vxWorks 6.2 中TFFS的问题,求助!!
Attaching to TFFS...
0xc816c0 (tRoot): checkStatus() ERROR line 44
0xc816c0 (tRoot): checkStatus() ERROR line 279
tffsDevCreate failed.
usrTffsConfig failed.
装载Image失败,我修改Boot参数,使用网络加载Image,VxWorks能正常引导,使用usrTffsConfig创建文件系统成功,使用devs命令可以看到设备:"/tffs0"!
据我推测,可能是MTD出现了问题,但又不知如何下手解决,请各高手指导!!!
关键词: vxWorks 问题 求助
在config.h中试一下下面的定义:
/*TFFS configuration*/
#define INCLUDE_TFFS
#ifdef INCLUDE_TFFS
#define INCLUDE_XBD
#define INCLUDE_XBD_TRANS
#define INCLUDE_XBD_BLKDEV
#define INCLUDE_XBD_BLK_DEV
#define INCLUDE_XBD_PART_LIB
#define INCLUDE_TFFS_SHOW
#define INCLUDE_TFFS_MOUNT
#define INCLUDE_DISK_UTIL
#define INCLUDE_MTD_AMD
#define INCLUDE_TL_FTL
#define INCLUDE_FS_MONITOR
#define INCLUDE_DOSFS /* dosFs file system */
#define INCLUDE_DOSFS_MAIN
#define INCLUDE_DOSFS_FAT
#define INCLUDE_DOSFS_DIR_VFAT
#define INCLUDE_DOSFS_DIR_FIXED
#define INCLUDE_DOSFS_CACHE
#define INCLUDE_SHOW_ROUTINES /* show routines for system facilities*/
#define INCLUDE_ERF /* Event reporting framework */
#define INCLUDE_DEVICE_MANAGER /* Device Manager */
#define INCLUDE_FS_EVENT_UTIL /* File system event utility */
#endif/*#ifdef INCLUDE_TFFS*/
我按你的方法试了一下,还是一样,你不是遇到过类似的问题么,你是怎么解决的,请赐教!
错误提示如下:
VxWorks System Boot
Copyright 1984-2005 Wind River Systems, Inc.
CPU: AMCC PowerPC 440epx - 440EPx Board
Version: VxWorks 6.2
BSP version: 2.0/1
Creation date: Apr 3 2008, 08:48:03
Press any key to stop auto-boot...
1
auto-booting...
boot device : tffs=0,0
unit number : 0
processor number : 0
host name : Host
file name : /tffs0/vxWorks
inet on ethernet (e) : 192.168.0.111
host inet (h) : 192.168.0.218
user (u) : target
ftp password (pw) : target
flags (f) : 0x0
noOfMTDs=1
Attaching to TFFS(0, 0, /tffs0/vxWorks)... 0xd0ba68 (tBoot): checkStatus() ERROR line 44
0xd0ba68 (tBoot): checkStatus() ERROR line 279
Error loading file: errno = 0x3d0001.
Can't load boot file!!
[VxWorks Boot]:
谢谢!!
你的问题跟我的具体原因可能不一样,症状很像,不了解你用的板子,下面两个参数是否需要修改
按我们当初的思路试试?
我在Config.h定义了以下宏:
#undef INCLUDE_MTD_CFIAMD
#undef INCLUDE_MTD_CFISCS
#undef INCLUDE_MTD_I28F016
#undef INCLUDE_MTD_I28F008
#undef INCLUDE_MTD_I28F008_BAJA
#undef INCLUDE_MTD_AMD
#ifdef INCLUDE_TFFS
#define INCLUDE_XBD /* Extended block device */
#define INCLUDE_XBD_BLK_DEV /* Extended block device */
#define INCLUDE_FS_MONITOR /* File system monitor */
#define INCLUDE_XBD_PART_LIB /* XBD partition creation support */
#define INCLUDE_DOSFS /* DOS filesystem */
#define INCLUDE_DOSFS_FAT /* DOS file system FAT12/16/32 handler */
#define INCLUDE_DOSFS_DIR_FIXED /* DOS File system old directory format handler */
#define INCLUDE_DOSFS_DIR_VFAT /* DOS file system VFAT directory handler */
#define INCLUDE_USER_FLASH
#define INCLUDE_NET_SHOW
#define INCLUDE_STARTUP_SCRIPT
#define INCLUDE_TFFS_DOSFS
#define INCLUDE_SYM_TBL
#define INCLUDE_STAT_SYM_TBL
#define INCLUDE_SHELL
#define INCLUDE_STANDALONE_SYM_TBL
#define INCLUDE_IO_SYSTEM
#endif
我想定义宏的位置在Config.h中的位置应该没有什么关系吧! 我也在Image的工程里查过,与TFFS有关的宏不知道有哪些?
而且我在使用Amcc-440EPx的时候,有时候不是很稳定,现在也是一头雾水,不知是硬件不稳定还是BSP不稳定?
我本来是想用vxWorks 6.3的,可是没有找到,也就只能将就用它了!!
Amcc-440EPx的BSP的还真有点挑战性,国内用的人不是很多,我们多交流吧!
实在没有办法了,我就从NOR-FLASH中划了一块区域存放IMAGE,大小为1MB。vxWorks6.2好象要比vxWorks5.5大多了,以至于板上的512KB ISP不能够用,所以也就在NOR-FLASH上想办法了!原来是想通过TFFS加载IMAGE的,没有成功!现在只有把IMAGE放到NOR-FLASH上去了,剩余的空间再做成文件系统TFFS,这种办法倒是成功了,不过就是调试起来麻烦一些了。因为板上的ISP是8-bits设备,而NOR-FLASH是16-bits设备,得修改440EPx的引导配置!
我所prjParams.h中有关于TFFS的宏定义在config.h又定义了一番,还是没有通过,晕~~~~~~
