/**********lcd1602显示程序***************/
#include
#define uchar unsigned char
#define uint unsigned int
sbit RS=P2^4;
sbit RW=P2^5;
sbit EN=P2^6;
unsigned char code str1[]={"value: "};
unsigned char code str2[]={" "}; uchar data disdata[5]; uint tvalue;//显示的数值
/*************************lcd1602程序**************************/
void delay1ms(unsigned int ms)//延时1毫秒(不够精确的) {unsigned int i,j; for(i=0;i
