电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » LM3S811 使用心得 之超声波测距
共12条 1/2 1 2 › 跳转至页
LM3S811 使用心得 之超声波测距
2012-02-23 20:52:41     打赏
LM3S811 使用心得二  之超声波测距
计算出到障碍物的距离,并通过5110lcd显示出来
//main.c
#include "LM3S811.h"
#include "uart1.h"
#include "uart0.h"
#include <stdio.h>
/*****************超声波数据结构声明**********************/
typedef struct suWaveData
uint8 flag;
uint8 tempcmd[4];
   //温度
uint8 tempdata[2];
uint8 distcmd[4];
   //距离
uint8 distdata[2];
}suWave_t;
suWave_t suWave1={0x00,0x11,0x00,0x00,0x11,0x00,0x00,
  0x22,0x55,0x00,0x77,0x00,0x00}; //初始化超声波数据变量
/******************函数声明*********************************/
static void init_LM3S811(void);
static void delay(uint16 dly);
void   process_udata(suWave_t *pfile);
function:main 函数
input:    null
output:   null
author:  gyk
data:
  2011_11_18
int main(void)
init_LM3S811();
init_UART0(9600,2);
init_UART1(9600,3);
IntMasterEnable();
send_str_UART1("System initialization sucessful!!!\n");
send_str_UART1("Waiting for the data from URM37V3.2...\n");
for(;;)
send_UART0(suWave1.tempcmd,4);
delay(100);
send_UART0(suWave1.distcmd,4);
delay(100);
process_udata(&suWave1);
delay(5000);
function:初始化
input:    null
output:   null
author:  gyk
data:
  2011_11_18
SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);
function:延时
input:    dly
output:   null
author:  gyk
data:
  2011_11_18
uint16 i;
for(;dly>0;dly--)
for(i=0;i<100;i++);
function: 超声波数据处理
input:    null
output:   null
author:  gyk
data:
  2011_11_18
uint8 buffer[30];
uint16 tmp;
fp32   ftmp;
if(pfile->flag&&0x01)
if((pfile->tempdata[0]==0xFF)&&(pfile->tempdata[1]==0xFF))
send_str_UART1("Temperature: invalid data!\n");
return;
if((pfile->tempdata[0]&0xF0)==0xF0)
tmp=(uint16)(pfile->tempdata[0]&0xF0);
tmp<<=8;
tmp|=(uint16)pfile->tempdata[1];
ftmp=(fp32)tmp*0.1;
send_UART1(buffer,sprintf((char *)buffer,"temerature:  -%f\n",ftmp));
if((pfile->tempdata[0]&0xF0)==0x00)
tmp=(uint16)(pfile->tempdata[0]);
tmp<<=8;
ftmp=(fp32)tmp*0.1;
send_UART1(buffer,sprintf((char *)buffer,"temerature:  %f\n",ftmp));
pfile->flag&=0xFE;
if(pfile->flag&0x02)
tmp=(uint16)pfile->distdata[0];
tmp<<=8;
tmp|=pfile->distdata[1];
if(tmp==0xFFFF)
send_str_UART1("distance: invalid data!\n");
return;
send_UART1(buffer,sprintf((char *)buffer,"distance:  %f\n",tmp));
pfile->flag&=0xFD;
function: interrupt
input:    null
output:   null
author:  gyk
data:
  2011_11_18
void uart0_isr(void)
uint8 ch;
unsigned long ulStatus;
ulStatus=UARTIntStatus(UART0_BASE,true);
UARTIntClear(UART0_BASE,ulStatus);
if((ulStatus&UART_INT_RT)||(ulStatus&UART_INT_RX))
ch=UARTCharGet(UART0_BASE);
if(ch==0x11)
suWave1.tempdata[0]=UARTCharGet(UART0_BASE);
suWave1.tempdata[1]=UARTCharGet(UART0_BASE);
suWave1.flag|=0x01;
if(ch==0x022)
suWave1.distdata[0]=UARTCharGet(UART0_BASE);
suWave1.distdata[1]=UARTCharGet(UART0_BASE);
suWave1.flag|=0x02;
//uart0.h
#ifndef  _UART0_H_
#define  _UART0_H_
extern uint8 init_UART0(uint32 baudrate,uint8 prio);
extern void  send_UART0(uint8 *pbuffer,uint16 size);
extern void recv_UART0(void);
extern void  send_str_UART0(uint8 *pstr);
#endif
//uart1.h
#ifndef  _UART1_H_
#define  _UART1_H_
extern uint8 init_UART1(uint32 baudrate,uint8 prio);
extern void  send_UART1(uint8 *pbuffer,uint16 size);
extern void recv_UART1(void);
extern void  send_str_UART1(uint8 *pstr);
#endif
//uart0.c
#include"LM3S811.h"
function: 初始化串口0
input:    波特率,ISR优先级
output:   fasle失败,true成功
author:  gyk
data:
  2011_11_18
if(baudrate>15200)
return FALSE;
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
GPIOPinTypeUART(GPIO_PORTA_BASE,GPIO_PIN_0|GPIO_PIN_1);
UARTConfigSetExpClk(UART0_BASE,SysCtlClockGet(),baudrate,(UART_CONFIG_WLEN_8|UART_CONFIG_STOP_ONE|UART_CONFIG_PAR_NONE));
UARTFIFOLevelSet(UART0_BASE,UART_FIFO_TX1_8,UART_FIFO_RX4_8);
