LG推出吸尘机器人――V-R4000
写于: 星期一 15 八月 @ 06:53:18 |
LG近日研制出一款真空吸尘机器人,型号为LG V-R4000,在韩国它还有一个形象的名字叫“Roboking”。它的外形大小为340mm×133mm可谓非常小巧,每分钟能前进0.3米,可持续工作70分钟,充电需要2.5小时。
LG推出吸尘机器人――V-R4000
(点击放大)
下面是一些简单的介绍:
- Improved core performances of the vacuum cleaning robot, including suction power, battery life & Performance and Automatic driving
- Provided additional comfort with wellness-oriented micro filters
| Most Powerful BLDC Motor |
| Thanks to BLDC (Brushless Direct Current) Motor loaded in Roboking, the suction power can reach up to 100W, which is by far the best suction performance among the few robotic vacuum models available in the market. Most high-end products usually feature from 30W to 70W of suction power. Therefore BLDC Motor makes cleaning more thorough. |
| High Efficiency Long time Battery |
| Roboking is geared by a Lithium Polymer battery (Li-PB), which was used on premium cell phones and auto-bike, laptop-computers, and never before on a robotic vacuums. The newly introduced battery type extends the life cycle of the battery from 3 to 5 times longer than others, and as a result the consumers do not have to buy additional battery, which is very convenient and saves money. |
| Hygienic HEPA Filter |
| Roboking adapts a five-step filtering system and a valve that prevents the backward flowing of dust collected in the machine. For the first time in the industry, the system incorporates advanced micro filters named the HEPA (High Efficiency Penetration Air) filters. It will be especially beneficial for the family with Asthma patients. |
| 4 Smart Cleaning mode |
| Roboking’s effective operation under the control of 22sensors attached on 32bit Microprocessor, moves in 4 smart patterns such as Gyro-Matrix, Variable-Matrix, and Spiral, Random, depending on the structure and space of the area. Especially, Gyro-Matrix controlled by Gyro sensor does what vacuum cleaner ROBOT has to do. |
| Ratio Frequency Remote Control |
| The radius of IR remote is very short, so it is very difficult to use for a large space. However, RF remote adapted in Roboking can be used without any problem within a 10M radius. Also, Consumers can operate the remote control very easily just by the use of joystick. |
| Dimension |
| Φ340 x 133 H |
| Suction Power |
| 100W |
| Motor |
| Digital BLDC |
| Agitator |
| Hybrid Nozzle(Silicon Blade+Brush) |
| Filter Type |
| Cyclone 0.5l, Double HEPA |
| Noise |
| 65dB |
| Sensing |
| 21 Sensors & Gyro |
| Cleaning Speed |
| 0.3m/sec |
| Cleaing Mode |
| Gyro Matrix |
| Variable Matrix |
| Spiral |
| Random |
| Run-time/Charging |
| 70min /2.5Hr. |
| Battery Type |
| LiPB |
| Remote Control |
| RF |
| Additional Function |
| Voice informer |
图片集:
(点击放大)
(点击放大)
(点击放大)
关于机器人吸尘机器人的讨论:
吸尘机器人 清洁机器人 自动吸尘器 智能吸尘器
或者在论坛中搜索。
