鱼板寄存器写入问题
这是rominit.S开始的一段,当运行到下面斜杠的位置就飞了,我通过屏蔽代码调试发现第一个寄存器是可以设的,后面的就不行了,请大侠指点
/* disable interrupts in CPU and switch to SVC32 mode */
MRS r1, cpsr /* From cpsr */
BIC r1, r1, #MASK_MODE /* clear mode */
ORR r1, r1, #MODE_SVC32 | I_BIT | F_BIT /* set supervisor mode & clear IRQ and FIQ */
MSR cpsr, r1 /* To cpsr */
MOV r13, r0 /* Save starttype in r13 so that r0 can be used for other purposes */
* CPU INTERRUPTS DISABLED
* disable individual interrupts in the interrupt controller
LDR r2, L$_SBCARM7Intmsk /* R2->interrupt controller */
MVN r1, #0 /* &FFFFFFFF */
STR r1, [r2] /* disable all interrupt sources */
* If not BOOT_COLD, bypass memory configuration, memory region
* switching etc.
CMP r0, #BOOT_COLD
BNE JumpPos
LDR r0, L$_SBCARM7Syscfg
LDR r1, L$_SysCfgSdram
STR r1, [r0] /* Cache,WB disable */
LDR r1, L$_SystemInitDataSDRAM
LDR r2, L$_SystemInitDataSDRAM + 0x04
LDR r3, L$_SystemInitDataSDRAM + 0x08
LDR r4, L$_SystemInitDataSDRAM + 0x0c
LDR r5, L$_SystemInitDataSDRAM + 0x10
LDR r6, L$_SystemInitDataSDRAM + 0x14
LDR r7, L$_SystemInitDataSDRAM + 0x18
LDR r8, L$_SystemInitDataSDRAM + 0x1c
LDR r9, L$_SystemInitDataSDRAM + 0x20
LDR r10,L$_SystemInitDataSDRAM + 0x24
LDR r11,L$_SystemInitDataSDRAM + 0x28
LDR r12,L$_SystemInitDataSDRAM + 0x2c
LDR r0, L$_SBCARM7Extdbwth /* Extdbwth Offset : 0x3010 */
STMIA r0, {r1-r12} /*只能运行到这里*//////////////////////////////////////////////
LDR r1, L$_ClkCon
LDR r0, L$_SBCARM7ClkCon /* CLKCON Offset : 0x3000 */
STR r1, [r0]
LDR r1, L$_ExtACon
LDR r2, L$_ExtACon + 0x04
LDR r0, L$_SBCARM7ExtACon /* EXTACON Offset : 0x3008 */
STMIA r0, {r1-r2}
关键词: 鱼板 寄存器 写入 问题 SystemInitDa
