏50分 | |
分享技术笔记五被打赏50分 | |
【STM32H7S78-DK评测】LTDC Color Key功能验证被打赏50分 | |
请大声喊出:我要开发板!---使用esp32驱动AD7606C-18被打赏50分 | |
分享技术笔记四被打赏50分 |
