430 430引脚的输入输出电压、电流是多少呀?
MSP430F43x,MSP430F44x引脚电压(相对VSS)
1、运行时(AVCC = DVCC2 = VCC)
MSP430F43x,MSP430F44x VCC=1.8 - 3.6 V
2、运行时(SVS 打开) (VCC = DVCC = VCC)
MSP430F43x,MSP430F44x VCC=2 - 3.6 V
3、Flash编程时(AVCC = DVCC2 = VCC)
MSP430F43x,MSP430F44x VCC=2.7 - 3.6 V
4、低电平输入电压 (TCK, TMS, TDI, RST/NMI,不包括 Xin, Xout)
VIL=VSS - (VSS + 0.6 V) (VCC = 2.2 V - 3 V时)
5、高电平输入电压 (TCK, TMS, TDI, RST/NMI,不包括 Xin, Xout)
VIH=0.8 × VCC - VCC(VCC = 2.2 V - 3 V时)
6、Xin 及 Xout脚的输入低电平
VIL=VSS - 0.2 × VCC(VCC = 2.2 V - 3 V时)
7、Xin 及 Xout脚的输入高电平
VIH= 0.8 × VCC - VCC(VCC = 2.2 V - 3 V时) 答 1: MSP43x、44x I/O电流(设计极限):拉电流6mA,灌电流2mA
6、Xin 及 Xout脚的输入低电平
7、Xin 及 Xout脚的输入高电平
