电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 406514993MCU DIY进程帖
共8条 1/1 1 跳转至页
406514993MCU DIY进程帖
2011-12-02 18:56:17     打赏
现在终于有点时间搞下这东西,期末了,实在是太忙了···
关键词: 406514993MCU     进程
2011-12-02 19:09:06     打赏
准备写流水灯,液晶显示,数码管显示,跑马灯,温度传感器,时钟等程序。先来个流水灯的吧!
2011-12-02 19:16:28     打赏
#include <reg51.h>
#include <intrins.h>
unsigned char a,b,k,j;
void delay10ms()
    for(a=100;a>0;a--)
      for(b=225;b>0;b--);
void main()
  k=0xfe;
  while(1)
      delay10ms();
      beep=0;
      delay10ms();
      beep=1;
      j=_crol_(k,1);
      k=j;
      P1=j;
2011-12-02 20:23:43     打赏
继续哦
2011-12-07 13:15:07     打赏
数码管显示程序:
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar temp,aa,bai,shi,ge;
sbit dula=P3^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void display(uchar bai,uchar shi,uchar ge);
void delay(uint z);
void init();
void main()
 init();//初始化子程序
 while(1)
  if(aa==20)
   aa=0;
   temp++;
   if(temp==100)
     temp=0;
   bai=temp/100;
   shi=temp%100/10;
   ge=temp%10;
  display(bai,shi,ge);
void delay(uint z)
 uint x,y;
 for(x=z;x>0;x--)
  for(y=110;y>0;y--);
        dula=1;
  P0=table[bai];
  dula=0;
  P0=0xff;
  P2=0x00;
  P0=0xfe;
  P2=0xff;
  delay(1);
  dula=1;
  P0=table[shi];
  dula=0;
  P0=0xff;
  P2=0x10;
  P0=0xfd;
  P2=0xff;
  delay(1);
  dula=1;
  P0=table[ge];
  dula=0;
  P0=0xff;
  P2=0x20;
  P0=0xfb;
  P2=0xff;
  delay(1);
void init()
 P2=0xff;
 dula=0;
 temp=0;
 TMOD=0x01;
 TH0=(65536-50000)/256;
 TL0=(65536-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
void timer0() interrupt 1
 aa++;
2011-12-16 16:39:34     打赏
LCD1602液晶显示程序:分2行显示。
#include<reg52.h>
sbit rs=P2^4;
sbit rw=P2^5;
sbit lcden=P2^6;
uchar table1[]="JX-JA MCU";
uchar table2[]="1234567654321";
void delay(uint x)
 uint a,b;
 for(a=x;a>0;a--)
  for(b=10;b>0;b--);
void delay1(uint x)
 uint a,b;
 for(a=x;a>0;a--)
  for(b=100;b>0;b--);
void write_com(uchar com)
 P0=com;
 rs=0;
    rw = 0;
 lcden=0;
 delay(10);
 lcden=1;
 delay(10);
 lcden=0;
void write_date(uchar date)
 P0=date;
 rs=1;
    rw = 0;
 lcden=0;
 delay(10);
 lcden=1;
 delay(10);
 lcden=0;
void init()
 write_com(0x38);
 delay(20);
 write_com(0x0f);
 delay(20);
 write_com(0x06);
 delay(20);
 write_com(0x01);
 delay(20);
void main()
 uchar a;
 init();
 write_com(0x80+17);
 delay(20);
 for(a=0;a<9;a++)
 write_date(table1[a]);
 delay(20);
 write_com(0xc0+17);
 delay(50);
 for(a=0;a<13;a++)
 write_date(table2[a]);
 delay(40);
 for(a=0;a<16;a++)
  write_com(0x18);
  delay1(200);
 while(1);
2011-12-16 16:47:28     打赏
LCD12864液晶显示程序:在LCD上画一个圆。
#include<reg52.h>
#include<math.h>
#define Lcd_DatBus  P0
sbit rs=P2^4;
sbit rw=P2^5;
sbit en=P2^6;
sbit PSB=P2^1;
