电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » FPGA实现串口通信的例子
FPGA实现串口通信的例子
2007-07-02 23:25:04     打赏
FPGA板上实现串口通信
FPGA开发板上写的Verilog代码:
功能是从电脑端发送一个字节,然后把它接收回来。
`timescale 1ns / 10ps
`define Tgate 1
module uart_loop (osc,rst_,rxd,sdo,data_ready,framing_error,parity_error);
input osc ;
input rst_ ;
input rxd ;
output sdo ;
output data_ready ;
output framing_error ;
output parity_error ;
wire rst = ~rst_;
reg[7:0] oscd163r;
always @(posedge osc or posedge rst)
begin
if (rst)
oscd163r <= 0 ;
else
oscd163r <= (oscd163r==8'HA3) ? 0 : (oscd163r + 1) ;
end
reg clk16x;
begin
if (rst)
clk16x <= 0 ;
else
clk16x <= (oscd163r==8'HA3) ? ~clk16x : clk16x ;
end
reg[4:0] clk1d4r;
always @(posedge clk16x or posedge rst)
begin
if (rst)
clk1d4r = 5'b00000 ;
else
clk1d4r = clk1d4r +1 ;
end
wire clk1d4 = clk1d4r[4];
wire data_ok = data_ready& ~framing_error & ~parity_error ;
wire tbre;//Status signal indication that the transmitter buffer register is empty
//CASE BRANCH
parameter IDLE = 3'h0,LOAD1 = 3'h1,LOAD2 = 3'h4, STORE=3'h2,WAIT_TX=3'h3 ;
reg[2:0] State;
always @(posedge clk1d4 or posedge rst)
if(rst)
State <= #`Tgate IDLE;
else
case(State)
IDLE :
if(data_ok)
State <= #`Tgate LOAD1;
else
LOAD1 :
State <= #`Tgate LOAD2;
LOAD2 :
State <= #`Tgate STORE;
STORE :
State <= #`Tgate WAIT_TX;
WAIT_TX :
if(!tbre)
else
default : State <= #`Tgate IDLE;
endcase
reg rdn,wrn;
wire[7:0] dout;
reg[7:0] din;
//Execute
if(rst)
begin
rdn <= #`Tgate 1'b1;
wrn <= #`Tgate 1'b1;
din <= #`Tgate 8'hEE;
end
else
case(State)
IDLE :
begin
end
LOAD1 :
begin
rdn <= #`Tgate 1'b0;
end
LOAD2 :
begin
din <= #`Tgate dout;
end
STORE :
begin
wrn <= #`Tgate 1'b0;
din <= #`Tgate din;
end
WAIT_TX :
begin
end
default :
begin
end
endcase
uart i_uart(
dout,data_ready,framing_error,parity_error,rxd,clk16x,rst,rdn,din,tbre,tsre,wrn,sdo);
endmodule
使用EZDSO2041的单次触发功能捕捉到串口发送B后并接收回来的波形:
[align=right][color=#000066][此贴子已经被作者于2007-7-4 14:31:47编辑过][/color][/align]
关键词: 实现     串口     通信     例子     Tgate     posedge
2007-07-04 22:33:00     打赏
先自己顶一个。
