430149 【求助】用430149做串口通信,老是丢数据
用430149做串口通信,老是丢数据,比如我每次发一页256字节,然后循环,可是在发送的时候发现总有丢失数据的现象,而且都是在每页的中间丢数据,特别郁闷,各位大虾:能否分析一下这是怎么回事呀?一般什么情况会出现丢失数据的现象呢?HELP ME !!!
程序如下:
void RS232_Init(void)
unsigned int i;
P3SEL |= 0x30; // P3.4,5 = USART0 TXD/RXD
P3DIR |= BIT4;
P3DIR &= ~BIT5;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 &= ~XT2OFF; // XT2on
BCSCTL2 |= SELS;
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG)); // OSCFault flag still set?
BCSCTL1 |= SELM_2 + SELS; // MCLK = SMCLK = XT2 (safe)
ME1 |= UTXE0 + URXE0; // Enable USART0 TXD/RXD
UCTL0 |= CHAR; // 8-bit character
UTCTL0 |= SSEL1; // 波特率发生器的时钟 = SMCLK
UBR00 = 0xA0; // 8Mhz/19200 ~ 417
UBR10 = 0x01; //
UMCTL0 = 0x00; // no modulation
UCTL0 &= ~SWRST; // Initialize USART state machine
void T_TXD(unsigned char byte)
while ((IFG1&UTXIFG0) == 0);
TXBUF0 = byte;
//while((UTCTL0&BIT0) == 0);
unsigned char R_RXD(void)
unsigned char byte;
while((IFG1&URXIFG0) == 0);
byte = RXBUF0;
return(byte);
} 答 1: 不明白,大侠为什么不用接收发送中断?149有硬件usart的啊.
#pragma vector=UART0RX_VECTOR
__interrupt void usart0_rx (void)
while (!(IFG1 & UTXIFG0)); // USART0 TX buffer ready?
} 答 2: 这不是完整的程序吧? 答 3: 是不是你用的波特率产生的时钟有问题,好像要算调整部分的吧,因为你的波特率8M是得不到整数的吧.
程序如下:
unsigned int i;
P3DIR |= BIT4;
P3DIR &= ~BIT5;
BCSCTL2 |= SELS;
do
UBR10 = 0x01; //
TXBUF0 = byte;
unsigned char byte;
byte = RXBUF0;
return(byte);
