专业英语术语
沖壓類
punch, press沖
punching machine 沖床
hydraulic machine油壓機
jack升降機
decoiler整平機
manufacture management製造管理
stamping, press沖壓
feeder送料機
rack, shelf, stack料架
taker取料機
to reverse material 翻料
to load material上料
to unload material卸料
to return material/stock to退料
scraped |\'skr鎝id|報廢
scrape ..v.刮;削
robot機械手
production line流水線
packaging tool打包機
packaging打包
成型類
well type蓄料井
insulated runner絕緣澆道方式
hot runner熱澆道
runner plat澆道模塊
valve gate閥門澆口
band heater環帶狀的電熱器
spindle閥針
spear head鉋尖頭
slag well冷料井
cold slag冷料渣
air vent排氣道
welding line熔合痕
eject pin頂出針
knock pin頂出銷
return pin回位銷反頂針
sleeve套筒
stripper plate脫料板
insert core放置入子
runner stripper plate澆道脫料板
guide pin導銷
eject rod (bar)(成型機)頂業捧
subzero深冷處理
three plate三極式模具
runner system澆道系統
stress crack應力電裂
orientation定向
sprue gate射料澆口,直澆口
nozzle射嘴
sprue lock pin料頭鉤銷(拉料杆)
slag well冷料井
side gate側澆口
edge gate側緣澆口
tab gate搭接澆口
film gate薄膜澆口
flash gate閘門澆口
slit gate縫隙澆口
fan gate扇形澆口
dish gate因盤形澆口
diaphragm gate隔膜澆口
ring gate環形澆口
submarine gate潛入式澆口
tunnel gate隧道式澆口
pin gate針點澆口
runner less無澆道
sprue less 無射料管方式
long nozzle延長噴嘴方式
spur澆口;溶
waste廢料
board看板
sliding rack滑料架
to impose lines壓線
to compress, compressing壓縮
character die字模
to feed, feeding送料
material change, stock change材料變更
feature change 特性變更
prepare for, make preparations for 準備
rotating speed, revolution轉速
abnormal handling異常處理
組裝類
Assembly line組裝線
Layout布置圖
Conveyer流水線運\輸帶
Rivet machine拉釘機
Rivet gun拉釘槍
Screw driver起子
Electric screw driver電動起子
Hydraulic machine 液壓機
Pneumatic screw driver氣動起子
automation自動化
to stake, staking, riveting鉚合
add lubricant oil加潤滑油
argon welding氬焊
cylinder油缸
robot機械手
conveying belt輸送帶
transmission rack輸送架
to draw holes抽孔
bolt螺栓
nut 螺母
screw 螺絲
identification tag標示單
screwdriver plug起子插座
automatic screwdriver電動啟子
to move, to carry, to handle搬運\
be put in storage入庫
packing包裝
staker = riveting machine鉚合機
fit together組裝在一起
fasten鎖緊(螺絲)
fixture 夾具(治具)
pallet/skid棧板
barcode條碼
barcode scanner條碼掃描器
fuse together熔合
fuse machine/heat stake熱熔機
processing, to process加工
delivery, to deliver 交貨
to return delivery to. to send delivery back to return of goods退貨
easily damaged parts易損件
standard parts標準件
to lubricate潤滑
spring 彈簧
spare tools location/buffer手工備品倉
spare molds location模具備品倉
tox machine自鉚機
共6条
品質類
qualified products, up-to-grade products良品
defective products, not up-to-grade products不良品
defective product box不良品箱
poor processing 制程不良
poor incoming part來件不良
exposed metal/bare metal金屬裸露
excessive defect過多的缺陷
critical defect極嚴重缺陷
major defect主要缺陷
minor defect次要缺陷
not up to standard不合規格
cosmetic defect外觀不良
lack of painting烤漆不到位
slipped screw head/slippery slipped thread滑絲
missing part漏件
wrong part錯件
oxidation氧化
defective threading抽芽不良
poor staking鉚合不良
deficient purchase來料不良
deficient manufacturing procedure制程不良
cosmetic inspection外觀檢查
inner parts inspection內部檢查
blister 氣泡
angular offset 角度偏差
dent 壓痕
scratch 刮傷
deformation 變形
filings 鐵削
defective label 不良標簽
abrasion 磨損
Breaking. (be)broken,(be)cracked 斷裂
short射料不足
nick缺口
speck瑕疪
shine亮班
splay 銀紋
gas mark焦痕
