电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 有图真相——焊接液晶以及调试GSM结果
共14条 1/2 1 2 › 跳转至页
有图真相——焊接液晶以及调试GSM结果
2011-05-06 22:45:42     打赏
1、正面
2、背面
3、调试结果
关键词: 真相     焊接     液晶     以及     调试     结果
2011-05-07 09:27:52     打赏
楼主效率很高!
2011-05-07 11:08:55     打赏
帖点代码出来:就是UART2的,与GSM通信的串口通信,波特率位9600
#include "config.h"
u8  RxBuffer2[RxBuffer2_SIZE];
u8  TxBuffer2[TxBuffer2_SIZE];
u16  USART2_RX_HeadIndex;
u16  USART2_RX_TailIndex;
u16  USART2_TX_HeadIndex;
u16  USART2_TX_TailIndex;
u16  UASRT2_Input_Index;
void USART2_Initialise( void )
  GPIO_InitTypeDef GPIO_InitStructure;//I/O口初始化结构体
  NVIC_InitTypeDef NVIC_InitStructure;//中断初始化结构体
  USART_InitTypeDef USART_InitStructure;//串口初始化结构体
  USART_ClockInitTypeDef  USART_ClockInitS;
 // Flush the buffers by setting the indexes to 0
   USART2_RX_HeadIndex = 0;
   USART2_RX_TailIndex = 0;
   USART2_TX_HeadIndex = 0;
   USART2_TX_TailIndex = 0;
   UASRT2_Input_Index = 0;
  /* Enable the USART2 Pins Software Remapping */
  GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
  /* Configure USART2 Rx (PD.06) as input floating */
  //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//zhai 10-26
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//zhai 10-26
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOA, &GPIO_InitStructure);//zhai 10-26
  //GPIO_Init(GPIOD, &GPIO_InitStructure);//zhai 10-26
   /* Configure USART2 Tx (PD.05) as alternate function push-pull */
  //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;//zhai 10-26
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;//zhai 10-26
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
   /* Enable the USART2 Interrupt */
   NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0;
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
   NVIC_Init(&NVIC_InitStructure);
  // 串口相关配置
  //USART_InitStructure.USART_BaudRate = 115200;
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 位宽
  USART_InitStructure.USART_StopBits = USART_StopBits_1;      //停止位
  USART_InitStructure.USART_Parity = USART_Parity_No;         //校验位
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件控制流
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //串口模式
  USART_ClockInitS.USART_Clock = USART_Clock_Disable;          //SCLK时钟使能(同步模式下)
  USART_ClockInitS.USART_CPOL = USART_CPOL_Low;                //时钟极性(同步模式下)
  USART_ClockInitS.USART_CPHA = USART_CPHA_2Edge;              //时钟相位(同步模式下)
  USART_ClockInitS.USART_LastBit = USART_LastBit_Disable;      //最后一位时钟脉冲(同步模式下)
  USART_Init(USART2, &USART_InitStructure);  /* Configure USART2 配置 串口发送方式寄存器*/
  USART_ClockInit(USART2, &USART_ClockInitS);
  //USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
  USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);  //USART中断配置
  USART_Cmd(USART2, ENABLE);  // Enable USART2
bool  USART2_TX_Char(char c)
    bool success =TRUE;
 //OS_CPU_SR  cpu_sr;
    //OS_ENTER_CRITICAL();   // 进入 临界段
    if(USART2_TX_Count() >(TxBuffer2_SIZE-1))
    {  success =FALSE; }
    else
       TxBuffer2[USART2_TX_HeadIndex++] =c;
       if(USART2_TX_HeadIndex >=TxBuffer2_SIZE)
       { USART2_TX_HeadIndex =0; }
