blackfin,MDMA 请教:blackfin 同时开启两个MDMA ,产生冲突,为什么?
我在算法中同时开启两个片外SDRAM到L1SRAM的内存DMA,算法就出错;单独开启就正常,请问哪位大侠能帮助解决这个问题?
答 1:
补充对不起,我用的是blackfin561,DMA工作模式为FLOW = 7 (Descriptor List Large):谢谢!
答 2:
代码如下:#include "mpeg4_new_algorithm.h"
////DMAx_CONFIG, MDMA_yy_CONFIG Masks
/*#define DMAEN 0x00000001 // Channel Enable
#define WNR 0x00000002 // Channel Direction (W/R*)
#define WDSIZE_8 0x00000000 // Word Size 8 bits
#define WDSIZE_16 0x00000004 // Word Size 16 bits
#define WDSIZE_32 0x00000008 // Word Size 32 bits
#define DMA2D 0x00000010 // 2D/1D* Mode
#define RESTART 0x00000020 // Restart
#define DI_SEL 0x00000040 // Data Interrupt Select
#define DI_EN 0x00000080 // Data Interrupt Enable
#define NDSIZE 0x00000900 // Next Descriptor Size
#define FLOW 0x00007000 // Flow Control*/
//DMA1_S_CONFIG = FLOW|NDSIZE|DMA2D|DMAEN|WDSIZE_8 即0x7911
//DMA2_D_CONFIG = FLOW|NDSIZE|DMA2D|DMAEN|WDSIZE_8|WNR即0x7913
//y:16*16; u:8*8; v:8*8 单位byte
section("L1_data_ds") tDMA_descriptor tDescSrcy= {&tDescSrcu,0,0x7911,16,1,16,1,0};
section("L1_data_ds") tDMA_descriptor tDescSrcu= {&tDescSrcv,0,0x7911,8,1,8,1,0};
section("L1_data_ds") tDMA_descriptor tDescSrcv= {&tDescSrcdummy,0,0x7911,8,1,8,1,0};
section("L1_data_ds") tDMA_descriptor tDescSrcdummy= {&tDescSrcy,0,0x0911,8,1,8,1,0};
section("L1_data_ds") tDMA_descriptor tDescDsty= {&tDescDstu,0,0x7913,16,1,16,1,0};
section("L1_data_ds") tDMA_descriptor tDescDstu= {&tDescDstv,0,0x7913,8 ,1,8 ,1,0};
section("L1_data_ds") tDMA_descriptor tDescDstv= {&tDescDstdummy,0,0x7913,8 ,1,8 ,1,0};
section("L1_data_ds") tDMA_descriptor tDescDstdummy= {&tDescDsty,0,0x0913,8 ,1,8 ,1,0};
//y:48*48; u:24*24; v:24*24 单位byte
section("L1_data_ds") tDMA_descriptor tDescRefSrcy= {&tDescRefSrcu,0,0x7911,48,1,48,1,0};
section("L1_data_ds") tDMA_descriptor tDescRefSrcu= {&tDescRefSrcv,0,0x7911,24,1,24,1,0};
section("L1_data_ds") tDMA_descriptor tDescRefSrcv= {&tDescRefSrcdummy,0,0x7911,24,1,24,1,0};
section("L1_data_ds") tDMA_descriptor tDescRefSrcdummy= {&tDescRefSrcy,0,0x0910,8,1,8,1,0};
section("L1_data_ds") tDMA_descriptor tDescRefDsty= {&tDescRefDstu,0,0x7913,48,1,48,1,0};
section("L1_data_ds") tDMA_descriptor tDescRefDstu= {&tDescRefDstv,0,0x7913,24 ,1,24 ,1,0};
section("L1_data_ds") tDMA_descriptor tDescRefDstv= {&tDescRefDstdummy,0,0x7913,24 ,1,24 ,1,0};
section("L1_data_ds") tDMA_descriptor tDescRefDstdummy= {&tDescRefDsty,0,0x0912,8 ,1,8 ,1,0};
#define REFDMA
#define INDMA
//enable to global value , to convinient the function
