共5条
iar调试download后出现这样的warnings是怎么回事阿?
Tue Jul 15 16:24:57 2003: Target inconsistency detected at Memory address 0x000080AC
Tue Jul 15 16:24:57 2003: Target inconsistency detected at Memory address 0x000080AE
Tue Jul 15 16:24:57 2003: Target inconsistency detected at Memory address 0x000080B4
Tue Jul 15 16:24:57 2003: Target inconsistency detected at Memory address 0x000080BA
Tue Jul 15 16:24:57 2003: Target inconsistency detected at Memory address 0x000080E8
Tue Jul 15 16:24:57 2003: Target inconsistency detected at Memory address 0x000080EC
Tue Jul 15 16:24:57 2003: Target inconsistency detected at Memory address 0x000080FA
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008108
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008128
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008148
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x0000814C
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008158
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008188
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00000000
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008000
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008044
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008198
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x0000819C
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008224
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x000081A4
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x000081B0
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x000081B6
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x0000820C
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008218
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008204
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x00008064
Tue Jul 15 16:24:58 2003: Target inconsistency detected at Memory address 0x000080A8
Tue Jul 15 16:24:58 2003: There were warnings during download, see Log Window
Tue Jul 15 16:24:59 2003: Loaded module
Tue Jul 15 16:25:00 2003: The maximum number of 2 JTAG watchpoints has been succeeded !!!
3 OP-fetch breakpoints has been set in ROM memory
within the range 0x000080AC - 0x000081A0
Before execution can be made, some breakpoints must first be disabled.
这样子运行那个点灯程序也不见灯亮.
关键词: 调试 download 出现 这样 warning
共5条