    UARTIntEnable(UART0_BASE,UART_INT_RX|UART_INT_RT);
IntEnable(INT_UART0);
IntPrioritySet(INT_UART0,prio);
UARTEnable(UART0_BASE);
return TURE;
function: 串口0发送数据
input:    缓冲区大小,数据大小
output:   null
author:  gyk
data:
  2011_11_18
uint16 i;
for(i=0;i<size;i++)
UARTCharPut(UART0_BASE,pbuffer);
while(UARTBusy(UART0_BASE));
function: 串口0发送字符串
input:    字符串指针
output:   null
author:  gyk
data:
  2011_11_18
while(*pstr!='\0')
UARTCharPut(UART0_BASE,*pstr++);
//uart1.c
#include"LM3S811.h"
function: 初始化串口1
input:    波特率,ISR优先级
author:  gyk
data:
  2011_11_18
if(baudrate>15200)
return FALSE;
(void)prio;
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART1);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
GPIOPinTypeUART(GPIO_PORTD_BASE,GPIO_PIN_2|GPIO_PIN_3);
UARTConfigSetExpClk(UART1_BASE,SysCtlClockGet(),baudrate,(UART_CONFIG_WLEN_8|UART_CONFIG_STOP_ONE|UART_CONFIG_PAR_NONE));
UARTFIFOLevelSet(UART1_BASE,UART_FIFO_TX1_8,UART_FIFO_RX4_8);
UARTEnable(UART1_BASE);
return TURE;
function: 串口1发送数据
input:    缓冲区大小,数据大小
output:   null
author:  gyk
data:
  2011_11_18
uint16 i;
for(i=0;i<size;i++)
UARTCharPut(UART1_BASE,pbuffer);
while(UARTBusy(UART1_BASE));
function: 串口1发送字符串
input:    字符串指针
output:   null
author:  gyk
data:
  2011_11_18
while(*pstr!='\0')
UARTCharPut(UART1_BASE,*pstr++);
下载 (46.53 KB)
2011-11-22 18:25
关键词: LM3S811     使用     心得     超声波     测距     uint
2012-02-23 20:53:32     打赏
2012-02-23 20:54:09     打赏
//关于定时器的使用
void  SysClockInit_40M(void)
SysCtlLDOSet( SYSCTL_LDO_2_75V);
    SysCtlDelay(SysCtlClockGet()/3000);
                                                     //延时1ms,稳定芯片用
SysCtlClockSet(SYSCTL_SYSDIV_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_6MHZ);   //5分频,PLL设置时钟为40M
//延时1ms,稳定芯片用
SysCtlLDOSet( SYSCTL_LDO_2_50V);
void Timer0A_ISR(void)
     TimerIntClear(TIMER0_BASE,TIMER_TIMA_TIMEOUT );
//清除中断源
     counter++;
//处理过程
     void TimerEnable(TIMER0_BASE, Timer_A);
             //使能定时器
int main(void)
    SysClockInit_40M();
SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);           //使能定时器0
// 使能PA端口
    GPIOPinTypeGPIOInput(GPIO_PORTA_BASE, GPIO_PIN_0);
// 设置PA0为超声波的echo管脚
GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_1 );
// 设置PA1为超声波的trig管脚
/*************************************关于定时器中断的设置**********************************/
    TimerConfigure(TIMER0_BASE, TIMER_CFG_16_BIT_PAIR|TIMER_CFG_A_PERIODIC);   //配置成16位周期定时器,使用定时器A
    void TimerLoadSet(TIMER0_BASE,  Timer_A, unsigned long ulValue);
   //设置定时器初始值
void TimerIntRegister(TIMER0_BASE,  Timer_A,void Timer0A_ISR(void));
   //声明定时器A的中断处理函数
                                   //使能定时器
void TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
                   //使能中断,设置为定时器A的溢出中断
GPIOPinWrite(GPIO_PORTC_BASE,GPIO_PIN_1,GPIO_PIN_1);
GPIOPinRead(GPIO_PORTC_BASE, GPIO_PIN_0);
while(1)
//trig口设置高电平信号,启动超声波传感器
        SysCtlDelay(SysCtlClockGet()/3000/50);
//高电平持续 20US
GPIOPinWrite(GPIO_PORTC_BASE,GPIO_PIN_1,~GPIO_PIN_1);
//trig口置低电平
flag=0;
//设置标志位,方便对超声波传感器的控制
while(flag==0)
if(GPIOPinRead(GPIO_PORTA_BASE, GPIO_PIN_0)==0)
   { SysCtlIntDisable(TIMERA_BASE, TIMER_TIMA_TIMEOUT);     //关闭中断
  distance=counter;
  counter=0;
  flag=1;
  while(GPIOPinRead(GPIO_PORTA_BASE, GPIO_PIN_0)==0);    //等待超声波的echo端口转变为高电平,表示一次测距结束
2012-02-23 22:52:28     打赏
支持一下!!
2012-02-24 08:36:44     打赏
这个设计的好,有没有完整的资料。
2012-02-24 09:24:04     打赏
最好还是有个附件吧,在IAR下看要方便些
2012-02-24 12:03:45     打赏
3q
2012-02-24 12:04:47     打赏
硬件电路就那样嘛
2012-02-24 12:05:24     打赏
我用的是keil
2012-02-24 19:04:16     打赏
return TURE;
function: 串口1发送数据
input:    缓冲区大小,数据大小
output:   null
author:  gyk
data:
  2011_11_18
uint16 i;
for(i=0;i<size;i++)
function: 串口1发送字符串
input:    字符串指针
output:   null
author:  gyk
data:
  2011_11_18
while(*pstr!='\0')
共12条 1/2 1 2 › 跳转至页
