电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » 怎么设置 Rhapsody 环境 ??
共9条 1/1 1 跳转至页
怎么设置 Rhapsody 环境 ??
2007-08-10 07:19:49     打赏
我想用 T20 for PPC 和 Rhapsody 结合起来, 但是 Rhapsody默认 的target是80486, 我想改成PPC860, 请问各位应该怎么做? 下面是一下信息. Sample build.mak File The following is an example of the vxbuild.mak file, which is used to build the framework for the VxWorks environment. MAKE=make CPU=I80486 ifeq ($(PATH_SEP),) all : @echo PATH_SEP is not defined. Please define it as \\or / else all : $(MAKE) all -C oxf -f vxoxf.mak CFG=vxoxf CPU=$(CPU) PATH_SEP=$(PATH_SEP) $(MAKE) all -C oxf -f vxoxf.mak CFG=vxoxfsim CPU=$(CPU) PATH_SEP=$(PATH_SEP) $(MAKE) all -C oxf -f vxoxf.mak CFG=vxoxfinst CPU=$(CPU) PATH_SEP=$(PATH_SEP) $(MAKE) all -C oxf -f vxoxf.mak CFG=vxoxfsiminst CPU=$(CPU) PATH_SEP=$(PATH_SEP) $(MAKE) all -C omcom -f vxomcom.mak CFG=vxomcomappl CPU=$(CPU) PATH_SEP=$(PATH_SEP $(MAKE) all -C tom -f vxtom.mak CFG=vxtomtrace CPU=$(CPU) PATH_SEP=$(PATH_SEP) $(MAKE) all -C tom -f vxtom.mak CFG=vxtomtraceRiC CPU=$(CPU) PATH_SEP=$(PATH_SEP) $(MAKE) all -C aom -f vxaom.mak CFG=vxaomtrace CPU=$(CPU) PATH_SEP=$(PATH_SEP) $(MAKE) all -C aom -f vxaom.mak CFG=vxaomanim CPU=$(CPU) PATH_SEP=$(PATH_SEP) endif This makefile: ? Sets the make command for the VxWorks environment (make). ? Sets the CPU being targeted (I80486 = Intel 80486). ? Checks whether the path separator (PATH_SEP) character was properly set. If not, it generates an error and cancels the build. ? Sets the all: command to build the framework libraries for the various configurations (with and without animation, real-time or simulated time, and so on).
关键词: 怎么     设置     Rhapsody     环境
2007-08-10 07:21:59     打赏
昨晚搞定了, 把Rhapsody/share/langc/vxbuild.mak修改一下, CPU改成PPC860, 把路径改成//, 然后在dos下运行tornado下的torvars,然后到目录Rhapsody/share/langc/下 make -f vxbuild.mak,就生成5个库文件,在lib目录下, http://www.pc860.com MPC8XX BDM调试器,入门级MPC850学习板我的硬盘 http://pc850.vicp.net:5656
2007-08-10 07:22:37     打赏
这东东有点难用, connect没有任何反应, http://www.pc860.com MPC8XX BDM调试器,入门级MPC850学习板我的硬盘 http://pc850.vicp.net:5656
2007-08-10 07:22:54     打赏
生成几个库就可以了, 我的电脑是CPU有点问题,是VIA的。 http://www.pc860.com MPC8XX BDM调试器,入门级MPC850学习板我的硬盘 http://pc850.vicp.net:5656
2007-08-10 07:23:08     打赏
最近一直比较忙,你可以看看里边的文档,照着做应该没问题, 我经常做小东西,基本用不着rhapsody, 用得最多的是状态机。
2007-08-10 07:23:29     打赏
关注
2011-02-12 11:38:05     打赏
跟着学学
2011-07-12 14:40:12     打赏
有点难度,不是很明白啊!看来还是要多学习学习.
2011-10-12 10:05:26     打赏
型号            品牌  年份 封装 无铅 货期
TLP131          Toshiba  11+ SOP Y 原装现货
TLP161J          Toshiba 11+ SOP Y 原装现货
TLP127          Toshiba  11+ SOP Y 原装现货
TLPTLP114A       Toshiba  11+ SOP Y 原装现货
TLP112A          Toshiba 11+ SOP Y 原装现货
TLP521-4         Toshiba 11+ DIP Y 原装现货
TLP521-1         Toshiba 11+ DIP Y 原装现货
TLP521-2         Toshiba 11+ DIP Y 原装现货
TLP281-4GB       Toshiba 11+ SOP Y 原装现货
TLP280-4         Toshiba 11+ SOP Y 原装现货
TLP181GR         Toshiba 11+ SOP Y 原装现货
TLP113           Toshiba 11+ SOP Y 原装现货
TLP621(D4, GB F T)Toshiba  11+ DIP Y 原装现货
PS2801-4-F3-A   NEC  11+ SOP Y 原装现货
PS2501L-1-F3(LK)  NEC  11+ SOP Y 原装现货
PS2701-1-F3   NEC  11+ SOP Y 原装现货
ACPL-M60L-500E   Avago  11+ SOP Y 原装现货
PC817C           SHARP  11+ DIP Y 原装现货
LTV-814           Lite-On 11+ DIP Y 原装现货
电话:0755-82767111
传真:0755-83643999
企业QQ:4000016118
邮件:ic199@qq.com
网址:www.tosharp.cn
联系人:洪纯娴
QQ;1711893081
手机:13691789333  1348086690
共9条 1/1 1 跳转至页
