#include <reg52.h>
sfr16 DPTR=0x82;
sbit A0 = P1^1; //数据/命令切换
sbit RES = P1^4; //复位
sbit WRB = P1^2; //写控制
sbit RDB =P1^3; //读控制
sbit CS_MAIN=P1^0;
sbit led = P0^0;
void delayms(int count) //10ms
int i,j;
for(i=0;i<count;i++)
for(j=0;j<100;j++);
void main_Write_COM( int CH) //8位数据接口发送命令
A0=0;
CS_MAIN =0;
DPTR=CH;
P2=DPH;
WRB=0;
WRB=1;
P2=DPL;
WRB=0;
WRB=1;
CS_MAIN =1;
void main_Write_DATA(int DH) //8位数据接口发送数据
A0=1;
CS_MAIN =0;
DPTR=DH;
P2=DPH;
WRB=0;
WRB=1;
P2=DPL;
WRB=0;
WRB=1;
CS_MAIN =1;
void main_W_com_data( int com1,dat1)
main_Write_COM(com1);
main_Write_DATA(dat1);
void address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
main_W_com_data(0x0020,x1);//设置X坐标位置
main_W_com_data(0x0021,y1);//设置Y坐标位置
main_W_com_data(0x0050,x1); //开始X
main_W_com_data(0x0052,y1); //开始Y
main_W_com_data(0x0051,x2); //结束X
main_W_com_data(0x0053,y2); //结束Y
main_Write_COM(0x0022);
void main_init(void)
RES=1;
delayms(5);
RES=0;
delayms(10);
RES=1;
delayms(20);
//************* Start Initial Sequence **********//
main_Write_COM(0x00E5); main_Write_DATA(0x78F0); // set SRAM internal timing
main_Write_COM(0x0001); main_Write_DATA(0x0100); // set SS and SM bit
main_Write_COM(0x0002); main_Write_DATA(0x0700); // set 1 line inversion
main_Write_COM(0x0003); main_Write_DATA(0x1030); // set GRAM write direction and BGR=1.
main_Write_COM(0x0004); main_Write_DATA(0x0000); // Resize register
main_Write_COM(0x0008); main_Write_DATA(0x0207); // set the back porch and front porch
main_Write_COM(0x0009); main_Write_DATA(0x0000); // set non-display area refresh cycle ISC[3:0]
main_Write_COM(0x000A); main_Write_DATA(0x0000); // FMARK function
main_Write_COM(0x000C); main_Write_DATA(0x0000); // RGB interface setting
main_Write_COM(0x000D); main_Write_DATA(0x0000); // Frame marker Position
main_Write_COM(0x000F); main_Write_DATA(0x0000); // RGB interface polarity
//*************Power On sequence ****************//
main_Write_COM(0x0010); main_Write_DATA(0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
main_Write_COM(0x0011); main_Write_DATA(0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
main_Write_COM(0x0012); main_Write_DATA(0x0000); // VREG1OUT voltage
main_Write_COM(0x0013); main_Write_DATA(0x0000); // VDV[4:0] for VCOM amplitude
main_Write_COM(0x0007); main_Write_DATA(0x0001);
delayms(200); // Dis-charge capacitor power voltage
main_Write_COM(0x0010); main_Write_DATA(0x1090); // 1490//SAP, BT[3:0], AP, DSTB, SLP, STB
main_Write_COM(0x0011); main_Write_DATA(0x0227); // DC1[2:0], DC0[2:0], VC[2:0]
delayms(50); // Delay 50ms
main_Write_COM(0x0012); main_Write_DATA(0x001F); //001C// Internal reference voltage= Vci;
main_Write_COM(0x0013); main_Write_DATA(0x1500); //0x1000//1400 Set VDV[4:0] for VCOM amplitude 1A00
main_Write_COM(0x0029); main_Write_DATA(0x0027); //0x0012 //001a Set VCM[5:0] for VCOMH //0x0025 0034
main_Write_COM(0x002B); main_Write_DATA(0x000D); // Set Frame Rate 000C
main_Write_COM(0x0020); main_Write_DATA(0x0000); // GRAM horizontal Address
main_Write_COM(0x0021); main_Write_DATA(0x0000); // GRAM Vertical Address
// ----------- Adjust the Gamma Curve ----------//
main_Write_COM(0x0030); main_Write_DATA(0x0000);
main_Write_COM(0x0031); main_Write_DATA(0x0707);
main_Write_COM(0x0032); main_Write_DATA(0x0307);
main_Write_COM(0x0035); main_Write_DATA(0x0200);
main_Write_COM(0x0036); main_Write_DATA(0x0008);//0207
main_Write_COM(0x0037); main_Write_DATA(0x0004);//0306
main_Write_COM(0x0038); main_Write_DATA(0x0000);//0102
main_Write_COM(0x0039); main_Write_DATA(0x0707);//0707
main_Write_COM(0x003C); main_Write_DATA(0x0002);//0702
main_Write_COM(0x003D); main_Write_DATA(0x1D04);//1604
//------------------ Set GRAM area ---------------//
main_Write_COM(0x0050); main_Write_DATA(0x0000); // Horizontal GRAM Start Address
main_Write_COM(0x0051); main_Write_DATA(0x00EF); // Horizontal GRAM End Address
main_Write_COM(0x0052); main_Write_DATA(0x0000); // Vertical GRAM Start Address
main_Write_COM(0x0053); main_Write_DATA(0x013F); // Vertical GRAM Start Address
main_Write_COM(0x0060); main_Write_DATA(0xA700); // Gate Scan Line
main_Write_COM(0x0061); main_Write_DATA(0x0001); // NDL,VLE, REV
main_Write_COM(0x006A); main_Write_DATA(0x0000); // set scrolling line
//-------------- Partial Display Control ---------//
main_Write_COM(0x0080); main_Write_DATA(0x0000);
main_Write_COM(0x0081); main_Write_DATA(0x0000);
main_Write_COM(0x0082); main_Write_DATA(0x0000);
main_Write_COM(0x0083); main_Write_DATA(0x0000);
main_Write_COM(0x0084); main_Write_DATA(0x0000);
main_Write_COM(0x0085); main_Write_DATA(0x0000);
//-------------- Panel Control -------------------//
main_Write_COM(0x0090); main_Write_DATA(0x0010);
main_Write_COM(0x0092); main_Write_DATA(0x0600);
main_Write_COM(0x0007); main_Write_DATA(0x0133); // 262K color and display ON
void Pant(unsigned int color)
int i,j;
address_set(0,0,240,320);
for(i=0;i<320;i++)
for (j=0;j<240;j++)
main_Write_DATA(color);
main()
led = 0;
main_init(); //tft初始化
while(1)
Pant(0xf800); //红
Pant(0X07E0); //绿
Pant(0x001f); //蓝
Pant(0xffe0); //黄
Pant(0x0000); //黑
Pant(0xffff); //白
Pant(0x07ff); //青
Pant(0xd343); //暗红