delaminating起鱗
speckle斑點
mildewed =moldy = mouldy發霉
deformation變形
burr(金屬)flash(塑件)毛邊
poor staking鉚合不良
excessive gap間隙過大
grease/oil stains油污
inclusion雜質
shrinking/shrinkage縮水
mixed color雜色
fold of packaging belt打包帶折皺
painting make-up補漆
discoloration羿色
water spots水漬
impurity 雜質
Mismatch 錯位
failure, trouble 故障
deformation 變形
rust 生銹
peel 脫漆
Shrink 縮水
Contamination 臟污
water spots 水漬
Gap 間隙
label error 標簽錯誤
Missing label 漏貼
rejection criteria 拒收標准
Suspected rejects 可疑庇
abrasion 損傷、磨損
Texture surface 印花紋表面
Streak 條紋
stains 污點
Blotch 斑點
discoloration 脫色
Inclusion 雜質
slug mark 壓痕
dirt grime 灰塵
blush 毛邊薄膜
sink 下凹
Hickey 漏漆
labels and logos 貼紙與商標
Configuration labels 組合貼紙
corrugated container 瓦擺紙箱
Delaminating 脫層
splattering 散點
Gouge 銼孔
puckering 折痕
major defect主要缺陷
minor defect次要缺陷
cosmetic defect外觀不良
missing part漏件
wrong part錯件
oxidation氧化
poor staking鉚合不良
blister 氣泡
angular offset 角度偏差
dent 壓痕
scratch 刮傷
deformation 變形
filings 鐵削
abrasion 磨損
short射料不足
nick缺口
speck瑕疪
shine亮班
splay 銀紋
gas mark焦痕
delaminating起鱗
speckle斑點
deformation變形
burr(金屬)flash(塑件)毛邊
poor staking鉚合不良
excessive gap間隙過大
grease/oil stains油污
inclusion雜質
mixed color雜色
painting make-up補漆
discoloration羿色
water spots水漬
impurity 雜質
Mismatch 錯位
failure, trouble 故障
deformation 變形
rust 生銹
peel 脫漆
Shrink 縮水
Contamination 臟污
water spots 水漬
Gap 間隙
label error 標簽錯誤
Missing label 漏貼
abrasion 損傷、磨損
Streak 條紋
stains 污點
Blotch 斑點
discoloration 脫色
Inclusion 雜質
slug mark 壓痕
dirt grime 灰塵
blush 毛邊薄膜
sink 下凹
Hickey 漏漆
Delaminating 脫層
splattering 散點
Gouge 銼孔
puckering 折痕
通用類
president董事長
operator作業員
position職務
general manager總經理
special assistant 特助
deputy manager |\'depjuti| =vice manager副理
deputy supervisor =vice supervisor副課長
group leader組長
line leader線長
supervisor 課長
responsible department負責單位
Human Resources Department
人力資源部
Head count 人頭數
production department生產部門
planning department企劃部
QC Section品管課
stamping factory沖壓廠
painting factory烤漆廠
molding factory成型廠
administration/general affairs dept./總務部
production unit生產單位
meeting minutes會議記錄
distribution department分發單位
subject主題
conclusion結論
decision items決議事項
pre-fixed finishing date預定完成日
Color management 顏色管理
Visual management 目視管理
production capacity生產力
first count初盤
first check初盤復櫂
second count 復盤
second check復盤復核
quantity of physical inventory second count 復盤點數量
physical inventory盤點數量
physical count quantity帳面數量
difference quantity差異量
spare parts physical inventory list備品盤點清單
cause analysis原因分析
waste materials廢料
description品名
specification 規格
model機種
work order工令
revision版次
remark備注registration登記
registration card登記卡
to control管制
application form for purchase請購單
consume, consumption消耗
to notify通知
to fill in填寫
to collect, to gather收集
statistics統計
cosmetic inspection standard 外觀檢驗規範
computer case 電腦外殼(組件)
personal computer enclosure 電腦機箱產品
front plate前板
rear plate后板
chassis |\'∫鎠i| 基座
bezel panel面板
Hood 上蓋
base pan 基座
bezel 面板
riser card 擴充卡
flat cable 排線
TOP driver cage 上磁架
bottom driver cage 下磁架
resin film 樹脂膜
raw materials原料
materials物料
steel plate鋼板