section("L1_data_b")unsigned char *pSearchWin; //search window pointer
section("L1_data_b") MACROBLOCK *pCurrMB, *pTEMPMB;
section("L1_data_b") int iSearchRange, bIntra, flag_mbbuf = 0, is_full_ref;
section("L1_data_b") unsigned char *mbbuf_in;
section("L1_data_b") int OffsetY ;
section("L1_data_b") int OffsetUV ;
section("L1_data_b") int sc, scuv, sr, sruv;
section("L1_data_b") unsigned char *pppdy1 ;
section("L1_data_b") unsigned char *pppdy2 ;
section("L1_data_b") unsigned char *pppdy3 ;
section("L1_data_b") unsigned char *pppdy4 ;
section("L1_data_b") unsigned char *pppdu1 ;
section("L1_data_b") unsigned char *pppdu2 ;
section("L1_data_b") unsigned char *pppdu3 ;
section("L1_data_b") unsigned char *pppdu4 ;
section("L1_data_b") unsigned char *pppdv1 ;
section("L1_data_b") unsigned char *pppdv2 ;
section("L1_data_b") unsigned char *pppdv3 ;
section("L1_data_b") unsigned char *pppdv4 ;
section("L1_data_b") unsigned char* ppsry1;
section("L1_data_b") unsigned char* ppsry2;
section("L1_data_b") unsigned char* ppsry3;
section("L1_data_b") unsigned char* ppsry4;
section("L1_data_b") unsigned char* ppsru1;
section("L1_data_b") unsigned char* ppsru2;
section("L1_data_b") unsigned char* ppsru3;
section("L1_data_b") unsigned char* ppsru4;
section("L1_data_b") unsigned char* ppsrv1;
section("L1_data_b") unsigned char* ppsrv2;
section("L1_data_b") unsigned char* ppsrv3;
section("L1_data_b") unsigned char* ppsrv4;
section("L1_data_b") unsigned char* pppdy4last;
section("L1_data_b") unsigned char* pppdu4last;
section("L1_data_b") unsigned char* pppdv4last;
section("L1_data_b") unsigned char* psrynext;
section("L1_data_b") unsigned char* psrunext;
section("L1_data_b") unsigned char* psrvnext;
/// DMA descriptor lists
extern tDMA_descriptor tDescSrcy;
extern tDMA_descriptor tDescSrcu;
extern tDMA_descriptor tDescSrcv;
extern tDMA_descriptor tDescDsty;
extern tDMA_descriptor tDescDstu;
extern tDMA_descriptor tDescDstv;
#pragma optimize_for_speed
section("L1_code") int FrameCodeP_tss(Encoder * pEnc,
Bitstream * bs,
uint32_t * pBits,
bool vol_header,
uint8_t** pMbCurAndRefWinPara, //接口控制
MACROBLOCK_CUR* pMbCurParamter ) // *pMbCur[2] peter add interface
unsigned char* pWinY;
unsigned char* pWinU;
unsigned char* pWinV;
tDescSrcy.YModify = (pEnc->mbParam.edged_width - 16) +1;
tDescSrcu.YModify = ((pEnc->mbParam.edged_width>>1) - 8) +1;
tDescSrcv.YModify = ((pEnc->mbParam.edged_width>>1) - 8) +1;
#ifdef REFDMA
