//为定时器0初始化程序
//入口参数:空
//出口参数:空
void timer0_init(void)
TMOD &= 0xf0;
TMOD |= 0x01; //定时器0工作在16位定时器模式下
TH0 = (0xFFFF-SystemClock/12/Timer25ms)>>8;//定时25ms
TL0 = (0xFFFF-SystemClock/12/Timer25ms)%256;
ET0 = 1; //开启中断
TR0 = 1; //开始计数
//%%%%%%%%%%%%%%%%%%%中断服务函数%%%%%%%%%%%%%%%%%%%%%%
//为定时器0中断处理程序
//入口参数:空
//出口参数:空
void timer0_irq(void) interrupt 1
EA = 0;
TH0 = (0xFFFF-SystemClock/12/Timer10ms)>>8;//定时25ms
TL0 = (0xFFFF-SystemClock/12/Timer10ms)%256;
system_time ++;
EA = 1;
LCD1602操作程序
#define LCD_DB P0
sbit LCD_RS = P2^4;
sbit LCD_RW = P2^5;
sbit LCD_E = P2^6;
void delay_n40us(unsigned int n)
unsigned int i;
unsigned char j;
for(i=n;i>0;i--)
for(j=0;j<2;j++);
void LCD_write_command(unsigned char dat)
LCD_DB = dat;
LCD_RS = 0;
LCD_E = 1;
LCD_E = 0;
delay_n40us(1);
void LCD_write_data(unsigned char dat)
LCD_DB = dat;
LCD_RS = 1;
LCD_RW = 0;
LCD_E = 1;
LCD_E = 0;
delay_n40us(1);
void LCD_disp_char(unsigned char x,unsigned char y,unsigned char dat)
unsigned char address;
if(y==1)
address = 0x80 + x;
else
address = 0xc0 + x;
LCD_write_command(address);
LCD_write_data(dat);
void LCD_check_busy(void)
do{
LCD_E = 0;
LCD_RS = 0;
LCD_RW = 1;
LCD_DB = 0xff;
LCD_E = 1;
}while(LCD_DB^7 == 1);
void LCD_init(void)
LCD_write_command(0x38);
LCD_write_command(0x0c);
LCD_write_command(0x06);
LCD_write_command(0x01);
delay_n40us(100);
