共8条
上传文档时出现这个
Fatal error: Uncaught exception 'Zend_Db_Statement_Exception' with message 'SQLSTATE[HY000]: General error: 2006 MySQL server has gone away' in /var/www/html/www.edw.com.cn/library/Zend/Db/Statement/Pdo.php:230 Stack trace: #0 /var/www/html/www.edw.com.cn/library/Zend/Db/Adapter/Abstract.php(233): Zend_Db_Statement_Pdo-execute(Array) #1 /var/www/html/www.edw.com.cn/library/Zend/Db/Adapter/Pdo/Abstract.php(204): Zend_Db_Adapter_Abstract-query('DESCRIBE `edw_u...', Array) #2 /var/www/html/www.edw.com.cn/library/Zend/Db/Adapter/Pdo/Mysql.php(108): Zend_Db_Adapter_Pdo_Abstract-query('DESCRIBE `edw_u...') #3 /var/www/html/www.edw.com.cn/library/Zend/Db/Table/Abstract.php(595): Zend_Db_Adapter_Pdo_Mysql-describeTable('edw_user_pile', NULL) #4 /var/www/html/www.edw.com.cn/library/Zend/Db/Table/Abstract.php(528): Zend_Db_Table_Abstract-_setupMetadata() #5 /var/www/html/www.edw.com.cn/library/Zend/Db/Table/Abstract.php(264): Zend_Db_Table_Abstract-_setup() #6 /var/www/html/www.edw.com.cn/library/Edw/Db/Table.php(19): Zend_Db in /var/www/html/www.edw.com.cn/library/Zend/Db/Statement/Pdo.php on line 230
求解答
共8条
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
| 【分享开发笔记,赚取电动螺丝刀】墨水屏文本显示器被打赏¥25元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取磁力计iis2mdc被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取LPS22HH气压、温度被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取STTS751温度被打赏¥17元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX软件读取HTS221温湿度被打赏¥22元 | |
| M5PAPERESP32EINKDEVKIT评测|使用MicroPython开发M5Paper被打赏¥15元 | |
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
