电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 继续求助状态机的问题
共6条 1/1 1 跳转至页
继续求助状态机的问题
2009-08-14 16:30:06     打赏
我编写的状态机,在功能仿真的时候可以完成我要的功能,可是为什么下到板子里功能就不对了,仿真和实际差在哪里呢
可是在下到板子后RD一直是高电平,没有出来上图的结果?
附代码;module ADCNT(D,Clk,Busy,
      ,RESET,CS,ConvSTX,RD,Lock0,Q,ret,flag);
input [15:0] D;
input Clk,Busy,ret;
output ConvSTX,RESET;
output RD,Lock0,CS,flag;
output [15:0] Q;
reg [15:0] REGL;
reg ConvSTX,RESET,flag;
wire CS;
wire [15:0] Q;
reg Lock,RD;
parameter st0=4'b0000,st1=4'b0001,st2=4'b0010,st3=4'b0011,st4=4'b0100,st5=4'b0101;
parameter st6=4'b0110,st7=4'b0111,st8=4'b1000,st9=4'b1001,st10=4'b1010,st11=4'b1011;
parameter st12=4'b1100,st13=4'b1101,st14=4'b1110,st15=4'b1111;
reg [3:0] current_states, next_states;
 assign CS= 0;
 assign Q= REGL;
 assign Lock0= Lock;
 always@(current_states)
  begin
      case(current_states)
    st0:begin
        RESET<=0;
         ConvSTX<= 0;
            Lock<=0;
            RD<=1;
            flag<=1;
            next_states<=st1;
         end //Initial
    st1:begin
      RESET<=1;
     ConvSTX<= 1;
     Lock<= 0;
     RD<= 1;
      flag<=0;
     next_states<= st2;
          end //启动采样
    st2:begin
     RESET<=1;
     ConvSTX<= 1;
     Lock<= 0;
     flag<=1;        RD<= 1;
     if(Busy==0)
      begin
        RD<=1;
       next_states<= st3;
      end
     else
      next_states<= st2;
        end //如果busy为0 转换结束 进入状态st3
    st3: begin
    RESET<=1;
    ConvSTX<= 1;
     Lock<= 1;
     RD=0;
     flag<=0;
     next_states<= st4;
         end //第一路转换结果储存
  st4: begin
    RESET<=1;
    ConvSTX<= 1;
     Lock<= 0;
     RD=1;
     flag<=1;
      next_states<= st5;
        end //将RD拉高
  st5: begin
    RESET<=1;
    ConvSTX<= 1;
     Lock<= 1;
     RD=0;
     flag<=0;
      next_states<= st6;
         end //第二路转换结果储存
     st6: begin
     RESET<=1;
    ConvSTX<= 1;
     Lock<= 0;
      RD=1;
      flag<=1;
     next_states<= st7;
         end //将RD拉高
     st7: begin
     RESET<=1;
   ConvSTX<= 1;
     Lock<= 1;
      RD=0;
      flag<=0;
     next_states<= st8;
         end //第三路转换结果储存
    st8: begin
    RESET<=1;
    ConvSTX<= 1;
     Lock<= 0;
     RD=1;
      flag<=1;
     next_states<= st9;
         end //将RD拉高
    st9: begin
    RESET<=1;
   ConvSTX<= 1;
     Lock<= 1;
     RD=0;
     flag<=0;
     next_states<= st10;
         end //第四路转换结果储存
     st10: begin
     RESET<=1;
     ConvSTX<= 1;
     Lock<= 0;
     RD=1;
     flag<=1;
     next_states<= st11;
         end //将RD拉高
    st11: begin
     RESET<=1;
     ConvSTX<= 1;
     Lock<= 1;
     RD=0;
     flag<=0;
     next_states<= st12;
         end //第五路转换结果储存
     st12: begin
     RESET<=1;
     ConvSTX<= 1;
     Lock<= 0;
     RD=1;
     flag<=1;
     next_states<= st13;
         end //将RD拉高
     st13: begin
     RESET<=1;
     ConvSTX<= 1;
     Lock<= 1;
     RD=0;
     flag<=0;
     next_states<= st14;
         end //第六路转换结果储存
     st14: begin
     RESET<=1;
       ConvSTX<= 1;
           Lock<=0;
           RD<=1;
           flag<=1;
           next_states<=st0;
           end
    default:begin
    RESET<=0;
      next_states<= st0;
     end
   endcase
  end
always@(posedge Clk)
  begin
   if(ret)
   //RESET<=0;
   current_states<= next_states;
else
    current_states<=st0;
    end
always@(posedge Lock)
  begin
   REGL <= D;
  end //如果lock上升沿来了 将AD7656输出的结果送给REGL
 endmodule
还请大家帮忙看看
关键词: 继续     求助     状态机     问题     RESET     ConvST
2009-08-15 22:07:48     打赏
可是我的本意就是系统一上电就执行current_states<= next_states; 这样它就进入了状态机,只有当要复位的时候ret才给低电,现在问题就是下到板子里后就没有任何反应,ConvSTX一直为高电平,按下ret会有个低电平出现,可是RD与flag根本就一直持续高电平,不明白为什么没有进入状态!
2009-08-19 10:57:55     打赏
我下进板子后 ConvSTX,RD flag RESET一直为高电平,ret上电为高,按下ret后ConvSTX ,RESET为低电平,RD flag没有任何反应
2009-08-21 19:52:58     打赏
有人帮忙吗?这个问题还是没有解决,我在组合逻辑中改用阻塞赋值结果还是一样.很奇怪!
2009-08-24 17:24:24     打赏
我在按照状态机的写法改一下,我不间断的间歇性按复位键也不行,进入的状态也不是st0,应该不是复位键的问题
2009-08-25 10:20:04     打赏
感谢版主Jason_Zhang的帮忙提醒,我重新调整了一下busy信号,现在状态机可以运行了,只是波形很差,稍后我会传上一些图片,感觉他的波形大体有我想要的样子,可是有一些杂波。先去照图!
共6条 1/1 1 跳转至页