tDescRefSrcy.YModify = (pEnc->mbParam.edged_width - 48) +1;
tDescRefSrcu.YModify = ((pEnc->mbParam.edged_width>>1) - 24) +1;
tDescRefSrcv.YModify = ((pEnc->mbParam.edged_width>>1) - 24) +1;
#endif //REFDMA
psry = pEnc->reference->image.y - (pEnc->mbParam.edged_width*16+16);
psru = pEnc->reference->image.u - ((pEnc->mbParam.edged_width>>1)*8+8);
psrv = pEnc->reference->image.v - ((pEnc->mbParam.edged_width>>1)*8+8);
pdy = pEnc->current->image.y;
pdu = pEnc->current->image.u;
pdv = pEnc->current->image.v;
pEnc->mbParam.m_rounding_type = 1 - pEnc->mbParam.m_rounding_type;
pEnc->current->rounding_type = pEnc->mbParam.m_rounding_type;
pEnc->current->fcode = pEnc->mbParam.m_fcode;
pEnc->current->coding_type = P_VOP;
BitstreamPutBits(bs, 0, 32);
BitstreamWriteVopHeader(bs, &pEnc->mbParam, pEnc->current, 1);
*pBits = BitstreamPos(bs);
OffsetY = 16*pEnc->mbParam.edged_width - pEnc->mbParam.width + 16 ;
OffsetUV = (pEnc->mbParam.edged_width<<2) - (pEnc->mbParam.width>>1) + 8 ;
int x_index;// x index
int nLoop = pEnc->mbParam.mb_width>>2; // 22
int nLoopRemaining = (pEnc->mbParam.mb_width)%4; // 22
int x, y ;
int x1, x2, x3, x4;
int curr = 0;
int next = 0;
//填满缓冲队列
#ifdef REFDMA//refdma
Lib_CoreWaittingForMem_0();
*pMDMA2_S0_CONFIG = 0;
*pMDMA2_D0_CONFIG = 0;
tDescRefSrcy.start_address = psry;
tDescRefSrcu.start_address = psru;
tDescRefSrcv.start_address = psrv;
tDescRefDsty.start_address = &refwin1[0];
tDescRefDstu.start_address = (&refwin1[0] + 48*48);
tDescRefDstv.start_address = (&refwin1[0] +48*48+24*24);
*pMDMA2_S0_NEXT_DESC_PTR = &tDescRefSrcy;
//Dst
*pMDMA2_D0_NEXT_DESC_PTR = &tDescRefDsty;
ssync();
//config
*pMDMA2_S0_CONFIG = 0x7911;
*pMDMA2_D0_CONFIG = 0x7913;
#endif
#ifdef INDMA
Lib_CoreWaittingForMem_1();
*pMDMA1_S1_CONFIG = 0;
*pMDMA1_D1_CONFIG = 0;
tDescSrcy.start_address = pdy;
tDescSrcu.start_address = pdu;
tDescSrcv.start_address = pdv;
tDescDsty.start_address = &MB_curr1[0];
tDescDstu.start_address = (&MB_curr1[0] + 16*16);
tDescDstv.start_address = (&MB_curr1[0] +16*16+8*8);
*pMDMA1_S1_NEXT_DESC_PTR = &tDescSrcy;
//Dst
*pMDMA1_D1_NEXT_DESC_PTR = &tDescDsty;
ssync();
//config
*pMDMA1_S1_CONFIG = 0x7911;
*pMDMA1_D1_CONFIG = 0x7913;
#endif
#ifdef REFDMA
tDescRefSrcy.start_address = psry +48;
tDescRefSrcu.start_address = psru +24;
tDescRefSrcv.start_address = psrv +24;
tDescRefDsty.start_address = &refwin2[0];
tDescRefDstu.start_address = (&refwin2[0] + 48*48);
tDescRefDstv.start_address = (&refwin2[0] +48*48+24*24);
ssync();
