我们一般测试都用dB来表示麦克风的灵敏度,表示的在一定声压激励下麦克风的电平响应。现在有个客户给我发封E-mail,说我们的产品有三个灵敏度偏低,三个不良品他是这么描述的:
3pcs have defective microphone sensitivity:
#15 measurements from a 700Hz audio source at an amplitude of (.5V +/-0.60KHz) (1.5V +/-1.65KHz) (2.5V +/-1.90KHz)
#17 measurements from a 700Hz audio source at an amplitude of (.5V +/-0.50KHz) (1.5V +/-1.50KHz) (2.5V +/-1.85KHz)
#20 measurements from a 700Hz audio source at an amplitude of (.5V +/-0.60KHz) (1.5V +/-1.75KHz) (2.5V +/-1.95KHz)
All defects were verified on 3 IRAD test radios S/N: 37GA0767, 37GA0761, & 37GA0817.
而OK的产品他是这么描述的:
Microphone sensitivity rating is very good. Average measurements from a 700Hz audio source at an amplitude of (.5V +/-1.10KHz) (1.5V +/-1.94KHz) (2.5V +/-2.12)
我想请教论坛各位高手,这是怎么样的一个测试方法?其测试原理是什么?
叩谢了!搞不定客户要退我们100W的货- -
