线晒下焊的东西吧,因为有些器件还没有过来就,发个办成品的照片,展示下进度:
跟新中
共5条
cat3902982 MCU DIY进程帖
*- 花样流水灯 *
* P1---8个LED 硬件:8路指示灯接P1口 *
* 日期: 2011-12-20 *
* 版本: V1.0 *
* 作者: CAT *
#include <reg51.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
uchar code display_P1[]={
0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,0xFF,
0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //
0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE, //
0xFC,0xF9,0xF3,0xE7,0xCF,0x9F,0x3F,0x7F,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, //
0xE7,0xDB,0xBD,0x7E,0xBD,0xDB,0xE7,0xFF,
0xE7,0xC3,0x81,0x00,0x81,0xC3,0xE7,0xFF,
0xAA,0x55,0x18,0xFF,0xF0,0x0F,0x00,0xFF,
0xFF,0x00,0x00,0xFF,0xFF };
void delayms(uint ms)// 延时子程序
uchar k;
while(ms--)
for(k = 0; k < 50; k++);
void main(void)
uchar i;
P1 = 0xff;
while(1)
for(i=0;i <110; i++)
P1 =display_P1[i];
delayms(350);
共5条