roll/coil material捲料
spare parts =buffer備品
plastic parts塑膠件
sheet metal parts/stamping parts 沖件
material check list物料檢查表
finished product成品
semi-finished product半成品
good product/accepted goods/ accepted parts/good parts良品
defective product/non-good parts不良品
disposed goods處理品
warehouse/hub倉庫
packing material包材
basket蝴蝶竺
plastic basket膠筐
flow chart流程表單
production tempo生產進度現狀
lots of production生產批量
manufacture procedure制程
to revise, modify修訂
to switch over to, switch—to, switching over切換
engineering bottleneck, project difficulty工程瓶頸
glove(s)手套
glove(s) with exposed fingers割手套
Band-Aid創可貼
Industrial alcohol工業酒精
broom掃把
mop拖把
vacuum cleaner吸塵器
rag 抹布
garbage container灰箕
garbage can垃圾箱
garbage bag垃圾袋
liaison聯絡單
rags抹布
lamp holder燈架
to mop the floor拖地
to clean a table擦桌子
air pipe 氣管
delivery deadline交貨期
die worker模工
production, to produce生產
equipment設備
resistance電阻
beacon警示燈
coolant冷卻液
crusher破碎機
club car高爾夫球車
plate電鍍
power button電源按鍵
reset button重置鍵
forklift叉車
Workshop traveler 天車
trailer =long vehicle拖板車
Hydraulic trolley手壓車
hydraulic hand jack油壓板車
casing = containerization裝箱velocity速度
patent專利
coordinate座標
supply and demand供求
career card履歷卡
barricade隔板
carton box紙箱
to pull and stretch拉深
work cell/work shop工作間
sub-line支線
bottleneck 瓶頸
president董事長
operator作業員
position職務
general manager總經理
group leader組長
line leader線長
supervisor 課長
人力資源部
Head count 人頭數
QC Section品管課
stamping factory沖壓廠
painting factory烤漆廠
molding factory成型廠
production unit生產單位
meeting minutes會議記錄
subject主題
conclusion結論
decision items決議事項
first count初盤
first check初盤復櫂
second count 復盤
second check復盤復核
cause analysis原因分析
waste materials廢料
description品名
specification 規格
model機種
work order工令
revision版次
to control管制
to notify通知
to fill in填寫
statistics統計
front plate前板
rear plate后板
chassis |\'∫鎠i| 基座
bezel panel面板
Hood 上蓋
base pan 基座
bezel 面板
riser card 擴充卡
flat cable 排線
TOP driver cage 上磁架
resin film 樹脂膜
raw materials原料
materials物料
steel plate鋼板
plastic parts塑膠件
finished product成品
disposed goods處理品
warehouse/hub倉庫
packing material包材
basket蝴蝶竺
plastic basket膠筐
flow chart流程表單
to revise, modify修訂
glove(s)手套
Band-Aid創可貼
broom掃把
mop拖把
vacuum cleaner吸塵器
rag 抹布
garbage container灰箕
garbage can垃圾箱
garbage bag垃圾袋
liaison聯絡單
rags抹布
lamp holder燈架
to mop the floor拖地
to clean a table擦桌子
air pipe 氣管
die worker模工
equipment設備
resistance電阻
beacon警示燈
coolant冷卻液
crusher破碎機
club car高爾夫球車
plate電鍍
power button電源按鍵
reset button重置鍵
forklift叉車
patent專利
coordinate座標
supply and demand供求
career card履歷卡
barricade隔板
carton box紙箱
sub-line支線
bottleneck 瓶頸
模具工程類
plain die簡易模
pierce die沖孔模
forming die成型模
progressive die連續模
stage die工程模
compound die復合模
shearing die剪邊模
riveting die鉚合模
feature die公母模
male die公模
female die母模
cavity型控 母模
core模心 公模
die change 換模
to fix a die裝模
to repair a die修模
punch set上模座
punch pad上墊板
punch holder上夾板
stripper pad脫料背板
up stripper上脫料板
upper plate上模板
lower plate下模板
die pad下墊板
die holder下夾板
die set下模座
bottom block下墊腳
bottom plate下托板(底板)
upper supporting blank上承板
upper padding plate blank上墊板
top plate上托板(頂板)
