ADuC847/ADuC848 MicroConverter将24/16位多通道Σ-Δ型ADC和Flash微控制器完全集成在一个芯片上。这些器件针对要求精密采集多个(最多10个)通道的工业控制、智能传感器、称重传感器和仪器仪表应用进行了优化。
共4条
有没人用过ADI的aduc8xx或者TI的MSC12XX系列51核的单片机
有没人用过ADI的aduc8xx或者TI的MSC12XX系列51核的单片机,看起来很强大啊,可以用Keil编程,串口下载程序。去ADI申请ADuC847想玩下,没通过。。。
24位(ADuC848为16位)精密Σ-Δ型ADC
10通道单端输入或5通道差分输入选项
缓冲可编程增益、自校准、24位/16位ADC
两个独立的差分参考输入选项
片内熔断检测和激励电流选项
单通道12位轨到轨电压输出DAC
精密温度传感器
两路灵活的PWM输出
12.58 MIPS单周期8052内核
62 KB在线重新编程能力
4 KB 读写存取能力
关键词: 没人 用过 aduc8xx 或者 MSC12XX
msc121x.pdfmsc1210
aduc 8xxuser guide.pdf
KEIL.pdf
IAP.pdf
msc12xx 数据手册
MSC1210-DAQ-EVM_User_Guide_sbau083.pdf
MSC1210_User_Manual_sbau077.pdf
The MSC1210Yx is a completely integrated family of mixed-signal devices incorporating a high-resolution delta-sigma ADC, 8-channel multiplexer, burnout current sources, selectable buffered input, offset DAC (digital-to-analog converter), PGA (programmable gain amplifier), temperature sensor, voltage reference, 8-bit microcontroller, Flash Program Memory, Flash Data Memory, and Data SRAM, as shown in Figure 8.
On-chip peripherals include an additional 32-bit accumulator, an SPI compatible serial port, dual USARTs, multiple digital input/output ports, watchdog timer, low-voltage detect, on-chip power-on reset, 16-bit PWM, and system timers, brownout reset, and three timer/counters.
The microcontroller core is 8051 instruction set compatible.
- ANALOG FEATURES
- 24 Bits No Missing Codes
- 22 Bits Effective Resolution at 10Hz
- Low Noise: 75nV
- PGA From 1 to 128
- Precision On-Chip Voltage Reference
- 8 Differential/Single-Ended Channels
- On-Chip Offset/Gain Calibration
- Offset Drift: 0.1ppm/°C
- Gain Drift: 0.5ppm/°C
- On-Chip Temperature Sensor
- Burnout Sensor Detection
- Single-Cycle Conversion
- Selectable Buffer Input
- DIGITAL FEATURES
- Microcontroller Core
- 8051-Compatible
- High-Speed Core
- 4 Clocks per Instruction Cycle
- DC to 33MHz
KEIL.pdf
IAP.pdf
msc12xx 数据手册
共4条
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
