电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » aagreen0514 ARM DIY进程帖
共43条 2/5 ‹ 1 2 3 4 5 › 跳转至页
2012-03-29 10:49:29     打赏
11楼
坐等 PCB 板
2012-03-29 13:42:42     打赏
12楼
终于拿到板了
开始焊接
2012-03-29 13:47:04     打赏
13楼
MCU焊接
1 对其管脚
2固定MCU
3上满焊锡
4去除多余的焊锡 加适量松香 效果更好
5用酒精擦出松香
2012-03-29 18:49:41     打赏
14楼
板子焊好了
2012-03-30 10:48:20     打赏
15楼
可以下载了 流水点好了 呵呵
2012-03-31 14:42:06     打赏
16楼
最后 一个 部件 液晶 收到了
2012-03-31 19:51:19     打赏
17楼
发现PCB错误了 液晶接口 20和21脚 和原理图 反了  和 买的 LCD模块也 反了 纠结了一下无 总算发现了
红圈 处两个焊盘对调
2012-03-31 19:52:31     打赏
18楼
对调好了 上一个LCD图片
2012-03-31 19:54:07     打赏
19楼
FMSC 配置 程序
void fsmc_init(void)
/* FSMC GPIO configure */
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF
                           | RCC_APB2Periph_GPIOG, ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    FSMC_D0 ~ FSMC_D3
    PD14 FSMC_D0   PD15 FSMC_D1   PD0  FSMC_D2   PD1  FSMC_D3
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_14 | GPIO_Pin_15;
    GPIO_Init(GPIOD,&GPIO_InitStructure);
    FSMC_D4 ~ FSMC_D12
    PE7 ~ PE15  FSMC_D4 ~ FSMC_D12
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10
                                  | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
    GPIO_Init(GPIOE,&GPIO_InitStructure);
    /* FSMC_D13 ~ FSMC_D15   PD8 ~ PD10 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
    FSMC_A0 ~ FSMC_A5   FSMC_A6 ~ FSMC_A9
    PF0     ~ PF5       PF12    ~ PF15
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3
                                  | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
    GPIO_Init(GPIOF,&GPIO_InitStructure);
    /* FSMC_A10 ~ FSMC_A15  PG0 ~ PG5 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
    GPIO_Init(GPIOG,&GPIO_InitStructure);
    /* FSMC_A16 ~ FSMC_A18  PD11 ~ PD13 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
    /* RD-PD4 WR-PD5 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
    /* NBL0-PE0 NBL1-PE1 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
    /* NE1/NCE2 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    /* NE2 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    /* NE3 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    /* NE4 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
static void LCD_FSMCConfig(void)
    FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
    FSMC_NORSRAMTimingInitTypeDef  p;
    /*-- FSMC Configuration ------------------------------------------------------*/
    p.FSMC_AddressSetupTime = 2;             /* 地址建立时间  */
    p.FSMC_AddressHoldTime = 1;              /* 地址保持时间  */
    p.FSMC_DataSetupTime = 3;                /* 数据建立时间  */
    p.FSMC_BusTurnAroundDuration = 0;        /* 总线返转时间  */
    p.FSMC_CLKDivision = 0;                  /* 时钟分频      */
    p.FSMC_DataLatency = 0;                  /* 数据保持时间  */
    p.FSMC_AccessMode = FSMC_AccessMode_A;   /* FSMC 访问模式 */
    /* Color LCD configuration ------------------------------------
       LCD configured as follow:
          - Data/Address MUX = Disable
          - Memory Type = SRAM
          - Data Width = 16bit
          - Write Operation = Enable
          - Extended Mode = Enable
          - Asynchronous Wait = Disable */
    FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
    FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
    FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
    FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
    FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
2012-04-01 13:18:18     打赏
20楼
Ascii 顺利 写出
