我编写的状态机,在功能仿真的时候可以完成我要的功能,可是为什么下到板子里功能就不对了,仿真和实际差在哪里呢
可是在下到板子后RD一直是高电平,没有出来上图的结果?
附代码;module ADCNT(D,Clk,Busy,
,RESET,CS,ConvSTX,RD,Lock0,Q,ret,flag);
input [15:0] D;
input Clk,Busy,ret;
output ConvSTX,RESET;
output RD,Lock0,CS,flag;
output [15:0] Q;
reg [15:0] REGL;
reg ConvSTX,RESET,flag;
wire CS;
wire [15:0] Q;
reg Lock,RD;
parameter st0=4'b0000,st1=4'b0001,st2=4'b0010,st3=4'b0011,st4=4'b0100,st5=4'b0101;
parameter st6=4'b0110,st7=4'b0111,st8=4'b1000,st9=4'b1001,st10=4'b1010,st11=4'b1011;
parameter st12=4'b1100,st13=4'b1101,st14=4'b1110,st15=4'b1111;
reg [3:0] current_states, next_states;
assign CS= 0;
assign Q= REGL;
assign Lock0= Lock;
always@(current_states)
begin
case(current_states)
st0:begin
RESET<=0;
ConvSTX<= 0;
Lock<=0;
RD<=1;
flag<=1;
next_states<=st1;
end //Initial
st1:begin
RESET<=1;
ConvSTX<= 1;
Lock<= 0;
RD<= 1;
flag<=0;
next_states<= st2;
end //启动采样
st2:begin
RESET<=1;
ConvSTX<= 1;
Lock<= 0;
flag<=1; RD<= 1;
if(Busy==0)
begin
RD<=1;
next_states<= st3;
end
else
next_states<= st2;
end //如果busy为0 转换结束 进入状态st3
st3: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 1;
RD=0;
flag<=0;
next_states<= st4;
end //第一路转换结果储存
st4: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 0;
RD=1;
flag<=1;
next_states<= st5;
end //将RD拉高
st5: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 1;
RD=0;
flag<=0;
next_states<= st6;
end //第二路转换结果储存
st6: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 0;
RD=1;
flag<=1;
next_states<= st7;
end //将RD拉高
st7: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 1;
RD=0;
flag<=0;
next_states<= st8;
end //第三路转换结果储存
st8: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 0;
RD=1;
flag<=1;
next_states<= st9;
end //将RD拉高
st9: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 1;
RD=0;
flag<=0;
next_states<= st10;
end //第四路转换结果储存
st10: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 0;
RD=1;
flag<=1;
next_states<= st11;
end //将RD拉高
st11: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 1;
RD=0;
flag<=0;
next_states<= st12;
end //第五路转换结果储存
st12: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 0;
RD=1;
flag<=1;
next_states<= st13;
end //将RD拉高
st13: begin
RESET<=1;
ConvSTX<= 1;
Lock<= 1;
RD=0;
flag<=0;
next_states<= st14;
end //第六路转换结果储存
st14: begin
RESET<=1;
ConvSTX<= 1;
Lock<=0;
RD<=1;
flag<=1;
next_states<=st0;
end
default:begin
RESET<=0;
next_states<= st0;
end
endcase
end
always@(posedge Clk)
begin
if(ret)
//RESET<=0;
current_states<= next_states;
else
current_states<=st0;
end
always@(posedge Lock)
begin
REGL <= D;
end //如果lock上升沿来了 将AD7656输出的结果送给REGL
endmodule
还请大家帮忙看看