//config
#endif //REFDMA
psrynext = psry ;
psrunext = psru ;
psrvnext = psrv ;
//编码循环
for (y = 0; y < pEnc->mbParam.mb_height; y++)
x = 0;
for( x_index = 0; x_index < nLoop; x_index++)
///////////////////////////1111111111111111///////////////
ppsry1 = psry ;
ppsru1 = psru ;
ppsrv1 = psrv ;
pWinY = psry + 3*16;
pWinU = psru + 3*8;
pWinV = psrv + 3*8;
pppdy1 = pdy ;
pppdu1 = pdu ;
pppdv1 = pdv ;
pppdy2 = pdy + 16;
pppdu2 = pdu + 8;
pppdv2 = pdv + 8;
pppdy3 = pdy + 16*2;
pppdu3 = pdu + 8*2;
pppdv3 = pdv + 8*2;
pppdy4 = pdy + 16*3;
pppdu4 = pdu + 8*3;
pppdv4 = pdv + 8*3;
curr = curr%2;
next = (curr +1)%2;
#ifdef REFDMA
if((x + 4)>= pEnc->mbParam.mb_width)
psrynext += 16*3+OffsetY;
psrunext += 8*3+OffsetUV;
psrvnext += 8*3+OffsetUV;
else
psrunext += 8<<2;
psrynext += 16<<2;
psrvnext += 8<<2;
tDescRefSrcy.start_address = psrynext;
tDescRefSrcu.start_address = psrunext;
tDescRefSrcv.start_address = psrvnext;
tDescRefDsty.start_address = &refwin1[0+ next*3456];
tDescRefDstu.start_address = (&refwin1[0+ next*3456] + 48*48);
tDescRefDstv.start_address = (&refwin1[0+ next*3456] +48*48+24*24);
//config
#else
copyRefWindows(ppsry1, ppsru1, ppsrv1, &refwin1[0+curr*3456], 1); //将从图像上取48×48的搜索窗数据
copyRefWindows(pWinY, pWinU, pWinV, &refwin2[0+curr*3456], 1);//将从图像上取48×48的搜索窗数据
#endif //REFDMA
#ifdef INDMA
tDescSrcy.start_address = pppdy2;
tDescSrcu.start_address = pppdu2;
tDescSrcv.start_address = pppdv2;
tDescDsty.start_address = &MB_curr2[0];
tDescDstu.start_address = (&MB_curr2[0] + 16*16);
tDescDstv.start_address = (&MB_curr2[0] +16*16+8*8);
ssync();
//config
#else
copyMB(pppdy1 , pppdu1 , pppdv1 , &MB_curr1[0] );//从当前图像上取一个16×16的数据
copyMB(pppdy2 , pppdu2 , pppdv2 , &MB_curr2[0] );
#endif
x1 = x;
pEnc->target_MB = &MB_curr1[0];
refwin_curr = &refwin1[0 +curr*3456];
mbbuf_in = &MB_curr1[0];
//更新
coreP_frame_coding(pEnc,bs ,x ,y ,pMbCurParamter) ;
//coding to the outer
pFrameCoding_called(pEnc,bs, x1, y,pMbCurParamter);
x++;
///////////////////////////2222222222222222///////////////
x2 = x;
#ifdef INDMA
tDescSrcy.start_address = pppdy3;
tDescSrcu.start_address = pppdu3;
tDescSrcv.start_address = pppdv3;
tDescDsty.start_address = &MB_curr3[0];
tDescDstu.start_address = (&MB_curr3[0] + 16*16);
tDescDstv.start_address = (&MB_curr3[0] +16*16+8*8);
ssync();
//config
#else
copyMB(pppdy3 , pppdu3 , pppdv3 , &MB_curr3[0] );
#endif
pEnc->target_MB = &MB_curr2[0];
refwin_curr = &refwin1[0+curr*3456];
mbbuf_in = &MB_curr2[0];
