89c51,P1,undefined,identifier 89c51怎么回事呀? 'P1_0': undefined identifier
TWOLED.C(9): error C202: 'P1_0': undefined identifier
请教各位大虾,怎么定义这些端口呢?
本人菜鸟,请赐教或者指点一下方向,找原因找了两天了 答 1: p1.1写成p1.1也不对,究竟怎么表达呀?是不是要改startup.a51的内容呀?怎么改? 答 2: 看一下头包含文件看一下头包含文件里面怎么写的,实在不行自己定义一个地址不就完了。 答 3: 应该是P1^1 答 4: 谢谢各位谢谢各位,按 庄庄 说的作了,解决。再次感谢。
请问 tianbi 怎么改头包文件?希望详细说说,可STARTUP.A51里面没有口子的事,拜托了!兄弟是菜鸟。 答 5: STARTUP.A51的文件内容$NOMOD51
; This file is part of the C51 Compiler package
; Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
; STARTUP.A51: This code is executed after processor reset.
; To translate this file use A51 with the following invocation:
; A51 STARTUP.A51
; To link the modified STARTUP.OBJ file to your application use the following
; BL51 invocation:
; BL51 <your object file list>, STARTUP.OBJ <controls>
; User-defined Power-On Initialization of Memory
; With the following EQU statements the initialization of memory
; at processor reset CAN be defined:
; ; the absolute start-address of IDATA memory is always 0
IDATALEN EQU 80H ; the length of IDATA memory in bytes.
XDATASTART EQU 0H ; the absolute start-address of XDATA memory
XDATALEN EQU 0H ; the length of XDATA memory in bytes.
PDATASTART EQU 0H ; the absolute start-address of PDATA memory
PDATALEN EQU 0H ; the length of PDATA memory in bytes.
; Notes: The IDATA space overlaps physically the DATA and BIT areas of the
; 8051 CPU. At minimum the memory space occupied from the C51
; run-time routines must be set to zero.
; Reentrant Stack Initilization
; The following EQU statements define the stack pointer for reentrant
; functions and initialized it:
; Stack Space for reentrant functions in the SMALL model.
IBPSTACK EQU 0 ; set to 1 if small reentrant is used.
IBPSTACKTOP EQU 0FFH+1 ; set top of stack to highest location+1.
; Stack Space for reentrant functions in the LARGE model.
XBPSTACK EQU 0 ; set to 1 if large reentrant is used.
XBPSTACKTOP EQU 0FFFFH+1; set top of stack to highest location+1.
; Stack Space for reentrant functions in the COMPACT model.
PBPSTACK EQU 0 ; set to 1 if compact reentrant is used.
PBPSTACKTOP EQU 0FFFFH+1; set top of stack to highest location+1.
; Page Definition for Using the Compact Model with 64 KByte xdata RAM
; The following EQU statements define the xdata page used for pdata
; variables. The EQU PPAGE must conform with the PPAGE control used
; in the linker invocation.
PPAGEENABLE EQU 0 ; set to 1 if pdata object are used.
PPAGE EQU 0 ; define PPAGE number.
PPAGE_SFR DATA 0A0H ; SFR that supplies uppermost address byte
; (most 8051 variants use P2 as uppermost address byte)
; Standard SFR Symbols
ACC DATA 0E0H
B DATA 0F0H
SP DATA 81H
DPL DATA 82H
DPH DATA 83H
NAME ?C_STARTUP
?C_C51STARTUP SEGMENT CODE
?STACK SEGMENT IDATA
RSEG ?STACK
DS 1
EXTRN CODE (?C_START)
PUBLIC ?C_STARTUP
CSEG AT 0
?C_STARTUP: LJMP STARTUP1
RSEG ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
MOV R0,#IDATALEN - 1
CLR A
IDATALOOP: MOV @R0,A
DJNZ R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
MOV DPTR,#XDATASTART
MOV R7,#LOW (XDATALEN)
IF (LOW (XDATALEN)) <> 0
MOV R6,#(HIGH (XDATALEN)) +1
ELSE
MOV R6,#HIGH (XDATALEN)
ENDIF
CLR A
XDATALOOP: MOVX @DPTR,A
INC DPTR
DJNZ R7,XDATALOOP
DJNZ R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
MOV PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
MOV R0,#LOW (PDATASTART)
MOV R7,#LOW (PDATALEN)
CLR A
PDATALOOP: MOVX @R0,A
INC R0
DJNZ R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
EXTRN DATA (?C_IBP)
MOV ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
EXTRN DATA (?C_XBP)
MOV ?C_XBP,#HIGH XBPSTACKTOP
MOV ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
EXTRN DATA (?C_PBP)
MOV ?C_PBP,#LOW PBPSTACKTOP
ENDIF
MOV SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
; EXTRN CODE (?B_SWITCH0)
; CALL ?B_SWITCH0 ; init bank mechanism to code bank 0
LJMP ?C_START
END
答 6: 回复多看书呀, 答 7: 直接把P1.1的地址写出来就行了.
请教各位大虾,怎么定义这些端口呢?
; A51 STARTUP.A51
; BL51 invocation:
ACC DATA 0E0H
B DATA 0F0H
SP DATA 81H
DPL DATA 82H
DPH DATA 83H
NAME ?C_STARTUP
RSEG ?STACK
DS 1
PUBLIC ?C_STARTUP
CSEG AT 0
RSEG ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
CLR A
DJNZ R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
ELSE
ENDIF
CLR A
INC DPTR
DJNZ R7,XDATALOOP
DJNZ R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
ENDIF
IF PDATALEN <> 0
CLR A
INC R0
DJNZ R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
EXTRN DATA (?C_IBP)
ENDIF
IF XBPSTACK <> 0
EXTRN DATA (?C_XBP)
ENDIF
IF PBPSTACK <> 0
EXTRN DATA (?C_PBP)
ENDIF
MOV SP,#?STACK-1
LJMP ?C_START
END
