ADIMM(advanced Dual In-line Memory Modules,高级双重内嵌式内存模块) AMR(Audio/Modem Riser;音效/调制解调器主机板附加直立插卡) AHA(Accelerated Hub Architecture,加速中心架构) ASK IR(Amplitude Shift Keyed Infra-Red,长波形可移动输入红外线) ATX: AT Extend(扩展型AT) BIOS(Basic Input/Output System,基本输入/输出系统) CSE(Configuration Space Enable,可分配空间) DB: Device Bay,设备插架 DMI(Desktop Management Interface,桌面管理接口) EB(Expansion Bus,扩展总线) EISA(Enhanced Industry Standard Architecture,增强形工业标准架构) EMI(Electromagnetic Interference,电磁干扰) ESCD(Extended System Configuration Data,可扩展系统配置数据) FBC(Frame Buffer Cache,帧缓冲缓存) FireWire(火线,即IEEE1394标准) FSB: Front Side Bus,前置总线,即外部总线 FWH( Firmware Hub,固件中心) GMCH(Graphics & Memory Controller Hub,图形和内存控制中心) GPIs(General Purpose Inputs,普通操作输入) ICH(Input/Output Controller Hub,输入/输出控制中心) IR(infrared ray,红外线) IrDA(infrared ray,红外线通信接口可进行局域网存取和文件共享) ISA(instruction set architecture,工业设置架构) MDC(Mobile Daughter Card,移动式子卡) MRH-R(Memory Repeater Hub,内存数据处理中心) MRH-S(SDRAM Repeater Hub,SDRAM数据处理心) MTH(Memory Transfer Hub,内存转换中心) NGIO(Next Generation Input/Output,新一代输入/输出标准) P64H(64-bit PCI Controller Hub,64位PCI控制中心) PCB(printed circuit board,印刷电路板) PCBA(Printed Circuit Board Assembly,印刷电路板装配) PCI: Peripheral Component Interconnect,互连外围设备 PCI SIG(Peripheral Component Interconnect Special Interest Group,互连外围设备专业组) POST(Power On Self Test,加电自测试) RNG(Random number Generator,随机数字发生器) RTC: Real Time Clock(实时时钟) KBC(KeyBroad Control,键盘控制器) SAP(Sideband Address Port,边带寻址端口) SBA(Side Band Addressing,边带寻址) SMA: Share Memory Architecture,共享内存结构 STD(Suspend To Disk,磁盘唤醒) STR(Suspend To RAM,内存唤醒) SVR: Switching Voltage Regulator(交换式电压调节) USB(Universal Serial Bus,通用串行总线) USDM(Unified System Diagnostic Manager,统一系统监测管理器) VID(Voltage Identification Definition,电压识别认证) VRM (Voltage Regulator Module,电压调整模块) ZIF: Zero Insertion Force, 零插力 主板技术 Gigabyte ACOPS: Automatic CPU OverHeat Prevention System(CPU过热****系统) SIV: System Information Viewer(系统信息观察) 磐英 ESDJ(Easy Setting Dual Jumper,简化CPU双重跳线法) 浩鑫 UPT(USB、PANEL、LINK、TV-OUT四重接口) 芯片组 ACPI(Advanced Configuration and Power Interface,先进设置和电源管理) AGP(Accelerated Graphics Port,图形加速接口) I/O(Input/Output,输入/输出) MIOC: Memory and I/O Bridge Controller,内存和I/O桥控制器 NBC: North Bridge Chip(北桥芯片) PIIX: PCI ISA/IDE Accelerator(加速器) PSE36: Page Size Extension 36-bit, 36位页面尺寸扩展模式 PXB: PCI Expander Bridge, PCI增强桥 RCG: RAS/CAS Generator,RAS/CAS发生器 SBC: South Bridge Chip(南桥芯片) SMB: System Management Bus(全系统管理总线) SPD(Serial Presence Detect,内存内部序号检测装置) SSB: Super South Bridge,超级南桥芯片 TDP: Triton Data Path(数据路径) TSC: Triton System Controller(系统控制器) QPA: Quad Port Acceleration(四接口加速)
