共5条
IAR强大的debug功能
C-SPY Debugger
Complex code and data breakpoints
C/EC++ call stack with parameters
Complete support for stack unwinding even at high optimization levels
I/O and interrupt simulation
Application program system calls emulated by the host
Versatile monitoring of registers, structures, call chain, locals, global variables and peripheral registers
Tracing
Sample projects
I/O register definition files
Fine-grain single stepping
Profiling and code coverage
[color=#FF0000]ARM Angel debug monitor support
CMX-RTX RTOS plug-in module included
Express Logic ThreadX RTOS plug-in module included
Compatibility with MicroC/OS-II RTOS by Micrium [/color]
[align=right][color=#000066][此贴子已经被作者于2003-9-1 11:46:37编辑过][/color][/align]
关键词: 大的 debug 功能
共5条