copy_ref23win(refwin_curr);
copy_win2win(refwin_curr, &refwin2[0+curr*3456], 0);
copyMBToImage(&MB_curr1[0], pppdy1, pppdu1, pppdv1);
bs ,
x ,
y ,
pMbCurParamter) ;
pFrameCoding_called(pEnc,bs, x2, y, pMbCurParamter);
x++;
///////////////////////////3333333333333333//////////////
x3 = x;
#ifdef INDMA
tDescSrcy.start_address = pppdy4;
tDescSrcu.start_address = pppdu4;
tDescSrcv.start_address = pppdv4;
tDescDsty.start_address = &MB_curr4[0];
tDescDstu.start_address = (&MB_curr4[0] + 16*16);
tDescDstv.start_address = (&MB_curr4[0] +16*16+8*8);
ssync();
//config
#else
copyMB(pppdy4 , pppdu4 , pppdv4 , &MB_curr4[0] );
#endif
pEnc->target_MB = &MB_curr3[0];
mbbuf_in = &MB_curr3[0];
copy_win2win(refwin_curr, &refwin2[0+curr*3456], 1);
#ifdef REFDMA
Lib_CoreWaittingForMem_0(); //
tDescRefSrcy.start_address = psrynext +48;
tDescRefSrcu.start_address = psrunext +24;
tDescRefSrcv.start_address = psrvnext +24;
tDescRefDsty.start_address = &refwin2[0+next*3456];
tDescRefDstu.start_address = (&refwin2[0+next*3456] + 48*48);
tDescRefDstv.start_address = (&refwin2[0+next*3456] +48*48+24*24);
//config
#endif
copyMBToImage(&MB_curr2[0], pppdy2, pppdu2, pppdv2);
bs ,
x ,
y ,
pMbCurParamter) ;
pFrameCoding_called(pEnc,bs, x3, y,pMbCurParamter);
x++;
///////////////////////////44444444444444444///////////////
x4 = x;
pEnc->target_MB = &MB_curr4[0];
refwin_curr = &refwin2[0+curr*3456];
mbbuf_in = &MB_curr4[0];
bs ,
x ,
y ,
pMbCurParamter) ;
#ifdef INDMA
ssync();
//config
#endif
copyMBToImage(&MB_curr3[0], pppdy3, pppdu3, pppdv3);
pFrameCoding_called(pEnc,bs, x4, y,pMbCurParamter);
//copy to outer
copyMBToImage(&MB_curr4[0], pppdy4, pppdu4, pppdv4);
x++;
pppdy4last = pppdy4;
pppdu4last = pppdu4;
pppdv4last = pppdv4;
curr ++;
////////////outer operation////////////////////////////////////
if(nLoopRemaining>0)
pppdy1 = pdy ;
pppdu1 = pdu ;
pppdv1 = pdv ;
ppsry1 = psry ;
ppsru1 = psru ;
ppsrv1 = psrv ;
/////////////////add new///////////////////
pppdy2 = pdy + 16;
pppdu2 = pdu + 8;
pppdv2 = pdv + 8;
ppsry2 = psry + 16*3;
ppsru2 = psru + 8*3;
ppsrv2 = psrv + 8*3;
curr = curr%2;
next = (curr +1)%2;
#ifdef REFDMA
if((x + 2)>= pEnc->mbParam.mb_width)
psrynext += 16+OffsetY;
psrunext += 8+OffsetUV;
psrvnext += 8+OffsetUV;
else
psrunext += 8<<1;
psrynext += 16<<1;
psrvnext += 8<<1;
tDescRefDsty.start_address = &refwin1[next*3456];
tDescRefDstu.start_address = (&refwin1[next*3456] + 48*48);
tDescRefDstv.start_address = (&refwin1[next*3456] +48*48+24*24);
//Dst