top block上墊腳
stripping plate內外打(脫料板)
outer stripper外脫料板
inner stripper內脫料板
lower stripper下脫料板punch沖頭
insert入塊(嵌入件)
deburring punch壓毛邊沖子
groove punch壓線沖子
stamped punch字模沖子
round punch圓沖子
special shape punch異形沖子
bending block折刀
roller滾軸
baffle plate擋塊
located block定位塊
supporting block for location
定位支承塊
air cushion plate氣墊板
air-cushion eject-rod氣墊頂桿
trimming punch切邊沖子
stiffening rib punch = stinger 加強筋衝子
ribbon punch壓筋沖子
reel-stretch punch卷圓壓平沖子
guide plate定位板
sliding block滑塊
sliding dowel block滑塊固定塊
die locker鎖模器
pressure plate =plate pinch壓板
thickness gauge厚薄規
cutting die, blanking die沖裁模
die block模塊
folded block折彎塊
sliding block滑塊
location pin定位銷
lifting pin頂料銷
die plate, front board模板
padding block墊塊
stepping bar墊條
panel board鑲塊
to load a die裝上模具
to unload a die 御模具
active plate活動板
lower sliding plate下滑塊板
upper holder block上壓塊
upper mid plate上中間板
spring box彈簧箱
spring-box eject-rod彈簧箱頂桿
spring-box eject-plate彈簧箱頂板
bushing block襯套
cover plate蓋板
guide pad導料塊
pilot導正筒
trim剪外邊
pierce剪內邊
pocket for the punch head挂鉤槽
slug hole廢料孔
radius半徑
shim/wedge/heel/pad/spacer/gasket楔子
torch-flame cut火焰切割
set screw止付螺絲
form block折刀
round pierce punch =die button圓沖子
shape punch =die insert異形子
stock located block定位塊
metal plate鈑金
miller銑床
grinder磨床
tolerance公差
score =groove壓線
sliding block滑塊lathe車
active plate活動板
baffle plate擋塊
cover plate蓋板
groove punch壓線沖子
capability能力
parameter參數
factor系數
driller鉆床
set up die架模
height of die setting up架模高度
analog-mode device類模器
inner guiding post內導柱
inner hexagon screw內六角螺釘
dowel pin固定銷
coil spring彈簧
lifter pin頂料銷
eq-height sleeves =spool等高套筒
pin銷
lifter guide pin浮升導料銷
guide pin導正銷
wire spring圓線彈簧
outer guiding post外導柱
stop screw止付螺絲
located pin定位銷
outer bush外導套
press specification沖床規格
die height閉模高度
flow mark流痕
welding mark溶合痕
post screw insert螺紋套筒埋值
self tapping screw自攻螺絲
stripper plate脫料板
piston活塞
handle mold手持式模具
flash mold溢流式模具
positive mold擠壓式模具
split mold分割式模具
die lifter舉模器
top stop上死點
bottom stop下死點
one stroke一行程
to continue, cont.連動
to grip(material)吸料
location lump, locating piece, location block定位塊
reset復位
to file burr 銼毛刺
embedded lump |in\'bed| |l賛p|鑲塊
stamping-missing漏沖
to tight a bolt擰緊螺栓
to loosen a bolt擰鬆螺栓
punched hole沖孔
to cut edge =side cut =side scrap 切邊
to bending折彎
to pull, to stretch拉伸
engraving, to engrave刻印
stamping 油印
to stake鉚合
designing, to design設計
design modification 設計脩改成
gauge(or jig)治具
pedal踩踏板
stopper阻擋器
flow board流水板
torque扭矩
spline =the multiple keys花鍵
quenching淬火
tempering回火
annealing退火
carbonization碳化
alloy合金
tungsten high speed steel鎢高速的
moly high speed steel鉬高速的
forming成型(抽凸,沖凸)
draw hole抽孔
bending折彎
emboss凸點
dome凸圓
semi-shearing半剪
stamp mark沖記號
deburr or coin壓毛邊
punch riveting沖壓鉚合
side stretch側沖壓平
reel stretch卷圓壓平
groove壓線
stamp letter沖字(料號)
tick-mark nearside正面壓印
tick-mark farside反面壓印
extension DWG展開圖
procedure DWG工程圖
die structure DWG模具結構圖
plain die簡易模
pierce die沖孔模
forming die成型模
progressive die連續模
stage die工程模
compound die復合模
shearing die剪邊模
riveting die鉚合模
feature die公母模
male die公模
female die母模