// OS_EXIT_CRITICAL();  //  退出临界段
   return success;
s16 USART2_RX_Char(void)
   u8 ch;
  // OS_CPU_SR  cpu_sr;
  //  OS_ENTER_CRITICAL();   // 进入 临界段
   if(USART2_RX_Count() ==0)
     return -1;
   ch =RxBuffer2[USART2_RX_TailIndex++];
   if (USART2_RX_TailIndex >=RxBuffer2_SIZE)
   {  USART2_RX_TailIndex =0;}
   return ch;
u16 USART2_TX_Count(void)
    s16 num;
 num =USART2_TX_HeadIndex -USART2_TX_TailIndex;
    if (num <0)
    {  num +=TxBuffer2_SIZE; }
    return num;
u16  USART2_RX_Count(void)
    s16 num;
    num =USART2_RX_HeadIndex -USART2_RX_TailIndex;
    if (num <0)
    {  num +=RxBuffer2_SIZE; }
    return num;
bool USART2_PutChar(u8 *s,u16 length)
   u16 i;
   bool success =TRUE;
   for(i=0; i<length; i++)
      if(!USART2_TX_Char(*s++))
          success =FALSE;
          break;
   return success;
bool USART2_PutString(char *s)
   bool success =TRUE;
   while (*s)
          success =FALSE;
          break;
   return success;
u16 UART2Read(char *s,u16 count)
   u16   i=0;
   while(USART2_RX_Count() >0 && i <= count)
      s[i]=RxBuffer2[USART2_RX_TailIndex];
   USART2_RX_TailIndex++;
   i++;
   return i;
* Function Name  : USART1_IRQHandler
* Description    : This function handles USART1 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
/*---------------interrupt sub---------------------------------*/
void USART2_IRQHandler(void)
  char ch;
  //OS_CPU_SR  cpu_sr;
  //OSIntNesting++;
  //OS_EXIT_CRITICAL();  //  退出临界段
  if(USART_GetITStatus(USART2, USART_IT_RXNE) !=RESET)
    ch =USART_ReceiveData(USART2);
    if(USART2_RX_Count() <(RxBuffer2_SIZE -1))
      RxBuffer2[USART2_RX_HeadIndex++] =ch;
      if(USART2_RX_HeadIndex >=RxBuffer2_SIZE)
        USART2_RX_HeadIndex =0;
    USART_ClearITPendingBit(USART2, USART_IT_RXNE);
  if(USART_GetITStatus(USART2,USART_IT_TXE) !=RESET)
    if(USART2_TX_Count() >0)
       USART_SendData(USART2, TxBuffer2[USART2_TX_TailIndex++]);
       USART_ClearITPendingBit(USART2, USART_IT_TXE);
       if(USART2_TX_TailIndex >=TxBuffer2_SIZE)
       {  USART2_TX_TailIndex =0; }
    else
    { /* Disable the USART1 Transmit interrupt */
      USART_ITConfig(USART2, USART_IT_TXE, DISABLE);
  // OSIntExit();
2011-05-07 11:10:15     打赏
串口1:为监听程序的运行
#include "config.h"
#define TxBuffer1_SIZE    200
#define RxBuffer1_SIZE    200
u8  RxBuffer1[RxBuffer1_SIZE];
u8  TxBuffer1[TxBuffer1_SIZE];
u16  USART1_RX_HeadIndex;
u16  USART1_RX_TailIndex;
u16  USART1_TX_HeadIndex;
u16  USART1_TX_TailIndex;
u16  UASRT1_Input_Index;
void USART1_Initialise( void )
   USART1_RX_HeadIndex = 0;
   USART1_RX_TailIndex = 0;
   USART1_TX_HeadIndex = 0;
   USART1_TX_TailIndex = 0;
   UASRT1_Input_Index = 0;
    // Configure USART1 Tx (PA.09) as alternate function push-pull
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
       // Configure USART1 Rx (PA.10) as input floating
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
      // Enable the USART1 Interrupt
   NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
     // 串口相关配置
  USART_Init(USART1, &USART_InitStructure);  /* Configure USART1 配置 串口发送方式寄存器*/
  USART_ClockInit(USART1, &USART_ClockInitS);
     // USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
   USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);  //接收终端使能
   USART_Cmd(USART1, ENABLE);  // Enable USART1
bool  USART1_TX_Char(char c)
    bool success =TRUE;
    //OS_CPU_SR  cpu_sr;
    if(USART1_TX_Count() >(TxBuffer1_SIZE-1))
    {  success =FALSE; }
    else
       TxBuffer1[USART1_TX_HeadIndex++] =c;
       if(USART1_TX_HeadIndex >=TxBuffer1_SIZE)
       { USART1_TX_HeadIndex =0; }
   return success;
s16 USART1_RX_Char(void)
   u8 ch;
   //OS_CPU_SR  cpu_sr;
   if(USART1_RX_Count() ==0)
     return -1;
   ch =RxBuffer1[USART1_RX_TailIndex++];
   if (USART1_RX_TailIndex >=RxBuffer1_SIZE)
   {  USART1_RX_TailIndex =0;}
   return ch;
u16 USART1_TX_Count(void)
{ s16 num;
 //OS_CPU_SR  cpu_sr;
    num =USART1_TX_HeadIndex -USART1_TX_TailIndex;
    if (num <0)
    {  num +=TxBuffer1_SIZE; }
    return num;
u16  USART1_RX_Count(void)
{ s16 num;
    //OS_CPU_SR  cpu_sr;
    num =USART1_RX_HeadIndex -USART1_RX_TailIndex;
    if (num <0)
    {  num +=RxBuffer1_SIZE; }
    return num;
bool USART1_PutChar(u8 *s,u16 length)
   u16 i;
   //OS_CPU_SR  cpu_sr;
   bool success =TRUE;
      if(!USART1_TX_Char(*s++))
          success =FALSE;
    break;
      return success;
bool USART1_PutString(char *s)
   bool success =TRUE;
   //OS_CPU_SR  cpu_sr;
   while (*s)
          success =FALSE;
    break;
  return success;
bool USART1_PutHex(u8 *s,u16 length)
   u16 i;
   u8 ch;
   bool success =TRUE;
      ch =s[i] >>4;
      if( ch<=9 )
   {  USART1_TX_Char(ch+'0'); }
   else
   {  USART1_TX_Char(ch+0x37);}
   ch =s[i] &0x0f;
   if( ch<=9 )
   else
      return success;
u16 UART1Read(char *s,u16 count)
   u16  i=0;
   while(USART1_RX_Count() > 0 && i <= count )
   s[i]=RxBuffer1[USART1_RX_TailIndex];
   RxBuffer1[USART1_RX_TailIndex]=0;
   USART1_RX_TailIndex++;
   if(USART1_RX_TailIndex==RxBuffer1_SIZE)   USART1_RX_TailIndex=0;
   i++;
   return i;
* Input          : None
* Output         : None
* Return         : None
void USART1_IRQHandler(void)
  char ch;
  //OS_CPU_SR  cpu_sr;
  //OSIntNesting++;
  if(USART_GetITStatus(USART1, USART_IT_RXNE) !=RESET)
    ch =USART_ReceiveData(USART1);
    if(USART1_RX_Count() <(RxBuffer1_SIZE -1))
      RxBuffer1[USART1_RX_HeadIndex++] =ch;
      if(USART1_RX_HeadIndex >=RxBuffer1_SIZE)
        USART1_RX_HeadIndex =0;
    USART_ClearITPendingBit(USART1, USART_IT_RXNE);
  if(USART_GetITStatus(USART1,USART_IT_TXE) !=RESET)
    if(USART1_TX_Count() >0)
       USART_SendData(USART1, TxBuffer1[USART1_TX_TailIndex++]);
       USART_ClearITPendingBit(USART1, USART_IT_TXE);
       if(USART1_TX_TailIndex >=TxBuffer1_SIZE)
       {  USART1_TX_TailIndex =0; }
    else
      USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
  // OSIntExit();
2011-05-09 23:24:31     打赏
好快啊,高手
2011-05-10 08:17:48     打赏
谢谢各位的支持!!!
2011-05-11 17:26:12     打赏
楼主 什么时候 拿出几套来卖卖啊 想玩玩 迫不及待啊~~~~
2011-05-12 08:27:40     打赏
卖与不卖现在也还没决定呢!到时候也不知道以什么方式提供出来
2011-05-12 19:20:56     打赏
楼主 手头不是有几套么??
可以 提供 PCB+元器件 以DIY的形式不知道可以否?
当然最好给一些基本测试历程。
仿真器到是个问题。。。
本人想买一套,不知可以买一套给偶。。。。呵呵
2011-09-21 22:01:54     打赏
再回复一下,这个板子很有可能分享出来!
共14条 1/2 1 2 › 跳转至页
