// ATMEL Microcontroller Software Support - ROUSSET -
// The software is delivered "AS IS" without warranty or
// condition of any kind, either express, implied or
// statutory. This includes without limitation any warranty
// or condition with respect to merchantability or fitness
// for any particular purpose, or against the infringements of
// intellectual property rights of others.
// File: SAM9_SDRAM.mac
// User setup file for CSPY debugger.
// 1.1 08/Aug/06 jpp : Creation
// $Revision: 26510 $
__var __mac_i;
__var __mac_pt;
* execUserReset() : JTAG set initially to Full Speed
execUserReset()
__message "------------------------------ execUserReset ---------------------------------";
_MapRAMAt0(); //* Set the RAM memory at 0x00300000 & 0x00000000
__PllSetting(); //* Init PLL
__PllSetting100MHz();
__message "-------------------------------Set PC Reset ----------------------------------";
* execUserPreload() : JTAG set initially to 32kHz
execUserPreload()
__message "------------------------------ execUserPreload ---------------------------------";
__hwReset(0); //* Hardware Reset: CPU is automatically halted after the reset (JTAG is already configured to 32kHz)
__writeMemory32(0xD3,0x98,"Register"); //* Set CPSR
__initSDRAM(); //* Init SDRAM before load
_MapRAMAt0(); //* Set the RAM memory at 0x0020 0000 & 0x0000 0000
_InitRSTC(); //* Enable User Reset to allow execUserReset() execution
* _InitRSTC()
* Function description
* Initializes the RSTC (Reset controller).
* This makes sense since the default is to not allow user resets, which makes it impossible to
* apply a second RESET via J-Link
_InitRSTC() {
__writeMemory32(0xA5000001, 0xFFFFFD08,"Memory"); // Allow user reset
* __initSDRAM()
* Set SDRAM for works at 100 MHz
__initSDRAM()
//* Configure EBI Chip select
// pCCFG->CCFG_EBICSA |= AT91C_EBI_CS1A_SDRAMC;
// AT91C_CCFG_EBICSA ((AT91_REG *) 0xFFFFEF1C) // (CCFG) EBI Chip Select Assignement Register
__writeMemory32(0x0001003A,0xFFFFEE30,"Memory");
//* Configure PIOs
//* AT91F_PIO_CfgPeriph( AT91C_BASE_PIOC, AT91C_PC16_D16 to AT91C_PC16_D31
// pPio->PIO_ASR = periphAEnable; AT91C_PIOC_ASR ((AT91_REG *) 0xFFFFF870) // (PIOC) Select A Register
// pPio->PIO_BSR = periphBEnable;AT91C_PIOC_BSR ((AT91_REG *) 0xFFFFF874) // (PIOC) Select B Register
// pPio->PIO_PDR = (periphAEnable | periphBEnable); // Set in Periph mode
__writeMemory32(0xFFFF0000,0xFFFFF870,"Memory");
__writeMemory32(0x00000000,0xFFFFF874,"Memory");
__writeMemory32(0xFFFF0000,0xFFFFF804,"Memory");
//* psdrc->SDRAMC_CR = AT91C_SDRAMC_NC_9 | AT91C_SDRAMC_NR_13 | AT91C_SDRAMC_CAS_2 |
// AT91C_SDRAMC_NB_4_BANKS | AT91C_SDRAMC_DBW_32_BITS | AT91C_SDRAMC_TWR_2 | AT91C_SDRAMC_TRC_7 |
// AT91C_SDRAMC_TRP_2 | AT91C_SDRAMC_TRCD_2 | AT91C_SDRAMC_TRAS_5 | AT91C_SDRAMC_TXSR_8 ;
// __writeMemory32(0x85227259,0xFFFFEA08,"Memory");
__writeMemory32(0xA6339279,0xFFFFEA08,"Memory");
__sleep(100);
//* psdrc->SDRAMC_MR = 0x00000002; // Set PRCHG AL
__writeMemory32(0x00000002,0xFFFFEA00,"Memory");
//* *AT91C_SDRAM = 0x00000000; // Perform. PRCHG