cavity型控 母模
core模心 公模
die change 換模
to fix a die裝模
to repair a die修模
punch set上模座
punch pad上墊板
punch holder上夾板
stripper pad脫料背板
up stripper上脫料板
upper plate上模板
lower plate下模板
die pad下墊板
die holder下夾板
die set下模座
bottom block下墊腳
bottom plate下托板(底板)
top plate上托板(頂板)
top block上墊腳
outer stripper外脫料板
inner stripper內脫料板
insert入塊(嵌入件)
groove punch壓線沖子
stamped punch字模沖子
round punch圓沖子
bending block折刀
roller滾軸
baffle plate擋塊
located block定位塊
定位支承塊
trimming punch切邊沖子
ribbon punch壓筋沖子
guide plate定位板
sliding block滑塊
die locker鎖模器
thickness gauge厚薄規
die block模塊
folded block折彎塊
sliding block滑塊
location pin定位銷
lifting pin頂料銷
padding block墊塊
stepping bar墊條
panel board鑲塊
to load a die裝上模具
to unload a die 御模具
active plate活動板
upper mid plate上中間板
spring box彈簧箱
bushing block襯套
cover plate蓋板
guide pad導料塊
pilot導正筒
trim剪外邊
pierce剪內邊
slug hole廢料孔
radius半徑
torch-flame cut火焰切割
set screw止付螺絲
form block折刀
metal plate鈑金
miller銑床
grinder磨床
tolerance公差
score =groove壓線
active plate活動板
baffle plate擋塊
cover plate蓋板
groove punch壓線沖子
capability能力
parameter參數
factor系數
driller鉆床
set up die架模
dowel pin固定銷
coil spring彈簧
lifter pin頂料銷
pin銷
guide pin導正銷
wire spring圓線彈簧
stop screw止付螺絲
located pin定位銷
outer bush外導套
die height閉模高度
flow mark流痕
welding mark溶合痕
stripper plate脫料板
piston活塞
handle mold手持式模具
flash mold溢流式模具
positive mold擠壓式模具
split mold分割式模具
die lifter舉模器
top stop上死點
bottom stop下死點
one stroke一行程
to grip(material)吸料
reset復位
to file burr 銼毛刺
stamping-missing漏沖
to tight a bolt擰緊螺栓
punched hole沖孔
to bending折彎
stamping 油印
to stake鉚合
gauge(or jig)治具
pedal踩踏板
stopper阻擋器
flow board流水板
torque扭矩
quenching淬火
tempering回火
annealing退火
carbonization碳化
alloy合金
forming成型(抽凸,沖凸)
draw hole抽孔
bending折彎
emboss凸點
dome凸圓
semi-shearing半剪
stamp mark沖記號
deburr or coin壓毛邊
punch riveting沖壓鉚合
side stretch側沖壓平
reel stretch卷圓壓平
groove壓線
stamp letter沖字(料號)
extension DWG展開圖
procedure DWG工程圖
品質人員名稱類
QC quality control 品質管理人員
FQC final quality control 終點品質管制人員
IPQC in process quality control 制程中的品質管制人員
OQC output quality control 最終出貨品質管制人員
IQC incoming quality control 進料品質管制人員
TQC total quality control 全面質量管理
POC passage quality control 段檢人員
QA quality assurance 質量保證人員
OQA output quality assurance 出貨質量保證人員
QE quality engineering 品質工程人員
品質保證類
FAI first article inspection 新品首件檢查
FAA first article assurance 首件確認
CP capability index 能力指數
CPK capability process index 模具製程能力參數
SSQA standardized supplier quality audit 合格供應商品質評估
FMEA failure model effectiveness analysis 失效模式分析
FQC運\作類
AQL Acceptable Quality Level 運\作類允收品質水準
S/S Sample size 抽樣檢驗樣本大小
ACC Accept 允收
REE Reject 拒收
CR Critical 極嚴重的
MAJ Major 主要的
MIN Minor 輕微的
Q/R/S Quality/Reliability/Service 品質/可靠度/服務
P/N Part Number 料號
L/N Lot Number 批號
AOD Accept On Deviation 特采
UAI Use As It 特采
FPIR First Piece Inspection Report 首件檢查報告
PPM Percent Per Million 百萬分之一
制程統計品管專類
SPC Statistical Process Control 統計製程管制
SQC Statistical Quality Control 統計品質管制
GRR Gauge Reproductiveness & Repeatability 量具之再制性及重測性判斷量可靠與否
DIM Dimension 尺寸
DIA Diameter 直徑
N Number 樣品數
其它品質術語類
QIT Quality Improvement Team 品質改善小組