ssync();
//config
#else
copyRefWindows(ppsry1, ppsru1, ppsrv1, &refwin1[+curr*3456], 1);
#endif
copyRefWindowsLeft13(ppsry2, ppsru2, ppsrv2, &refwin2[+curr*3456]);
#ifdef INDMA
ssync();
//config
#else
#endif //////////////////////////////////////////
x1 = x;
refwin_curr = &refwin1[+curr*3456];
bs ,
x ,
y ,
pMbCurParamter) ;
pFrameCoding_called(pEnc,bs, x1, y, pMbCurParamter);
copyMBToImage(pEnc->target_MB, pppdy1, pppdu1, pppdv1);
x++;
#ifdef REFDMA
tDescRefDsty.start_address = &refwin2[next*3456];
tDescRefDstu.start_address = (&refwin2[next*3456] + 48*48);
tDescRefDstv.start_address = (&refwin2[next*3456] +48*48+24*24);
ssync();
//config
#endif //REFDMA
x2 = x;
// copy_23refHor(refwin_curr);
// copyWinToWin(refwin_curr, &refwin2[+curr*3456], 0);
copy_win2win(refwin_curr, &refwin2[+curr*3456], 0);
bs ,
x ,
y ,
pMbCurParamter) ;
#ifdef INDMA
ssync();
//config
#endif
pFrameCoding_called(pEnc,bs, x2, y,pMbCurParamter);
x++;
curr ++;
}// for y
.section L1_code;
.align 4;
_Lib_CoreWaittingForMem_0 :
[--sp] = r0;
[--sp] = r1;
[--sp] = r2;
[--sp] = p0;
p0.l = lo(MDMA2_D0_IRQ_STATUS ); // MDMA1_D1_IRQ_STATUS // MDMA_D1_IRQ_STATUS 532
p0.h = hi(MDMA2_D0_IRQ_STATUS);
r1 = 0;
r2.l = 0xB000;
r2.h = 0x0;
DMARUNNING2:
r1 += 1;
cc = r2 < r1;
if cc jump ERROR2;
r0.l = w[p0];
cc = bittst(r0, 3);
if cc jump DMARUNNING2;
END2:
p0 = [sp++];
r2 = [sp++];
r1 = [sp++];
r0 = [sp++];
rts;
ERROR2:
p0.l = lo(MDMA2_S0_IRQ_STATUS);
p0.h = hi(MDMA2_S0_IRQ_STATUS);
r0.l = 0x3;
w[p0] = r0.l;
r0.l = 0x3;
w[p0] = r0.l;
p0.l = lo(MDMA2_S0_CONFIG);
p0.h = hi(MDMA2_S0_CONFIG);
r0 = 0;
w[p0] = r0;
p0.l = lo(MDMA2_D0_CONFIG);
p0.h = hi(MDMA2_D0_CONFIG);
r0 = 0;
w[p0] = r0;
jump END2;
_Lib_CoreWaittingForMem_0.end:
nop;
.section L1_code;
.align 4;
_Lib_CoreWaittingForMem_1 :
[--sp] = r0;
[--sp] = r1;
[--sp] = r2;
[--sp] = p0;
p0.l = lo(MDMA1_D1_IRQ_STATUS ); // MDMA1_D1_IRQ_STATUS // MDMA_D1_IRQ_STATUS 532
p0.h = hi(MDMA1_D1_IRQ_STATUS);
r1 = 0;
r2.l = 0xB000;
r2.h = 0x0;
DMARUNNING:
r1 += 1;
cc = r2 < r1;
if cc jump ERROR;
r0.l = w[p0];
cc = bittst(r0, 3);
if cc jump DMARUNNING;
END:
p0 = [sp++];
r2 = [sp++];
r1 = [sp++];
r0 = [sp++];
rts;
ERROR:
p0.l = lo(MDMA1_S1_IRQ_STATUS);
p0.h = hi(MDMA1_S1_IRQ_STATUS);
r0.l = 0x3;
w[p0] = r0.l;
r0.l = 0x3;
w[p0] = r0.l;
p0.l = lo(MDMA1_S1_CONFIG);
p0.h = hi(MDMA1_S1_CONFIG);
r0 = 0;
w[p0] = r0;
p0.l = lo(MDMA1_D1_CONFIG);
p0.h = hi(MDMA1_D1_CONFIG);
r0 = 0;
w[p0] = r0;
jump END;
_Lib_CoreWaittingForMem_1.end:
nop;
