答 1:
keil 51中嵌asm文件 链接错误;完成一个显示1234的调试程序
;接口函数定义
PUBLIC START ;启动MP3
;程序数据段定义
PR?XXG SEGMENT CODE ;程序段声明
DT?XXG SEGMENT DATA OVERLAYABLE ;数据段声明
RSEG DT?XXG
RSEG PR?XXG
start:
lcall DISPLAY
ret
DISPLAY:
MOV DPTR,#TAB
MOV A,#01h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.0
LCALL DELAY1
setb P2.0
MOV DPTR,#TAB
MOV A,#02h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.1;
LCALL DELAY1;
setb P2.1;
MOV A,#03h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.2;
LCALL DELAY1;
setb P2.2;
MOV A,#04h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.3;
LCALL DELAY1;
setb P2.3;
djnz r1,DISPLAY
ret
DELAY1: MOV R3,#50H;
DEL3: MOV R1,#0AH;
DEL2: MOV R2,#18H;
DEL1: NOP;
NOP;
DJNZ R2,DEL1;
DJNZ R1,DEL2;
DJNZ R3,DEL3;
RET
TAB: DB 3FH,06H,5BH,4FH, 66H, 6DH, 7DH, 07H
DB 7FH, 6FH
END
;接口函数定义
PUBLIC START ;启动MP3
;程序数据段定义
RSEG DT?XXG
RSEG PR?XXG
start:
lcall DISPLAY
ret
DISPLAY:
MOV DPTR,#TAB
MOV A,#01h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.0
LCALL DELAY1
setb P2.0
MOV DPTR,#TAB
MOV A,#02h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.1;
LCALL DELAY1;
setb P2.1;
MOV A,#03h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.2;
LCALL DELAY1;
setb P2.2;
MOV A,#04h
MOVC A,@A+DPTR
cpl a
MOV P0,A
clr P2.3;
LCALL DELAY1;
setb P2.3;
djnz r1,DISPLAY
ret
DEL3: MOV R1,#0AH;
DEL2: MOV R2,#18H;
DEL1: NOP;
NOP;
DJNZ R2,DEL1;
DJNZ R1,DEL2;
DJNZ R3,DEL3;
RET
DB 7FH, 6FH
END
【有奖活动】分享技术经验,兑换京东卡 | |
话不多说,快进群! | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
打赏了!打赏了!打赏了! |