ZD Zero Defect 零缺點
QI Quality Improvement 品質改善
QP Quality Policy 目標方針
TQM Total Quality Management 全面品質管理
RMA Return Material Audit 退料認可
7QCTools 7 Quality Control Tools 品管七大手法
通用之件類
ECN Engineering Change Notice 工程變更通知(供應商)
ECO Engineering Change Order 工程改動要求(客戶)
PCN Process Change Notice 工序改動通知
PMP Product Management Plan 生產管制計劃
SIP Standard Inspection Procedure 製程檢驗標準程序
SOP Standard Operation Procedure 製造作業規範
IS Inspection Specification 成品檢驗規範
BOM Bill Of Material 物料清單
PS Package Specification 包裝規範
SPEC Specification 規格
DWG Drawing 圖面
系統文件類
ES Engineering Standard 工程標準
CGOO China General PCE龍華廠文件
IWS International Workman Standard 工藝標準
ISO International Standard Organization 國際標準化組織
GS General Specification 一般規格
部類
PMC Production & Material Control 生產和物料控制
PCC Product control center 生產管制中心
PPC Production Plan Control 生產計劃控制
MC Material Control 物料控制
DC Document Center 資料中心
QE Quality Engineering 品質工程(部)
QA Quality Assurance 品質保證(處)
QC Quality Control 品質管制(課)
PD Product Department 生產部
LAB Laboratory 實驗室
IE Industrial Engineering 工業工程
R&D Research & Design 設計開發部
生產類
PCs Pieces 個(根,塊等)
PRS Pairs 雙(對等)
CTN Carton 卡通箱
PAL Pallet/skid 棧板
PO Purchasing Order 采購訂單
MO Manufacture Order 生產單
D/C Date Code 生產日期碼
ID/C Identification Code (供應商)識別碼
SWR Special Work Request 特殊工作需求
L/N Lot Number 批號
P/N Part Number 料號
OEM Original Equipment Manufacture 原設備製造
PC Personal Computer 個人電腦
CPU Central Processing Unit 中央處理器
A.S.A.P As Soon As Possible 盡可能快的
E-MAIL Electrical-Mail 電子郵件
N/A Not Applicable 不適用
QTY Quantity 數量
I/O input/output 輸入/輸出
NG Not Good 不行,不合格
C=0 Critical=0 極嚴重不允許
APP Approve 核準,認可,承認
CHK Check 確認
ASS\'Y Assembly 裝配,組裝
T/P True Position 真位度
5WIH When, Where, Who, What, Why, How to
6M Man, Machine, Material, Method, Measurement, Message
4MTH Man, Material, Money, Method, Time, How 人力,物力,財務,技術,時間(資源)
SQA Strategy Quality Assurance 策略品質保證
DQA Design Quality Assurance 設計品質保證
MQA Manufacture Quality Assurance 製造品質保證
SSQA Sales and service Quality Assurance 銷售及服務品質保證
LRR Lot Reject Rate 批退率
SPS Switching power supply 電源箱
DT Desk Top 臥式(機箱)
MT Mini-Tower 立式(機箱)
DVD Digital Video Disk
VCD Video Compact Disk
LCD Liquid Crystal Display
CAD Computer Aided Design
CAM Computer Aided Manufacturing
CAE Computer Aided Engineering
PCB Printed Circuit Board 印刷電路板
CAR Correction Action Report 改善報告
NG Not Good 不良
WDR Weekly Delivery Requirement 周出貨要求
TPM Total Production Maintenance 全面生產保養
MRP Material Requirement Planning 物料需計劃
OS Operation System 作業系統
TBA To Be Assured 待定,定缺
D/C Drawing Change
P/P Plans & Procedure
EMI Electrical-Music Industry 電子音樂工業
Electrical Magnetic Interference 電子干扰
RFI Read Frequency Input 讀頻輸入
MMC Maximum Material Condition
MMS Maximum Material Size
LMC Least Material Condition
LMS Least Material Size
LED lighting-emitting diode 發光二极管
QBR Quarter Business Record
CIP Continuous improvement process
FGI Forecasted Goal Inventory
CNC Computerized numeral controller
B2C Business to customer
B2B Business to business
AVL Approved vendor list
