电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【STM32H7S78-DK评测】LVGL适配之触摸输入
2024-09-27 10:20:50   被打赏 50 分(兑奖)     打赏
简介:
我们在上一篇适配了LVGL(8.3.10)显示的功能,还没有对接输入响应,板子上已经集成了一块GT911主控的触摸屏,我们在之前的基础上继续添加触摸屏的输入响应支持。对于触摸的驱动程序我们就不重复造轮子了,直接使用STM32Cube_FW_H7RS_V1.1.0\Drivers\BSP\STM32H7S78-DK 软件包里的驱动即可,把对应的驱动文件加入工程编译。
将上述驱动文件加入编译成功后对应的驱动程序已经ready,我么只要对接到 LVGL touch 设备依赖的驱动函数即可完成对应的适配,主要依赖我们porting的接口如下。
touchpad_init 接口初始化touch对应代码如下:
TS_Init_t hTS;
TS_State_t  TS_State;
/*Initialize your touchpad*/
static void touchpad_init(void)
    uint32_t ts_status = BSP_ERROR_NONE;
    /*Your code comes here*/
    hTS.Width = 800;
    hTS.Height = 480;
    hTS.Orientation = TS_SWAP_NONE;
    hTS.Accuracy = 5;
    /* Touchscreen initialization */
    ts_status = BSP_TS_Init(0, &hTS);
    if(ts_status != BSP_ERROR_NONE)
        printf("touch init failed %d\r\n",ts_status);
    else
        printf("touch init ok\r\n");
touch 按键状态检测接口touchpad_is_pressed
/*Return true is the touchpad is pressed*/
static bool touchpad_is_pressed(void)
    ts_status = BSP_TS_GetState(0, &TS_State);
    return TS_State.TouchDetected ? true : false;
获取touch 位置坐标接口 touchpad_is_pressed
/*Get the x and y coordinates if the touchpad is pressed*/
static void touchpad_get_xy(lv_coord_t * x, lv_coord_t * y)
    (*x) = TS_State.TouchX;
    (*y) = TS_State.TouchY;
    printf("x %d y %d \r\n",TS_State.TouchX,TS_State.TouchY);
touch 初始化接口,向lvgl 注册输入设备
void lv_port_indev_init(void)
     * Here you will find example implementation of input devices supported by LittelvGL:
     *  - Touchpad
     *  - Mouse (with cursor support)
     *  - Keypad (supports GUI usage only with key)
     *  - Encoder (supports GUI usage only with: left, right, push)
     *  - Button (external buttons to press points on the screen)
     *  The `..._read()` function are only examples.
     *  You should shape them according to your hardware
    static lv_indev_drv_t indev_drv;
     * Touchpad
    /*Initialize your touchpad if you have*/
    touchpad_init();
    /*Register a touchpad input device*/
    lv_indev_drv_init(&indev_drv);
    indev_drv.type = LV_INDEV_TYPE_POINTER;
    indev_drv.read_cb = touchpad_read;
    indev_touchpad = lv_indev_drv_register(&indev_drv);
在lvgl task 内添加lv_port_indev_init 调用完成touch 输入设备的注册。
板卡验证,LVGL 已经按照预期的可以响应触摸事件了。
