QUICK START GUIDE
Product Deliverable
Before using the product, please make sure the package contains the following items:
1、Easy Kit (Easy BGMA + Easy EV-B): 1
2、Quick start guide (This document): 1
Quick Start Process
3、 Install “F2MC-8L/8FX Family SOFTUNE Workbench” on PC if it hasn’t been
installed. The software could be downloaded from the web address:
http://www.fujitsu.com/cn/fmc/services/mcu/tools/mb95200.html
4、Set Mode Switch on Easy Kit to debug mode as below:
5、Connect Easy Kit to PC USB interface.
6、 Install BGM adaptor USB driver on PC if it hasn’t been installed, which is in
SOFTUNE installation folder: …\Softune\Drivers.
7、 Copy sample code to user folder, which could be downloaded from our web site.
8、Then Users can open the sample project and start debug in SOFTUNE workbench
on PC. Detailed can refer to SOFTUNE operation manual.
Related Manuals
You should refer to the following manuals as well:
1、“HARDWARE MANUAL” for each type of microcontroller
2、“DATA SHEET” for each type of microcontroller
3、“SOFTUNE Workbench OPERATION MANUAL”
4、 “SOFTUNE Workbench USER’S MANUAL”
5、 “SOFTUNE Workbench COMMAND REFERENCE MANUAL”
User can find all the sample code and documents mentioned above by the web address:
http://www.fujitsu.com/cn/fmc/services/mcu/mb95/index_mb95200.html
共7条
lyzhangxiang的使用手记
呵呵 这个是那个纸上的文字,copy下来了
还有很多资料上传了,可惜不知道论坛如何上传所以上传到我的个人空间了,免费下载
http://e.ys168.com/?resourcesharing
其中的EasyKit资料,等待后续精彩分享
感谢您使用本公司的产品,谨致谢忱!
您可以从以下的URL下载MB95200系列 SOFTUNE Professional Pack评估版。
http://www.fujitsu.com/cn/fmc/services/mcu/tools/mb95200-download.html
PASSWORD:EV-300016
(注)请勿向他人公开用户名及密码(ID/PASSWORD)
邮件内容,冒死公开
PASSWORD:EV-300016
邮件内容,冒死公开
昨天收到,软件装好了,找不到sample code,不知道MCU的具体型号是哪个,是不是264?260系列?互相学习下,呵呵。
是的 260系列的264啊,可以直接使用的,就是EasyKit的Demo呀,直接使用哈哈 ,软件的下载地址也给出来啦。一起学习
共7条
