创建定时器后,可以wdStart(),然后wdCancel(),一般是一次start对应一次cancel。如果是这样的可以吗?1start,1cancel,1又一次cancel,2start,是不是1又一次的cancel不会影响2start?1又一次的cancel不会导致系统死机?
共3条
wd内部有状态记录的。
* windWdCancel - cancel a watchdog timer
* This routine cancels a watchdog, removing it from the timer queue if needed.
* NOMANUAL
void windWdCancel
WDOG *wdId /* watch dog to cancel */
#ifdef WV_INSTRUMENTATION
/* windview - level 2 event logging */
EVT_TASK_1 (EVENT_WINDWDCANCEL, (int) wdId); /* log event */
#endif
if (wdId->status == WDOG_IN_Q)
Q_REMOVE (&tickQHead, &wdId->tickNode); /* remove from queue */
wdId->status = WDOG_OUT_OF_Q;
return (OK);
共3条
