电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » zzj1676 MCU DIY进程帖
共12条 2/2 ‹ 1 2 跳转至页
2012-01-09 13:55:06     打赏
11楼
0到9999秒正计时数码管显示源程序
#include<reg52.h> #include<intrins.h> #define uchar unsigned char #define uint unsigned int sbit dula=P3^7; uchar aa,qian,bai,shi,ge; uint i; void init(); void delay(uint z); void display(uchar qian,uchar bai,uchar shi,uchar ge); uchar code num_table[]= {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; void main() { init(); //初始化 i=0; while(1) {     if(aa==20)       {        aa=0;      if (i==9999)        i=0;       i++;         qian=i/1000;      bai=i%1000/100;      shi=i%100/10;      ge=i%10; } display(qian,bai,shi,ge); } } void init() { TMOD=0x01; TH0=(65536-45872)/256; TL0=(65536-45872)%256; EA=1; ET0=1; TR0=1; } void timer0()interrupt 1 { TH0=(65536-45872)/256; TL0=(65536-45872)%256; aa++; } void display(uchar qian,uchar bai,uchar shi,uchar ge) {         P2=0;         dula=1;      P0=num_table[qian];       dula=0;      delay(1) ;           P2=0x01;         dula=1;      P0=num_table[bai];      dula=0;      delay(1) ;           P2=0xb02;         dula=1;         P0=num_table[shi];      dula=0;      delay(1);           P2=0x03;         dula=1;      P0=num_table[ge];      dula=0;      delay(1) ; } void delay(uint z) { uint x,y; for(x=z;x>0;x--)  for(y=110;y>0;y--); }
图片如下:
2012-01-11 12:07:20     打赏
12楼
扫描法 矩阵键盘 按相应的键数码管显示相应的数字
  include <reg52.h>//包含头文件
unsigned char const num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f, 0x77,0x7c,0x39,0x5e,0x79,0x71};//0-F
uchar keyscan(void);
void delay(uint i);
void main()
 uchar key;
P2=0x00;//1数码管亮 按相应的按键,会显示按键上的字符、
while(1)
key=keyscan();//调用键盘扫描;
 switch(key)
 case 0x7e:P0=num[0];break;//0 按下相应的键显示相对应的码值  case 0x7d:P0=num[1];break;//1  case 0x7b:P0=num[2];break;//2  case 0x77:P0=num[3];break;//3  case 0xbe:P0=num[4];break;//4  case 0xbd:P0=num[5];break;//5  case 0xbb:P0=num[6];break;//6  case 0xb7:P0=num[7];break;//7  case 0xde:P0=num[8];break;//8  case 0xdd:P0=num[9];break;//9  case 0xdb:P0=num[10];break;//a  case 0xd7:P0=num[11];break;//b  case 0xee:P0=num[12];break;//c  case 0xed:P0=num[13];break;//d  case 0xeb:P0=num[14];break;//e  case 0xe7:P0=num[15];break;//f  }  } } uchar keyscan(void)//键盘扫描函数,使用行列反转扫描法 {  uchar cord_h,cord_l;//行列值  P3=0x0f;            //行线输出全为0  cord_h=P3&0x0f;     //读入列线值  if(cord_h!=0x0f)    //先检测有无按键按下  {  delay(100);        //去抖  if(cord_h!=0x0f)  {     cord_h=P3&0x0f; //读入列线值     P3=cord_h|0xf0; //输出当前列线值     cord_l=P3&0xf0; //读入行线值     return(cord_h+cord_l);//键盘最后组合码值    }  }return(0xff);     //返回该值 } void delay(uint i)//延时函数 { while(i--); }
共12条 2/2 ‹ 1 2 跳转至页
