上传LED的代码,参考正点原子的
#include "stm32f10x_conf.h"
#include "stm32f10x_it.h"
#define LED_ALL (GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5) //GPIO管脚定义
#define LED_GPIO_PORT GPIOE
#define LED_GPIO_CLK RCC_APB2Periph_GPIOE //时钟定义
//***********两个枚举类型定义***************//
typedef enum
ON = 1,
OFF = 0
}Led_SettingDef;
typedef enum
LED1 = GPIO_Pin_2,
LED2 = GPIO_Pin_3,
LED3 = GPIO_Pin_4,
LED4 = GPIO_Pin_5,
ALL_LED = (GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5)
}Led_TypeDef;
//****************LED初始化*************//
void LED_Init(Led_TypeDef led)
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = led;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
RCC_APB2PeriphClockCmd(LED_GPIO_CLK, ENABLE);
GPIO_Init(LED_GPIO_PORT, &GPIO_InitStructure);
//***************LED亮、灭操作函数*************//
void LED_Set(Led_TypeDef led, Led_SettingDef set)
if (set == ON)
GPIOE->BRR = led;
else GPIOE->BSRR = led;
//**************delay函数**************//
void delay(long Time)
long i;
if(Time > 0)
for(i = 0;i < 5000000;i++)
Time --;
//****************main*******************//
int main(void)
int j = 0;
Led_TypeDef led = ALL_LED;
LED_Init(led);
LED_Set(led, ON); //点亮4个灯,测试是否能正常工作
delay(5000000);
LED_Set(led, OFF);
// LED_Toggle(led);
while(1)
delay(5000000);
switch(j)
case 0:
LED_Set(LED1,ON);
LED_Set(LED4,OFF);
j++;
break;
case 1:
LED_Set(LED2,ON);
LED_Set(LED1,OFF);
j++;
break;
case 2:
LED_Set(LED3,ON);
LED_Set(LED2,OFF);
j++;
break;
case 3:
LED_Set(LED4,ON);
LED_Set(LED3,OFF);
j++;
break;
default:
break;
if(j == 4)
j = 0;
有奖活动 | |
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