POP Procedure of packaging
EOL End of life
VDCS Vender defect correcting sheet
PDCS Process defect correcting sheet
GRN Goods receiving note
A/R Accounting receivable
A/P Accounting payable
一:常用術語
PCEG Personal Computer Enclosure group 個人電腦外設事業群(FOXTEQ)
CCBG Connector&cable business group
CPBG Competition business group
ESBG Enterprise system business group 鴻富錦\事業群
SABG system assembly business group 系統組裝事業群
NWE Net Work Enclosure
NSE Network system enclosure
NSG Network system group
NFE Network flexible enclosure
Foxcavity = HZ = Hong Zhun 鴻準
Stamping tool shop I 沖模一廠
Stamping tool shop II 沖模二廠
Prototype workshop 樣品中心
Steel factory 裁剪廠
PCE molding tooling workshop PCE塑模廠
Hua Nan test and measurement center 華南檢測中心
MPE mobile phone enclosure MPE
MBE mobile phone and notebook enclosure 明塑厂
MGE Alloy magnesium alloy enclosure 鎂合金
Engineer standard 工標
Document center (database center)資料中心
Design Center 設計中心
Painting 烤漆(廠) Assembly組裝(廠)
Stamping 沖壓(廠)
Education and Training教育訓練
proposal improvement/creative suggestion提案改善
Technological exchange and study 技術交流研習會
Technology and Development Committee 技術發展委員會
BS Brain Storming 腦力激蕩
QCC Quality Control Circle 品質圈
PDCA Plan Do Check Action 計劃 執行 檢查 總結
DCC delivery control center 交貨管制中心
3C
Computer 電腦類產品
Consumer electronics 消費性電子產品
Communication 通訊類產品
Core value(核心价值)
Love 愛心
Confidence 信心
Decision 決心
Corporate culture(公司文化)
Integration 融合
Responsibility 責任
Progress 進步
3T STRATEGY
Time to market 及時切入生產
Time to volume 及時大量生產
Time to money 及時大量交貨
FOUR CONTROL YSTEM 四大管制系統
Engineering control system 工程管制系統
Quality control system品質管制系統
Manufacturing control system生產管制系統
Management control system經營管制系統
7S
Classification整理(sorting, organization)-seiri
Regulation整頓(arrangement, tidiness)-seiton
Cleanliness清掃(sweeping, purity)-seiso
Conservation清洁(cleaning, cleanliness)-seiktsu
Culture教養(discipline)-shitsuke
Save 節約
Safety安全
品質保證類
FQC運\作類
ACC Accept 允收
REE Reject 拒收
CR Critical 極嚴重的
MAJ Major 主要的
MIN Minor 輕微的
P/N Part Number 料號
L/N Lot Number 批號
UAI Use As It 特采
制程統計品管專類
DIM Dimension 尺寸
DIA Diameter 直徑
N Number 樣品數
其它品質術語類
ZD Zero Defect 零缺點
通用之件類
DWG Drawing 圖面
系統文件類
部類
LAB Laboratory 實驗室
生產類
PCs Pieces 個(根,塊等)
PRS Pairs 雙(對等)
CTN Carton 卡通箱
PAL Pallet/skid 棧板
D/C Date Code 生產日期碼
L/N Lot Number 批號
P/N Part Number 料號
QTY Quantity 數量
NG Not Good 不行,不合格
CHK Check 確認
DT Desk Top 臥式(機箱)
NG Not Good 不良
D/C Drawing Change
EOL End of life
一:常用術語
Steel factory 裁剪廠
Design Center 設計中心
Stamping 沖壓(廠)
3C
Computer 電腦類產品
Communication 通訊類產品
Core value(核心价值)
Love 愛心
Confidence 信心
Decision 決心
Integration 融合
Responsibility 責任
Progress 進步
3T STRATEGY
7S
Save 節約
Safety安全
共6条
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
| 【分享开发笔记,赚取电动螺丝刀】墨水屏文本显示器被打赏¥25元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX软件读取HTS221温湿度被打赏¥22元 | |
| M5PAPERESP32EINKDEVKIT评测|使用MicroPython开发M5Paper被打赏¥15元 | |
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
| OK1126B-S开发板下多时段语音提示型电子时钟被打赏¥27元 | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
