yaopg,你好;
我一开始也是这么考虑的把buffer调整的大一些,
-> memShow
SUMMARY:
 status    bytes     blocks   avg block  max block
current
   free   20188296       209      96594   19350504
  alloc    5749368       428      13433          -
cumulative
  alloc    6789500      3585       1893          -
value = 0 = 0x0
-> mbufShow
type        number
FREE    :    129
DATA    :      3
HEADER  :    868
SOCKET  :      0
PCB     :      0
RTABLE  :      0
HTABLE  :      0
ATABLE  :      0
SONAME  :      0
ZOMBIE  :      0
SOOPTS  :      0
FTABLE  :      0
RIGHTS  :      0
IFADDR  :      0
CONTROL :      0
OOBDATA :      0
IPMOPTS :      0
IPMADDR :      0
IFMADDR :      0
MRTABLE :      0
TOTAL   :    1000
number of mbufs: 1000
number of times failed to find space: 0
number of times waited for space: 0
number of times drained protocols for space: 0
__________________
CLUSTER POOL TABLE
_______________________________________________________________________________
size     clusters  free      usage
64       100       99        5
128      15000     14131     3136
256      256       256       0
512      100       100       0
1024     50        50        0
2048     50        50        0
value = 80 = 0x50 = 'P'
因为128的包站决大部分,所以我吧NUM_128调成15000,但是问题还是回出现ring buffer overflow! 同时tNetTask的priority也调整了(=10),不知道问题在那里?
还有一事不明
64       100       99        5
这里cluster!=free+usage, 是不是因为usage中有释放了重新使用的?
