电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » Synplify 9.6.2下载(分享)
共589条 37/59 |‹ ‹ 35 36 37 38 39 40 › ›| 跳转至页
2011-09-22 14:57:53     打赏
361楼
下来试试.
2011-09-27 17:23:10     打赏
362楼
多谢了!
2011-10-06 14:23:39     打赏
363楼
有用吗?
2011-10-08 07:42:51     打赏
364楼
It's wonderful. Thank you very uch.
2011-10-10 08:33:36     打赏
365楼
找了好久才发现这里,太感谢楼主了。
2011-10-14 13:14:20     打赏
366楼
正在找~
2011-10-18 10:33:12     打赏
367楼
谢谢!
2011-10-18 20:51:11     打赏
368楼
thanks
(function(sogouExplorer){ sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location); if (typeof comSogouWwwStop == "undefined"){ var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&"; window.comSogouWwwStop = true; setTimeout(function(){ if (!document.location || document.location.toString().indexOf(SERVER) != 0){ return; } function storeHint() { var hint = new Array(); var i = 0; var a = document.getElementById("hint_" + i); while(a) { hint.push({"text":a.innerHTML, "url":a.href}); i++; a = document.getElementById("hint_" + i); } return hint; } if (document.getElementById("windowcloseit")){ document.getElementById("windowcloseit").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "closeit"}); } var flag = false; document.getElementById("bbconfig").onclick = function(){ flag = true; sogouExplorer.extension.sendRequest({cmd: "config"}); return false; } document.body.onclick = function(){ if (flag) { flag = false; } else { sogouExplorer.extension.sendRequest({cmd: "closeconfig"}); } };/* document.getElementById("bbhidden").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "hide"}); return false; } */ var sogoutip = document.getElementById("sogoutip"); var tip = {}; tip.word = sogoutip.innerHTML; tip.config = sogoutip.title.split(","); var hint = storeHint(); sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}}); }else{ if (document.getElementById("windowcloseitnow")){ sogouExplorer.extension.sendRequest({cmd: "closeit", data: true}); } } }, 0); } })(window.external.sogouExplorer(window,7));
2011-10-28 10:48:20     打赏
369楼
仔细看看
2011-10-28 11:56:46     打赏
370楼
谢谢,太感谢了
