电子产品世界 » 论坛首页 » 企业专区 » Renesas » Get Over It —— 对iodefine.h文件的理解
共14条 1/2 1 2 › 跳转至页
2009-11-22 16:03:42     打赏
GPIOCtrl.rarHEW在创建工程的时候会生成一些文件,今天针对通用输入输出进行控制,发现由HEW生成的iodefine.h文件非常好用,先将对通用输入输出(PIO)部分的理解跟大家分享。
在iodefine.h中,通用输入输出的控制定义了两部分结构体:控制寄存器结构体st_pfc和数据寄存器结构体st_pn(n表示端口组A、B、E和F)。
1.控制寄存器结构体st_pfc
a) 结构体变量理解
控制器结构体的定义如下(以Port A为例):
union
{ /* PAIORL       */
 unsigned short WORD;/*  Word Access */
 struct {/*  Byte Access */
       unsigned char H;/*    High      */
       unsigned char L; /*    Low       */
       }       BYTE;/*              */
 struct {/*  Bit  Access */
       unsigned char B15:1;/*    Bit 15    */
       unsigned char B14:1;/*    Bit 14    */
       unsigned char B13:1;/*    Bit 13    */
       unsigned char B12:1;         /*    Bit 12    */
       unsigned char B11:1;         /*    Bit 11    */
       unsigned char B10:1;         /*    Bit 10    */
       unsigned char B9 :1;         /*    Bit  9    */
       unsigned char B8 :1;         /*    Bit  8    */
       unsigned char B7 :1;         /*    Bit  7    */
       unsigned char B6 :1;         /*    Bit  6    */
       unsigned char B5 :1;         /*    Bit  5    */
       unsigned char B4 :1;         /*    Bit  4    */
       unsigned char B3 :1;         /*    Bit  3    */
       unsigned char B2 :1;         /*    Bit  2    */
       unsigned char B1 :1;         /*    Bit  1    */
       unsigned char B0 :1;         /*    Bit  0    */
       }       BIT;                 /*              */
 }           PAIORL;                 /*              */
 char              wk1[8];                 /*              */
 union { /* PACRL4       */
       unsigned short WORD;                /*  Word Access */
              unsigned char H;             /*    High      */
             }       BYTE;                /*              */
       unsigned char       :1;      /*              */
       unsigned char PA15MD:3;      /*    PA15MD    */
       unsigned char PA14MD:3;      /*    PA14MD    */
       unsigned char PA13MD:3;      /*    PA13MD    */
       unsigned char PA12MD:3;      /*    PA12MD    */
  }       BIT;                 /*              */
}           PACRL4;                 /*              */
union {                                   /* PACRL3       */
       struct {                            /*  Byte Access */
             }       BYTE;                /*              */
      struct {                            /*  Bit  Access */
             unsigned char PA11MD:3;      /*    PA11MD    */
            unsigned char PA10MD:3;      /*    PA10MD    */
             unsigned char PA9MD :3;      /*    PA9MD     */
             unsigned char PA8MD :3;      /*    PA8MD     */
            }       BIT;                 /*              */
      }           PACRL3;                 /*              */
     union {                                   /* PACRL2       */
                 }       BYTE;                /*              */
                 unsigned char PA7MD:3;       /*    PA7MD     */
                unsigned char PA6MD:3;       /*    PA6MD     */
              unsigned char PA5MD:3;       /*    PA5MD     */
              unsigned char PA4MD:3;       /*    PA4MD     */
                }       BIT;                 /*              */
       }           PACRL2;                 /*              */
  union {/* PACRL1       */
              }       BYTE;                /*              */
              unsigned char PA3MD:3;       /*    PA3MD     */
