电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » VHDL按键去抖
共3条 1/1 1 跳转至页
VHDL按键去抖
2009-03-31 12:45:54     打赏
VHDL按键去抖
按键检测需要消抖,一般有硬件和软件两种方式。硬件就是加去抖动电路,这样从根本上解决按键抖动问题。除了用专用电路以外,用可编程FPGA或者CPLD设计相应的逻辑和时序电路,对按键信号进行处理,同样可以达到去抖动的目的。
        本例中用状态机实现了消抖电路: 端口描述:clk 输入检测时钟;reset 复位信号;din 原始按键信号输入; dout 去抖动输出信号。
VHDL源码如下: LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all; ENTITY xiaod IS
PORT
   clk      : IN STD_LOGIC ;
   reset   : IN STD_LOGIC ;
   din    : IN STD_LOGIC ;
   dout   : OUT STD_LOGIC
END ENTITY; ARCHITECTURE RTL OF xiaod IS
TYPE state IS( s0,s1,s2,s3);
SIGNAL pre_s, next_s: state; BEGIN
P0:PROCESS( reset, clk )
BEGIN
   if reset = '0' then
    pre_s <= s0;
   elsif rising_edge( clk ) then
    pre_s <= next_s;
   else
    null;
   end if;
END PROCESS P0;
P1:PROCESS( pre_s, next_s, din )
BEGIN
   case pre_s is
    when s0 =>
     dout <= '1';
     if din = '1' then
      next_s <= s0;
     else
      next_s <= s1;
     end if;
    when s1 =>
     dout <= '1';
     if din = '1' then
      next_s <= s0;
     else
      next_s <= s2;
     end if;
    when s2 =>
     dout <= '1';
     if din = '1' then
      next_s <= s0;
     else
      next_s <= s3;
     end if;
    when s3 =>
     dout <= '0';
     if din = '1' then
      next_s <= s0;
     else
      next_s <= s1;
     end if;
   end case;
END PROCESS P1; END RTL;  多按键去抖动电路VHDL源码,按键个数参数化,每个按键处理调用了上面的模块:
LIBRARY ieee;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all; ENTITY Nxiaod IS
GENERIC( width: positive:= 5 );
PORT
   din    : IN STD_LOGIC_VECTOR( width - 1 DOWNTO 0);
   dout   : OUT STD_LOGIC_VECTOR( width - 1 DOWNTO 0)
END ENTITY; ARCHITECTURE RTL OF Nxiaod IS
COMPONENT xiaod IS
PORT
END COMPONENT; BEGIN g1: FOR i IN 0 to width - 1 GENERATE
ux: xiaod port map( clk => clk, reset => reset, din => din(i), dout => dout(i)); END GENERATE; END RTL;
关键词: 按键     去抖     LOGIC
2009-04-02 14:08:51     打赏
这个有意思,留个脚印
2020-07-02 14:44:06     打赏
感谢楼主分享
共3条 1/1 1 跳转至页