__writeMemory32(0x00000000,0x20000000,"Memory");
__sleep(100);
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD; // Set 1st CBR
__writeMemory32(0x00000004,0xFFFFEA00,"Memory");
//* *(AT91C_SDRAM+4) = 0x00000001; // Perform. CBR
__writeMemory32(0x00000001,0x20000010,"Memory");
//* psdrc->SDRAMC_MR = 0x00000004; // Set 2 CBR
//* *(AT91C_SDRAM+8) = 0x00000002; // Perform. CBR
__writeMemory32(0x00000002,0x20000020,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD; // Set 3 CBR
//* *(AT91C_SDRAM+0xc) = 0x00000003; // Perform. CBR
__writeMemory32(0x00000003,0x20000030,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD; // Set 4 CBR
//* *(AT91C_SDRAM+0x10) = 0x00000004; // Perform. CBR
__writeMemory32(0x00000004,0x20000040,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD; // Set 5 CBR
//* *(AT91C_SDRAM+0x14) = 0x00000005; // Perform. CBR
__writeMemory32(0x00000005,0x20000050,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD; // Set 6 CBR
//* *(AT91C_SDRAM+0x18) = 0x00000006; // Perform. CBR
__writeMemory32(0x00000006,0x20000060,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD; // Set 7 CBR
//* *(AT91C_SDRAM+0x1c) = 0x00000007; // Perform. CBR
__writeMemory32(0x00000007,0x20000070,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD; // Set 8 CBR
//* *(AT91C_SDRAM+0x20) = 0x00000008; // Perform. CBR
__writeMemory32(0x00000008,0x20000080,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_LMR_CMD; // Set LMR operation
__writeMemory32(0x00000003,0xFFFFEA00,"Memory");
//* *(AT91C_SDRAM+0x24) = 0xcafedede; // Perform. LMR burst="1", lat="2"
__writeMemory32(0xCAFEDEDE,0x20000090,"Memory");
//* psdrc->SDRAMC_TR = (AT91C_MASTER_CLOCK * 7)/1000000; // Set Refresh Timer 390 for 25MHz (TR= 15.6 * F )
// // (F : system clock freq. MHz
__writeMemory32(0x000002b7,0xFFFFEA04,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_NORMAL_CMD; // Set Normal mode
__writeMemory32(0x00000000,0xFFFFEA00,"Memory");
//* *AT91C_SDRAM = 0x00000000; // Perform. Normal mode
__message "------------------------------- SDRAM Done at 133 MHz -------------------------------";
* _MapRAMAt0()
* Remap RAM at 0
_MapRAMAt0()
__var hold;
// Test and set Remap
hold = __readMemory32(0x00000000,"Memory");
__writeMemory32(0xAAAAAAAA,0x00000000,"Memory");
if(__readMemory32(0x00000000,"Memory") != 0xAAAAAAAA)
__writeMemory32(0x03,0xFFFFEE00,"Memory"); // toggle remap bits
else
__writeMemory32(hold,0x00000000,"Memory");
* __PllSetting()
* Initializes the PMC.
* 1. Enable the Main Oscillator
* 2. Configure PLL
* 3. Switch Master
__PllSetting()
if ((__readMemory32(0xFFFFFC30,"Memory")&0x3) != 0 ) {
//* Disable all PMC interrupt ( $$ JPP)
//* AT91C_PMC_IDR ((AT91_REG *) 0xFFFFFC64) //(PMC) Interrupt Disable Register
//* pPmc->PMC_IDR = 0xFFFFFFFF;
__writeMemory32(0xFFFFFFFF,0xFFFFFC64,"Memory");
//* AT91C_PMC_PCDR ((AT91_REG *) 0xFFFFFC14) //(PMC) Peripheral Clock Disable Register
__writeMemory32(0xFFFFFFFF,0xFFFFFC14,"Memory");
// Disable all clock only Processor clock is enabled.