uchar table[]={"我们是都好孩子!"};
uchar GDRAM_hbit=0;
uchar GDRAM_lbit=0;
名  称:delay1ms
功  能:延时约1ms
参  数:uchar n
返回值:无
void delayms(uchar z)
 uchar x,y;
   for(x=0;x<z;x++)
      for(y=0;y<110;y++);
名  称: write_com
功  能:对液晶写控制命令
参  数:com——控制命令
返回值:无
void Write_com(uchar com)
    uchar temp=0;
 rs=0;
  rw=1;
  do                //判忙
     en=1;
     delayms(1);
     temp=P0;
     en=0;
    while(temp&0x80);
 rw=0;
  P0=com;
  delayms(1);
  en=1;
  delayms(1);
  en=0;
名  称:write_dat
功  能:向液晶写入数据
参  数:dat——显示数据
返回值:无
void Write_data(uchar dat)
    uchar temp=0;
    rs=0;
    rw=1;
    do    //判忙
       en=1;
     delayms(1);
       temp=P0;
       en=0;
   while(temp&0x80);
   rs=1;
   rw=0;
   P0=dat;
   en=1;
   delayms(1);
   en=0;
/**********读取当前地址的LCD显示数据**********/
uchar Read_data()
 uchar shuju;
 P0=0xff;
 rs=1;      // D/I=1,代表数据
 rw=1;      // R/W=1.读取
 delayms(10);
 en=1;
 delayms(100);
 shuju=P0;    //读取当前显示的数据
 en=0;
 return(shuju);
函数名称:Draw_TX
功    能:显示一个16*16大小的图形
参    数:Yaddr--Y地址
          Xaddr--X地址
          dp--指向图形数据存放地址的指针
返回值  :无
void Draw_TX(uchar Yaddr,uchar Xaddr,const uchar * p)
    uchar j;
    uchar k=0;
    Write_com(0x01);  //清屏,只能清除DDRAM
    Write_com(0x34);  //使用扩展指令集,关闭绘图显示
    for(j=0;j<16;j++)
        Write_com(Yaddr++);       //Y地址
     Write_com(Xaddr);    //X地址
     Write_data(p[k++]);
     Write_data(p[k++]);
    Write_com(0x36);  //打开绘图显示
    Write_com(0x30);  //回到基本指令集模式
名  称:clear_DGRAM
功  能:清除液晶GDRAM中的随机数据
参  数:无
返回值:无
void clear_GDRAM(void)
    uchar i,j,k;
    Write_com(0x34);      //打开扩展指令集
 i=0x80;
 for(j=0;j<32;j++)
     Write_com(i++);
     Write_com(0x80);
     for(k=0;k<16;k++)
   Write_data(0x00);
    i=0x80;
    for(j=0;j<32;j++)
      Write_com(i++);
     Write_com(0x88);
     for(k=0;k<16;k++)
   Write_data(0x00);
画点函数:Write_Point()
x表示列,y表示为行。
void Write_Point(uchar x,uchar y,uchar flag)
    uchar x_dyte,x_byte;               //定义列地址的字节位,及在字节中的哪1位
 uchar y_dyte,y_byte;               //定义为上下两个屏(取值为0,1),行地址(取值为0~31)
 Write_com(0x36);               //绘图模式命令
  /***X,Y坐标互换,即普通的X,Y坐标***/
   x_dyte=y/16;                     //计算在16个字节中的哪一个
   x_byte=y&0x0f;                   //计算在该字节中的哪一位
   y_dyte=x/32;                     //0为上半屏,1为下半屏
   y_byte=x&0x1f;                   //计算在0~31当中的哪一行
   Write_com(0x80+y_byte);           //设定行地址(y坐标)
   Write_com(0x80+x_dyte+8*y_dyte);     //设定列地址(x坐标),并通过8*y_Dyte选定上下屏
    Read_data();
 GDRAM_hbit=Read_data();             //读取当前显示高8位数据
 GDRAM_lbit=Read_data();             //读取当前显示低8位数据
   delayms(5);
   if(flag==1)
  delayms(5);
  if(x_byte<8)                       //判断其在高8位,还是在低8位
   Write_data(GDRAM_hbit|(0X01<<(7-x_byte)));   //显示GDRAM区高8位数据
