MSP430 MSP430的代码指针怎么使用?
定义了一个常量结构,想用指针的方式使用,不知如何使用?C51中可以定义指针的存储器类型,而MSP的C430中却没有!请高手赐教!谢谢!
答 1:
const uchar string[]={"abcdefghijk\n"};
uchar *pointer;
pointer=&string[]; 答 2: 在C51中:
1)结构定义:
typedef struct _USB_DEVICE_DESCRIPTOR {
UCHAR bLength;
UCHAR bDescriptorType;
USHORT bcdUSB;
UCHAR bDeviceClass;
UCHAR bDeviceSubClass;
UCHAR bDeviceProtocol;
UCHAR bMaxPacketSize0;
USHORT idVendor;
USHORT idProduct;
USHORT bcdDevice;
UCHAR iManufacturer;
UCHAR iProduct;
UCHAR iSerialNumber;
UCHAR bNumConfigurations;
} USB_DEVICE_DESCRIPTOR, *PUSB_DEVICE_DESCRIPTOR;
结构常量:(里边全部是常量)
code USB_DEVICE_DESCRIPTOR DeviceDescr =
sizeof(USB_DEVICE_DESCRIPTOR),
USB_DEVICE_DESCRIPTOR_TYPE,
SWAP(0x0110),
USB_CLASS_CODE_TEST_CLASS_DEVICE,
0, 0,
EP0_PACKET_SIZE,
SWAP(0x0471),
SWAP(0x0666),
SWAP(0x0100),
0, 0, 0,
1
函数定义:
//发送端点号1建立代码
void code_transmit(unsigned char code * pRomData, unsigned short len)
ControlData.wCount = 0;
if(ControlData.wLength > len) ControlData.wLength = len;
ControlData.pData = pRomData;
D12_WriteEndpoint(1, EP0_PACKET_SIZE, ControlData.pData);//发送16字节数据
ControlData.wCount += EP0_PACKET_SIZE;
函数调用:
code_transmit((unsigned char code *)&DeviceDescr, sizeof(USB_DEVICE_DESCRIPTOR));
请问在MSP的C430中怎么移植?我将以上代码的code改为const编译是通不过的!谢谢赐教!
uchar *pointer;
1)结构定义:
UCHAR bLength;
USHORT bcdUSB;
UCHAR bDeviceClass;
USHORT idVendor;
USHORT idProduct;
USHORT bcdDevice;
UCHAR iProduct;
结构常量:(里边全部是常量)
SWAP(0x0110),
0, 0,
EP0_PACKET_SIZE,
SWAP(0x0471),
SWAP(0x0666),
SWAP(0x0100),
0, 0, 0,
1
函数定义:
//发送端点号1建立代码
函数调用:
| 2026年“我要开发板活动”第三季,开始了! | |
