HEW的最新完整版本能下载到吗
The following MCU groups have been added to the support line:
- In R8C/Tiny series
R8C/2E, R8C/2F, R8C/2G, R8C/2H, R8C/2J, R8C/2K, R8C/2L
R8C/32A, R8C/33A, and R8C/35A groups
- In M16C/60 series
M16C/64 and M16C/65 groups
好像不是新建工程的问题。
我在一个a.c文件定义了一个变量unsigned short TXADDRESS = 0;在一个b.h头文件声明此变量extern unsigned short TXADDRESS; 在c.c文件中包含b.h文件,使用TXADDRESS 变量,但是编译时候就是出现: Error (ln30): E:\PaStack\Debug_M16C_E8_SYSTEM\c.r30 : '_TXADDRESS' value is undefined ,我查编译器手册,也找不到原因。 请问这种情况会是什么原因呢?
多谢,问题解决了。参考的网页 http://forum.eepw.com.cn/forum/main?url=http%3A%2F%2Fforum.eepw.com.cn%2Fthread%2F127922%2F1
http://www.renesasrulz.com/forum/m32c/812357125?set_language=ja&cl=ja
感谢 renesasstk 的回答。是字符集惹的祸,看来推动编译器统一采用unicode字符还是有必要的,错误出现的诡异。
EUC and SJIS are different character sets used for encoding characters beyond the standard ASCII-characters. Both are basically Japanese character sets supporting also multi-byte characters for Asian languages. But SJIS has often problems with special European characters, while EUC does not have such problems. 意思就是说sjis是默认的字符集,对于特殊的西文字符有问题,我记得安装软件时候让选地区,亚洲或者欧洲,不知道如果当时选了亚洲,如果选欧洲这个NCKIN和NCKOUT就不用改了。
| OrangePiZero2W系统被打赏¥33元 | |