              unsigned char PA2MD:3;       /*    PA2MD     */
             unsigned char PA1MD:3;       /*    PA1MD     */
             unsigned char PA0MD:3;       /*    PA0MD     */
         }       BIT;                 /*              */
        }           PACRL1;                 /*              */
Ø PAIORL 输入/输出设定寄存器联合体。 由双字节变量WORD,两个单字节变量组成的结构体变量BYTE,按位定义的结构体变量BIT组成的联合体。此联合体占用16bit的空间。WORD可对Port A中所有的I/O口进行输出/输出的批量设定。BYTE可对Port A中的高8pins和低8 pins进行分开设定。而BIT可对PortA中每个I/O进行单独设定。
Ø PACRLn Port A模式设定寄存器。WORD,BYTE,BIT可对PortA中所有的I/O口进行批量设定,分组设定和单独设定。
Ø Wkl[8] 未使用到的地址空间,可以计算一下,PACRL4的偏移地址(0x110)与PAIORL(0x106)相差4个WORD,也就是8个Bytes。所以定义的wkl[8]可理解为用于计算偏移地址。
b) 用法举例
假定Port A中的第15、7口左右通用输出口。可按下面方式设定:
批量设定: PFC.PAIOL.WORD |= 0x8080://1设定为输出
分组设定:PFC.PAIOL.BYTE.H |=0x80;
PFC.PAIOL.BYTE.L |=0x80;
单独设定:PFC.PAIOL.BIT.B15 =1;
PFC.PAIOL.BIT.B7=1;
2.数据寄存器结构体st_pn
a) 结构体变量理解
struct st_pa { /* struct PA    */
     union { /* PADRL        */
                }       BYTE;                 /*              */
              unsigned char B15:1;          /*    Bit 15    */
              unsigned char B14:1;          /*    Bit 14    */
              unsigned char B13:1;          /*    Bit 13    */
          }       BIT;                  /*              */
     }            DRL; //此处省略PRL的定义
Ø 同理,WORD,BYTE和BIT成员变量可分别对Port A的I/O口状态进行批量设定,分组设定和单独设定。
b) 用法
假定要是PortA中的第15口输出1,第7口输出0。可按下列方式实现:
批量处理方式: PA.DRL.WORD |= 0x8000;
PA.DRL.WORD &= 0xFF7F;//不改变其他端口状态
分组设定方式:PA.DRL.BYTE.H |=0x80;
PA.DRL.BYTE.L &= 0x7F;
单独设定方式:PA.DRL.BIT.B15 = 1;
PA.DRL.BIT.B7 =0;
3.地址指向
#define PFC    (*(volatile struct st_pfc   *)0xFFFFD106)/* PFC   Address*/
#define PA     (*(volatile struct st_pa    *)0xFFFFD102)/* PA    Address*/
通过以上宏定义的方式将对应的寄存器基址指向对应的地址。
4.小结
这种实现方式具有以下特定:
Ø 通过结构体打包PIO模块控制和数据寄存器,程序结构严谨。
Ø 直接地址操作,程序效率高。
Ø 多种设定方式,应用灵活。
Ø 单独设定方式使程序可读性强。
此方式可借鉴到其他单片机的C语言中。用于提高程序的执行效率和代码质量。
可访问我的博客查看。http://johnny2009.spaces.eepw.com.cn/articles/article/item/68010
附件是我建立的工程,实现跑马灯。
目前在SH-Stick的小板子上初步确定可实现以下应用:I/O控制,I/O中断,定时器,时钟振荡,A/D,看门狗,串行通信(要RS232转接)。如果有实现,再share出来跟大家分享,希望跟大家共同进步!
关键词: iodefine.h     文件     理解     结构     struc
2009-11-22 16:48:57     打赏
这个要顶~~~~~~~
2009-11-22 18:51:04     打赏
一些好的宏定义可以极大地方便变成,想当初我学ARM时,专门写了一大堆宏定义用来实现IO操作
2009-11-23 09:52:56     打赏
宏定义
用的方便!
超好.
2009-11-23 13:10:33     打赏
真的很好,谢谢lz!
2009-11-23 17:57:50     打赏
个人建议:
b) 用法
批量处理方式:
PA.PADRL.WORD |= 0x8000;
PA.PADRL.WORD &= 0xFFF7;//不改变其他端口状态
分组设定方式:
PA.PADRL.BYTE.H |=0x80;
PA.PADRL.BYTE.L &= 0xF7;
单独设定方式:
PA.PADRL.BIT.B15 = 1;
PA.PADRL.BIT.B7 =0;
改为
b) 用法
#define BIT15 (1<<15)
#define BIT14 (1<<14)
#define BIT1(1<<1)
#define BIT0 (1<<0)
批量处理方式:
PA.PADRL.WORD |= 0x8000;//改为PA.PADRL.WORD |= BIT15;
PA.PADRL.WORD &= 0xFFF7;//改为PA.PADRL.WORD &= ~BIT7;这里楼主好像就用了错误的值
分组设定方式:
PA.PADRL.BYTE.H |=0x80;//改为PA.PADRL.BYTE.H |=(BIT15>>8);
PA.PADRL.BYTE.L &= 0xF7;//改为PA.PADRL.BYTE.L &= ~BIT7;这里楼主好像就用了错误的值
单独设定方式:
PA.PADRL.BIT.B7 =0;
这样做的优点是不用你自己计算位组合的值,设置任意单个位或者多个位组合都很方便,比如PA.PADRL.WORD |= (BIT15|BIT12|BIT6)。
但这样做存在一个问题,程序是否有高效率会依赖编译器的聪明程度,通常一个好的编译器应该是自动将有关宏定义的运算结果计算出来,比如上面的(BIT15|BIT12|BIT6)在预处理的时候就自动换算为0x9040。但不好的编译器可能将这一条C代码分解成三个或操作来完成。
2009-11-24 09:04:42     打赏
非常感谢楼上的建议。
你的用法更加直观,但是关于I/O端口控制,如果强调程序的可读性,当然可采用I/O独立设定的方式;如果强调效率,就采用批量设定的方式,效率更高。
另外,应用举例中选择的值应该是没有错的,欢迎讨论。
2009-11-24 09:06:18     打赏
应该是0xFF7F和0x7F
谢谢sjdai拍
2009-11-24 09:08:38     打赏
帖子已改正sjdai发现的错误,非常抱歉!同时再次感谢sjdai!
2009-11-24 19:30:07     打赏
自动生成的还不错,以后在用别家芯片是也可以模仿着这样来定义
共14条 1/2 1 2 › 跳转至页