__writeMemory32(0xFFFFFFFE,0xFFFFFC04,"Memory");
// AT91C_PMC_MCKR ((AT91_REG *) 0xFFFFFC30) // (PMC) Master Clock Register
__writeMemory32(0x00000001,0xFFFFFC30,"Memory");
__sleep(10000);
// write reset value to PLLA and PLLB
// AT91C_PMC_PLLAR ((AT91_REG *) 0xFFFFFC28) // (PMC) PLL A Register
__writeMemory32(0x00003F00,0xFFFFFC28,"Memory");
// AT91C_PMC_PLLBR ((AT91_REG *) 0xFFFFFC2C) // (PMC) PLL B Register
__writeMemory32(0x00003F00,0xFFFFFC2C,"Memory");
__sleep(10000);
__message "------------------------------- PLL Enable -----------------------------------------";
} else {
__message " ********* Core in SLOW CLOCK mode ********* "; }
* __PllSetting100MHz()
* Set core at 266 MHz and MCK at 133 MHz
* 133120000 * 2 = 266240000
__message "------------------------------- PLL Set at 133 MHz ----------------------------------";
//* pPmc->PMC_MOR = (( AT91C_CKGR_OSCOUNT & (0x40 <<8) | AT91C_CKGR_MOSCEN ));
__writeMemory32(0x00004001,0xFFFFFC20,"Memory");
__sleep(10000);
__sleep(10000);
//* AT91C_BASE_CKGR->CKGR_PLLAR = (AT91C_CKGR_SRCA | ((96 << 16) & AT91C_CKGR_MULA) |
// (AT91C_CKGR_PLLACOUNT | (AT91C_CKGR_OUTA_0 | (9);
// __writeMemory32(0x2060BF09,0xFFFFFC28,"Memory");
__writeMemory32(0x2081BF09,0xFFFFFC28,"Memory");
__sleep(10000);
// AT91C_BASE_PMC->PMC_PLLBR = BOARD_USBDIV| BOARD_CKGR_PLLB | BOARD_PLLBCOUNT | BOARD_MULB| BOARD_DIVB;
__writeMemory32(0x20813F0C,0xFFFFFC2C,"Memory");
__sleep(10000);
//* AT91C_BASE_PMC->PMC_MCKR = AT91C_PMC_CSS_PLLA_CLK | AT91C_PMC_PRES_CLK | AT91C_PMC_MDIV_2;;
__writeMemory32(0x00000102,0xFFFFFC30,"Memory");
__sleep(10000);
/// Frequency of the board main oscillator.
#define BOARD_MAINOSC 18432000
/// Master clock frequency (when using board_lowlevel.c).
#define BOARD_MCK 133120000 //((18432000 * 97 / 9) / 2)
#define BOARD_OSCOUNT (AT91C_CKGR_OSCOUNT & (64 << 8))
#define BOARD_CKGR_PLLA (AT91C_CKGR_SRCA | AT91C_CKGR_OUTA_2)
#define BOARD_PLLACOUNT (63 << 8)
//#define BOARD_MULA (AT91C_CKGR_MULA & (96 << 16))
//#define BOARD_DIVA (AT91C_CKGR_DIVA & 9)
#define BOARD_MULA (AT91C_CKGR_MULA & (129 << 16))
#define BOARD_PRESCALER AT91C_PMC_MDIV_2
#define BOARD_USBDIV AT91C_CKGR_USBDIV_2
#define BOARD_CKGR_PLLB AT91C_CKGR_OUTB_0
#define BOARD_PLLBCOUNT BOARD_PLLACOUNT
#define BOARD_MULB (124 << 16)
#define BOARD_DIVB 12
// CFG Control Register
WRITE(AT91C_BASE_SDRAMC, SDRAMC_CR, AT91C_SDRAMC_NC_9
| AT91C_SDRAMC_NR_13
| AT91C_SDRAMC_CAS_2
| sdrc_dbw
| AT91C_SDRAMC_TWR_2
| AT91C_SDRAMC_TRC_7
| AT91C_SDRAMC_TRP_2
| AT91C_SDRAMC_TRCD_2
| AT91C_SDRAMC_TRAS_5
| AT91C_SDRAMC_TXSR_8);
