共10条
KAO,白花了350元
原来该芯片没有串口,失败啊。只好通过外扩串口芯片了。
• Single-chip, high-performance processor with integrated network interfaces
− ARM940T processor
− Advanced Microcontroller Bus Architecture (AMBA) with two internal busses
♦ Advanced System Bus (ASB)
♦ Advanced Peripheral Bus (APB)
− 16k x 32 internal ROM
− 8k x 32 internal RAM
− External Memory Controller (EMC)
− Two identical 10/100 Mbps IEEE 802.3 Ethernet Media Access Controllers
(EMACs) with MII/7-WS interfaces
− USB 1.1 Slave Interface
− General Purpose Input/Output (GPIO) signals
− Timers
− Interrupt Controller (INTC)
− Clock Generators
• ARM940T processor
− ARM9TDMI Core
− Advanced System Bus (ASB) interface
− Advanced Peripheral Bus (APB) interface
− Separate 4 kB instruction and 4 kB data caches
− Write-back cache scheme and write buffer optimize performance and minimize
ASB traffic
− Five-stage pipeline with fetch, decode, execute, memory and write stages
− ‘TrackingICE’ mode allows a conventional ICE (in-circuit emulator) mode of
operation
• Dual Media Independent Interface (MII) interface to 10/100 Ethernet PHY
• Host Parallel Expansion Bus interface to Flash ROM and other devices
• Parallel interface to SDRAM/SRAM
• JTAG interface
• 22 general purpose I/O lines (13 available for application use, 6 available for
application use if optional signals for EEPROM, Host Parallel Expansion Bus, and
Clock are not used, and 3 dedicated to system signals)
• 196-pin FPBGA
共10条
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
分享汽车通信和多媒体总线结构被打赏20分 | |
【我踩过的那些坑】结构堵孔导致的喇叭无声问题被打赏50分 | |
NUCLEO-U083RC学习历程38+串口通过队列的方式输出两个字符串被打赏20分 | |
【我踩过的那些坑】分享一下调试一款AD芯片的遇到的“坑”被打赏50分 | |
电流检测模块MAX4080S被打赏10分 | |
分享电控悬架的结构与工作原理(一)被打赏20分 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 |
