共8条
上传文档时出现这个
Fatal error: Uncaught exception 'Zend_Db_Statement_Exception' with message 'SQLSTATE[HY000]: General error: 2006 MySQL server has gone away' in /var/www/html/www.edw.com.cn/library/Zend/Db/Statement/Pdo.php:230 Stack trace: #0 /var/www/html/www.edw.com.cn/library/Zend/Db/Adapter/Abstract.php(233): Zend_Db_Statement_Pdo-execute(Array) #1 /var/www/html/www.edw.com.cn/library/Zend/Db/Adapter/Pdo/Abstract.php(204): Zend_Db_Adapter_Abstract-query('DESCRIBE `edw_u...', Array) #2 /var/www/html/www.edw.com.cn/library/Zend/Db/Adapter/Pdo/Mysql.php(108): Zend_Db_Adapter_Pdo_Abstract-query('DESCRIBE `edw_u...') #3 /var/www/html/www.edw.com.cn/library/Zend/Db/Table/Abstract.php(595): Zend_Db_Adapter_Pdo_Mysql-describeTable('edw_user_pile', NULL) #4 /var/www/html/www.edw.com.cn/library/Zend/Db/Table/Abstract.php(528): Zend_Db_Table_Abstract-_setupMetadata() #5 /var/www/html/www.edw.com.cn/library/Zend/Db/Table/Abstract.php(264): Zend_Db_Table_Abstract-_setup() #6 /var/www/html/www.edw.com.cn/library/Edw/Db/Table.php(19): Zend_Db in /var/www/html/www.edw.com.cn/library/Zend/Db/Statement/Pdo.php on line 230
求解答
共8条
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
