我是一个新手,最近我在QUARTUSII6.0用VHDL编程,每次只要程序中含有 + 、-、*、/ ,编译时都会报类似的错误,如下面这个程序:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_unsigned.ALL;
entity adder is
port( in1 : bit_vector;
in2 : bit_vector;
cnt1 : bit;
pout : out bit_vector);
end entity adder;
architecture func of adder is
begin
process(cnt1)
begin
if(cnt1='1') then pout<=in1 + in2;
end if;
end process;
end architecture func;
每次编译时总是出现这样的错误提示:
Error (10327): VHDL error at adder.vhd(15): can't determine definition of operator ""+"" -- found 0 possible definitions
Error (10523): Ignored construct func at adder.vhd(11) due to previous errors
如果把程序中的“+”换成“*”或者“-”,编译时会把错误中的operator ""+"" 改成operator ""*""和operator ""-"",请高手指点一下出错的原因。谢谢了
| OrangePiZero2W系统被打赏¥33元 | |
