定时器查询实验:
本实验以LED控制实验为基础,使用TIM2查询方式作为延时实现走马灯效果。本实验使用的是8MHz的晶振。使用官方3.5.0的库。
TIM2的CK_INT时钟是APB1的倍频,除非APB1的时钟分频数设置为1.本实验APB1的时钟是HCLK/2 = 36Mhz,所以CK_INT的时钟频率为72Mhz。
TIM2初始化代码:
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
TIM_InitTypeDef.TIM_Prescaler = 7200; //预分频 72Mhz/7200 = 10Khz T = 0.1ms
TIM_InitTypeDef.TIM_CounterMode = TIM_CounterMode_Up; //向上计数
TIM_InitTypeDef.TIM_Period = 5000; //自动重装载值 这里定时为 500ms
TIM_InitTypeDef.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_InitTypeDef.TIM_RepetitionCounter = 0; //TIM1和TIM8使用
TIM_TimeBaseInit(TIM2, &TIM_InitTypeDef);
TIM_ClearFlag(TIM2, TIM_FLAG_Update);
使用方式:
while(1)
GPIO_SetBits(GPIO_LED,DS1_PIN|DS2_PIN|DS3_PIN|DS4_PIN);
Turn_On_LED(i);
i++;
if(i>3)
i = 0;
TIM_Cmd(TIM2, ENABLE);
while(TIM_GetFlagStatus(TIM2, TIM_FLAG_Update)==RESET);
TIM_Cmd(TIM2, DISABLE);
定时器中断方式:
基于定时器查询方式实验上,实现走马灯效果。
在TIM2初始化代码:
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE); //打开更新中断
中断控制器初始化:
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; //中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//强占优先级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //次优先级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //通道中断使能
NVIC_Init(&NVIC_InitStructure); //初始化中断
24C02读写实验:
向24C02的00H到13H地址写入0x0~0x13,然后读出,通过串口输出到终端。
初始化代码:
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; //复用开漏输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //复用开漏输出
GPIO_ResetBits(GPIOB,GPIO_Pin_5);
I2C_DeInit(I2C1);
I2C1_InitStruct.I2C_Mode = I2C_Mode_I2C;
I2C1_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2;
I2C1_InitStruct.I2C_OwnAddress1 = 0x30;
I2C1_InitStruct.I2C_Ack = I2C_Ack_Enable;
I2C1_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C1_InitStruct.I2C_ClockSpeed = 200000;
I2C_Cmd(I2C1,ENABLE);
I2C_Init(I2C1, &I2C1_InitStruct);
I2C_AcknowledgeConfig(I2C1,ENABLE);
这是个是一个脚,FSMC_NADV估计在初始化FSMC的时候动了。
IIC初始化放到LCD初始化之前就没事了。
不过现在还有问题。IIC真麻烦
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 |
