如设置线宽为32位,CPU会把32位数据一次写入,如果外设是16位的话,如ISA网卡,就会造成高16位丢失.
例如:       LDR      r0, =0x10000000
            LDR      r1, =0x12345678
            STR      r1,[r0]
实际情况是 一次写入地址0x10000000的数据是 0x12345678
        LDR         r0, = 0xff               ;DRAM刷新率refresh rate,设置要适当,否则数据丢失
        STR         r0, [r11, #0x200]
        LDR         r13, =0xc0020000         ;设置堆栈 Stack, r13 为ARM定义的堆栈指针
;Init OK
        LDR         r0, =receiving_msg
        BL         printmsg
        BL         dram_test                 ;跳转指令,执行测试DRAM
        LDR         r0, =startloader_cmdmsg
        BL         printmsg
        BL         Beep
        LDR         r0, =0x60005             ;设置波特率 38400, 8位
        LDR         r11, =0x80000000
        STR         r0, [r11, #0x4c0]        ;初始化串口 UART
;Receive data and save it to buffer        ;开始接收数据
        LDR         r12, =SaveAddr             ;First 8 bytes are start address and length
;Receive address
        LDR         r5, =0x4                 ;Read first 4 bytes
        MOV         r0, #0
rx_loop1
        LDR         r1, [r11, #0x140]        ;检查系统状态寄存器System Status Register 1
        TST         r1, #0x00400000           ;UART1 Rx 是否为空
        BNE         rx_loop1                  ;等待数据 Wait data
        LDR         r1, [r11, #0x480]         ;读数据 Read data
        AND         r1, r1, #0xff
        ORR         r0, r1, r0, ROR #8
        SUBS    r5, r5, #1
        BNE         rx_loop1
        MOV         r0, r0, ROR #8
        STR         r0, [r12]
        ADD         r12, r12, #4
