vxworks boot problem
VxWorks System Boot
Copyright 1984-2002 Wind River Systems, Inc.
CPU: PC PENTIUM
Version: VxWorks5.5
BSP version: 1.2/2
Creation date: June 14 2007, 10:10:37
0x2a7a8c (tBoot): dosFsLib.c : ERROR reading the device boot sector
0x2a7a8c (tBoot): dosFsLib.c : media not formatted or not present
0x2a7a8c (tBoot): sysNvRamGet: open failed
Press any key to stop auto-boot... :
0
auto-booting...
boot device : fei
unit number : 0
processor number : 0
host name : bbdou
file name : c:\vxWorks
inet on ethernet (e) : 10.0.0.139
host inet (h) : 10.0.0.39
user (u) : ttry
ftp password (pw) : vxworks
flags (f) : 0x0
target name (tn) : target
Attached TCP/IP interface to fei0
Warning: no netmask specified.
Attaching network interface lo0... done
Loading... 888562
Starting at 0x308000...
WFTPD information:
[L 0040] 06/15/07 09:03:40 Connection accepted from 10.0.0139
[C 0040] 06/15/07 09:03:40 Command "USER ttry" received
[C 0040] 06/15/07 09:03:40 PASSword accepted
[L 0040] 06/15/07 09:03:40 User ttry logged in.
[C 0040] 06/15/07 09:03:40 Command "TYPE I" received
[C 0040] 06/15/07 09:03:40 TYPE set to I
[C 0040] 06/15/07 09:03:40 Command "PASV" received
[C 0040] 06/15/07 09:03:40 Entering Passive Mode [10,0,0,39,6,201]
[C 0040] 06/15/07 09:03:40 Command "RETR C:\vxWorks" received
[C 0040] 06/15/07 09:03:40 RETRieve started o file C:\vxWorks
[C 0040] 06/15/07 09:03:41 Transfer finished
[G 0040] 06/15/07 09:03:41 Got file C:\vxWorks successfully
[C 0040] 06/15/07 09:03:41 Command "QUIT" received
[C 0040] 06/15/07 09:03:41 QUIT or close-user ttry logged out
If boot without the connection with the host,
.................................................................(same with above)
Loading...
Error loading file: errno = 0x308000.
Can't load boot file!!
Error opening file "/vxboot/bootrom.sys", trying "/vxboot/bootrom.dat" ...
Error opening file "/vxboot/bootrom.dat"
[VxWorks Boot]:
关键词: vxworks problem
If boot with network connected:
VxWorks System Boot
CPU: PC PENTIUM
Version: VxWorks5.5
BSP version: 1.2/2
0
auto-booting...
boot device : fei
unit number : 0
host name : bbdou
user (u) : ttry
flags (f) : 0x0
Loading... 888562
WFTPD information:
Loading...
[VxWorks Boot]:
很显然,target和host没有通过网络相连,怎么可能下载到vxworks
Attached TCP/IP inte**ce to fei0
Attaching network inte**ce lo0... done
Loading... 888562
我的到上面就停止了
然后超长时间后才显示[Vxworks boot]
为什么啊
我的是Tor2.2+Vx5.5+PIII+intel82559ER
是不是用自带的82559的网卡驱动不行,和82559ER有甚么区别啊
也能ping通,就是下载不下去
谢谢
开发环境Tor2.2+Vx5.5+PIII+intel82559ER
下
目标机会显示
然后Press any key to stop auto-boot... :
7---》0
auto-booting...然后
Loading... 888562
目标机就停在这了,过段时间就显示[Vxworks boot]
时间长短和主机的wftpd有关,那上面有个设置超时的选型吧,(ps:有人说是tor2.2带的wftpd有问题)
另外在主机wftpd端,
ftp server的提示:
connection accepted from 192.168.0.199
command "user starlight " received
password accepted
user starlight logged in
command "type i"received
type set to i n
command "pasv" received
entering passive mode[192,168,0,2,8,93]
command "retr vxworks" received
retrieve started on file vxworks
显示不能成功下载
为什么,难道是ftp的问题?
谢谢各位了!!!
[em01][em01]我用的VMWare, 网上下载的AMD 79C97x驱动,修改config.h为
lnPci(0,0)host:vxWorks h=192.168.10.19 e=192.168.10.23 u=user pw=1 tn=target
引导时提示lnPci0: failed to enter suspend mode
Loading... FTP transfer failed
Error loading file: errno = 0x33.
WFTPD那边没有收到任何请求。
请问这是什么原因,网卡驱动是否已经装上了?
| 为遥控小车巧添功能被打赏¥26元 | |