#define REFDMA
#define INDMA
Bitstream * bs,
uint32_t * pBits,
bool vol_header,
#ifdef REFDMA
#endif //REFDMA
int x, y ;
int x1, x2, x3, x4;
int curr = 0;
int next = 0;
//填满缓冲队列
//Dst
ssync();
//config
#endif
#ifdef INDMA
//Dst
ssync();
//config
#endif
#ifdef REFDMA
ssync();
//config
#endif //REFDMA
psrynext = psry ;
psrunext = psru ;
psrvnext = psrv ;
//编码循环
x = 0;
ppsry1 = psry ;
ppsru1 = psru ;
ppsrv1 = psrv ;
pWinU = psru + 3*8;
pWinV = psrv + 3*8;
pppdy1 = pdy ;
pppdu1 = pdu ;
pppdv1 = pdv ;
pppdy2 = pdy + 16;
pppdu2 = pdu + 8;
pppdv2 = pdv + 8;
pppdu3 = pdu + 8*2;
pppdv3 = pdv + 8*2;
pppdu4 = pdu + 8*3;
pppdv4 = pdv + 8*3;
curr = curr%2;
next = (curr +1)%2;
#ifdef REFDMA
else
psrunext += 8<<2;
psrynext += 16<<2;
psrvnext += 8<<2;
//config
#else
#endif //REFDMA
#ifdef INDMA
ssync();
//config
#else
#endif
x1 = x;
//更新
x++;
x2 = x;
#ifdef INDMA
ssync();
//config
#else
#endif
bs ,
x ,
y ,
pMbCurParamter) ;
x++;
x3 = x;
#ifdef INDMA
ssync();
//config
#else
#endif
#ifdef REFDMA
//config
#endif
bs ,
x ,
y ,
pMbCurParamter) ;
x++;
x4 = x;
bs ,
x ,
y ,
pMbCurParamter) ;
#ifdef INDMA
ssync();
//config
#endif
//copy to outer
x++;
curr ++;
pppdy1 = pdy ;
pppdu1 = pdu ;
pppdv1 = pdv ;
ppsry1 = psry ;
ppsru1 = psru ;
ppsrv1 = psrv ;
pppdy2 = pdy + 16;
pppdu2 = pdu + 8;
pppdv2 = pdv + 8;
curr = curr%2;
next = (curr +1)%2;
#ifdef REFDMA
else
psrunext += 8<<1;
psrynext += 16<<1;
psrvnext += 8<<1;
//Dst
ssync();
//config
#else
#endif
#ifdef INDMA
ssync();
//config
#else
x1 = x;
bs ,
x ,
y ,
pMbCurParamter) ;
x++;
#ifdef REFDMA
ssync();
//config
#endif //REFDMA
x2 = x;
bs ,
x ,
y ,
pMbCurParamter) ;
#ifdef INDMA
ssync();
//config
#endif
x++;
curr ++;
}// for y
.section L1_code;
.align 4;
[--sp] = r0;
[--sp] = r1;
[--sp] = r2;
[--sp] = p0;
r1 = 0;
r2.l = 0xB000;
r2.h = 0x0;
DMARUNNING2:
r1 += 1;
cc = r2 < r1;
if cc jump ERROR2;
r0.l = w[p0];
cc = bittst(r0, 3);
END2:
p0 = [sp++];
r2 = [sp++];
r1 = [sp++];
r0 = [sp++];
rts;
ERROR2:
r0.l = 0x3;
w[p0] = r0.l;
r0.l = 0x3;
w[p0] = r0.l;
r0 = 0;
w[p0] = r0;
r0 = 0;
w[p0] = r0;
jump END2;
nop;
.section L1_code;
.align 4;
[--sp] = r0;
[--sp] = r1;
[--sp] = r2;
[--sp] = p0;
r1 = 0;
r2.l = 0xB000;
r2.h = 0x0;
DMARUNNING:
r1 += 1;
cc = r2 < r1;
if cc jump ERROR;
r0.l = w[p0];
cc = bittst(r0, 3);
END:
p0 = [sp++];
r2 = [sp++];
r1 = [sp++];
r0 = [sp++];
rts;
ERROR:
r0.l = 0x3;
w[p0] = r0.l;
r0.l = 0x3;
w[p0] = r0.l;
r0 = 0;
w[p0] = r0;
r0 = 0;
w[p0] = r0;
jump END;
nop;
| 为遥控小车巧添功能被打赏¥26元 | |
