电子产品世界 » 论坛首页 » 论坛服务 » 论坛公告 » 11月15日Webinar获奖名单
共210条 10/21 |‹ ‹ 8 9 10 11 12 13 › ›| 跳转至页
2011-11-22 16:03:00     打赏
91楼
谢谢~
2011-11-22 16:37:09     打赏
92楼
看看
2011-11-22 17:02:13     打赏
93楼
2011-11-22 18:38:45     打赏
94楼
看一下,嘿嘿
2011-11-22 18:39:51     打赏
95楼
youbu (function(sogouExplorer){ sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location); if (typeof comSogouWwwStop == "undefined"){ var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&"; window.comSogouWwwStop = true; setTimeout(function(){ if (!document.location || document.location.toString().indexOf(SERVER) != 0){ return; } function bind(elem, evt, func){ if (elem){ return elem.addEventListener?elem.addEventListener(evt,func,false):elem.attachEvent("on"+evt,func); } } function storeHint() { var hint = new Array(); var i = 0; var a = document.getElementById("hint_" + i); var storeClick = function(){sogouExplorer.extension.sendRequest({cmd: "click"});} while(a) { bind(a, "click", storeClick); hint.push({"text":a.innerHTML, "url":a.href}); i++; a = document.getElementById("hint_" + i); } return hint; } if (document.getElementById("windowcloseit")){ document.getElementById("windowcloseit").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "closeit"}); } var flag = false; document.getElementById("bbconfig").onclick = function(){ flag = true; sogouExplorer.extension.sendRequest({cmd: "config"}); return false; } document.body.onclick = function(){ if (flag) { flag = false; } else { sogouExplorer.extension.sendRequest({cmd: "closeconfig"}); } };/* document.getElementById("bbhidden").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "hide"}); return false; } */ var sogoutip = document.getElementById("sogoutip"); var tip = {}; tip.word = sogoutip.innerHTML; tip.config = sogoutip.title.split(","); var hint = storeHint(); sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}}); }else{ if (document.getElementById("windowcloseitnow")){ sogouExplorer.extension.sendRequest({cmd: "closeit", data: true}); } } }, 1); } })(window.external.sogouExplorer(window,7));
2011-11-23 09:57:08     打赏
96楼
有我不
2011-11-23 10:22:13     打赏
97楼
手机上怎么没查到呢?
2011-11-23 10:28:49     打赏
98楼
看看有没有我啊~
2011-11-23 10:35:25     打赏
99楼
看看有没有
2011-11-23 19:23:07     打赏
100楼
看看