   Write_data(GDRAM_lbit);             //显示GDRAM区低8位数据
     else
      Write_data(GDRAM_hbit);
   Write_data(GDRAM_lbit|(0x01<<(15-x_byte)));
 else
  Write_data((0x00));                   //清除GDRAM区高8位数据
  Write_data((0x00));                   //清除GDRAM区低8位数据
名称:Write_Line(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char colour)
功能:在指定位置上画线。
入口参数:x0  指定线起点所在行的位置
           y0   指定线起点所在列的位置
           x1   指定线终点所在行的位置
           y1   指定线终点所在列的位置
          flag  显示颜色(对于黑白色LCM,为0时灭,为1时显示)
void Write_Line(uchar x0,uchar y0,uchar x1,uchar y1,uchar flag)
    int temp;
    int dx,dy;               //定义起点到终点的横、纵坐标增加值
    int s1,s2,i,j;
    int Dx,Dy,k;
    dx=x1-x0;
    if(dx>=0)                 //X的方向是增加的
     s1=1;
    else                     //X的方向是降低的
        s1=-1;
    dy=y1-y0;                 //判断Y的方向是增加还是降到的
    if(dy>=0)
        s2=1;
    else
        s2=-1;
    Dx=abs(x1-x0);             //计算横、纵标志增加值的绝对值
    Dy=abs(y1-y0);
    if(Dy>Dx)
    {                     //以45度角为分界线,靠进Y轴是status=1,靠近X轴是status=0
        temp=Dx;
        Dx=Dy;
        Dy=temp;
     j=1;
    else
        j=0;
/*********Bresenham算法画任意两点间的直线********/
    k=2*Dy-Dx;                 //第1次判断下个点的位置
    for(i=0;i<Dx;i++)
        Write_Point(x0,y0,flag);           //画点
        if(k>=0)
            if(j==1)               //在靠近Y轴区,x值加1
            x0+=s1;
            else                     //在靠近X轴区,y值加1
            y0+=s2;
            k-=2*Dx;                 //判断下下个点的位置
        if(j==1)
            y0+=s2;
        else
            x0+=s1;
         k+=2*Dy;
名称:plotC(int x,int y,int xc,int yc,unsigned char colour)
功能:八分点画圆函数
入口参数:x 指定线起点所在行的位置
           y 指定线起点所在列的位置
          color 显示颜色(对于黑白色LCM,为0时灭,为1时显示)
void plotC(uint x,uint y,uint xc,uint yc,uchar colour)
    Write_Point(xc+x,yc+y,colour);
    Write_Point(xc+x,yc-y,colour);
    Write_Point(xc-x,yc+y,colour);
    Write_Point(xc-x,yc-y,colour);
    Write_Point(xc+y,yc+x,colour);
    Write_Point(xc+y,yc-x,colour);
    Write_Point(xc-y,yc+x,colour);
    Write_Point(xc-y,yc-x,colour);
名称:Write_yuan(int xc,int yc,int r,unsigned char colour)
功能:画圆
入口参数:xc  圆心的行坐标
           yc  圆心的列坐标
           r   半径
void Write_yuan(uint xc,uint yc,uint r,uchar colour)
    int x,y,d;
    y=r;
    d=3-2*r;
    x=0;
    while(x<=y)
        plotC(x,y,xc,yc,colour);
        if(d < 0)
            d+=(4*x)+6;
        else
            d+=(4*(x-y))+10;
            y=y-1;
        x=x+1;
/********************实心圆*********************/
名称:Write_yuan2(uint x, uint y, uint r,uchar flag)
功能:用绘图的方法填充一个矩形
入口参数:x 圆心横坐标
           y 圆心纵坐标
           r 半径长度
     flag  颜色标志位,为1.
