请教两个问题:
1. 程序有时候编译能通过,运行(reset go) 时会弹出出现Progam counter is odd的错误,请问
是怎么回事,如何消除这个错误。
2. 还有一个是HEw里面用emum 的问题:
例如定义如下:
enum T_ANGLES
DEG350 = 63715,
DEG10 = 1820,
DEG50 = 9102,
DEG70 = 12743,
DEG110 = 20024,
DEG130 = 23665,
DEG170 = 30947,
DEG190 = 34588,
DEG230 = 41870,
DEG250 = 45511,
DEG290 = 52793,
DEG310 = 56434,
DEG22 = 4005,
DEG90 = 16384,
DEG285 = 51883
有的值超过了Int 的界限,会报错,请问有什么好的解决方案。一定要用
#define DEG350 63715
吗?
共6条
Progam Counter is odd
关键词: Progam Counter
第一个问题没遇到过,只能Google一下。
有两条信息相关。查查PC和SP指针吧。尤其是程序中用汇编改过什么的话。
Program counter is odd Since the program counter holds an odd value, execution of
the program is not possible.
If a PC or SP value is illegally set (e.g., an odd value) and the user program is
executed, an error message such as ‘Program counter is odd’ may be displayed
twice.
twice.
共6条
