library ieee;
use ieee.std_logic_1164.all;
entity h_adder2 is
port(a,b:in std_logic;
so,co:out std_logic);
end;
architecture bhv of h_adder2 is
signal ab:std_logic_vector(1 downto 0);
begin
ab<=a&b;
process(ab)
begin
case ab is
when "00"=>so<='0';co<='0';
when "01"=>so<='1';co<='0';
when "10"=>so<='1';co<='0';
when "11"=>so<='0';co<='1';
end case;
end process;
end;
library ieee;
entity or2a is
c:out std_logic);
end;
architecture bhv of or2a is
begin
c<=a or b;
end;
library ieee;
entity f_adder is
port(ain,bin,cin:in std_logic;
sum,count:out std_logic);
end;
architecture bhv of f_adder is
component h_adder
co,so:out std_logic);
end component;
component or2a
c:out std_logic);
end component;
signal d,e,f:std_logic;
begin
u1:h_adder port map(a=>ain,b=>bin,co=>d,so=>e);
u2:h_adder port map(a=>e,b=cin,co=>f,so=>sum);
u3:or2a port map(a=>d,b=>f,c=>count);
end;
这个程序编译时倒数第三行出错 错误提示为Error (10437): VHDL Association List error at f_adder.vhd(53): positional associations must be listed before named associations
麻烦各位网友帮忙解释一下撒!!!