void Write_yuan2(uint x, uint y, uint r,uchar flag)
 uint dx,dy,ref;
 uint Temp;
 if(r==0)return;
 dx=r;
 dy=1;
 ref=707*r/1000;      // 0.707r
 while(dy<=dx)
     if(dx>ref)
     Write_Line(x+ref+1,y+dy,x+dx,y+dy,flag);
     if(x>=ref+1&&dx>ref)
      if(x<dx)
        Temp=0;
      else
        Temp=x-dx;
       Write_Line(Temp,y+dy,x-ref-1,y+dy,flag);
     if(y>=dy&&dx>ref)
     Write_Line(x+ref+1,y-dy,x+dx,y-dy,flag);
     if(x>=ref+1&&y>=dy&&dx>ref)
      if(x<dx)
        Temp=0;
      else
        Temp=x-dx;
        Write_Line(Temp,y-dy,x-ref-1,y-dy,flag);
     if(dy!=dx||dx==ref)
      if(y<dx)
        Temp=0;
      else
        Temp=y-dx;
       Write_Line(x+dy,Temp,x+dy,y+dx,flag);
     if(x>=dy&&(dy!=dx||dy==ref))
      if(y<dx)
        Temp = 0;
      else
        Temp=y-dx;
       Write_Line(x-dy,Temp,x-dy,y+dx,flag);
     dy++;
     if((r*r-dy*dy)<=(dx-1)*dx)
     dx--;
 Write_Line(x+ref+1,y,x+r,y,flag);
 if(x>=ref+1)
     if(x<r)
      Temp=0;
     else
      Temp=x-r;
      Write_Line(Temp,y,x-ref-1,y,flag);
 if(y<r)
     Temp=0;
 else
     Temp=y-r;
     Write_Line(x,Temp,x,y+r,flag);
名称:Write_Full(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char colour)
功能:用绘图的方法填充一个矩形
入口参数:x0 起始点横坐标
           y0 起始点纵坐标
           x1 终止点横坐标
           y1 终止点纵坐标
void Write_Full(uchar x0,uchar y0,uchar x1,uchar y1,uchar colour)
    uchar i,j;
 for(j=y0;j<=y1;j++)
    for(i=x0;i<=x1;i++)
    Write_Point(i,j,colour);
名  称:LCD_init
功  能:初始化12864液晶
void LCD_init(void)
    Write_com(0x30);   //基本指令集
    delayms(1);
    Write_com(0x02);   //地址归位
    delayms(1);
    Write_com(0x0c);   //整体显示打开,游标关闭
    delayms(1);
    Write_com(0x01);   //清除显示屏
    delayms(1);
    Write_com(0x06);   //游标右移
    delayms(1);
    Write_com(0x80);   //设定显示的起始地址
void main ()
 uchar i=0;
    LCD_init();
    Write_com(0x01);
    Write_com(0x80);
    for(i=0;i<16;i++)
      Write_data(table[i]);
      delayms(5);
   clear_GDRAM();
   Write_Line(20,1,62,125,1);
   Write_Line(62,1,62,125,1);
   Write_Line(20,1,62,1,1);
 Write_yuan(40,40,10,1);
 Write_yuan2(40,90,20,1);
    Write_Line(40,1,40,30,1);
 Write_Line(40,30,60,30,1);
 Write_Line(60,30,60,1,1);
 Write_Line(60,1,40,1,1);
 Write_Full(40,1,60,30,1);
    while(1);
2011-12-16 16:49:23     打赏
因为手机比较垃圾。没照相功能,只能附上程序啦,好啦,今天上传2个程序,搞了好久才弄出来的。
共8条 1/1 1 跳转至页
